purtypitcher Samba Member
Joined: April 15, 2025 Posts: 13 Location: Lexington KY
Posted: Sun Oct 26, 2025 7:38 am Post subject: '87 Westy, auto, dropped all trans fluid |
Hi, first post, long, new to Vanagons. My ’87 Westy camper, Subaru 2.5, auto, Peloquin, dropped all its trans fluid in the Tennessee Smoky Mountains. About five miles from when I first noticed a slipping to when I knew I had to get off the road. Big red puddle forming under the van.
Engine and trans were installed by previous owner about 30,000 miles ago by Small Car in Tacoma. They rebuilt the engine from a 2011 Legacy and the trans is rebuilt by German Transaxle in Bend OR. There is also a trans cooler that is thermostatically controlled (German Trans requires it for warranty, but warranty is past). The van has run perfectly for the 5000 miles I have driven it up until now. (Most of that is the road trip back to Lexington KY (home) from Seattle where I bought it. Previous owner very meticulous on maintenance and upkeep. Have been planning to establish a relationship with a local VW mechanic but have not done that yet.
AAA towed it to Thomas Auto Service in Sevierville yesterday (Saturday) and AAA said they would be open but they were not. So the driver put it in a spot by the front door, and I left a pretty long note, and key in the drop box (I do have another key with me, thanks to girlfriend who came separately to camp with me (lol). Thomas landline was “not accepting messages”. So, I will call them tomorrow morning (Monday) when they open at 7AM. Currently “camping” in a Gatlinburg hotel.
Thomas is a AAA shop, so I guess that is good but I have no idea. They do have a Jasper sign for engine/trans work. But this is of course not a standard factory vehicle, so I am concerned about having them work on it. Anybody familiar with Thomas Auto Service?
There was trans fluid sprayed quite a bit around the trans and the cooler, but I couldn’t get a read on where it had actually come from.
Long post, but what I could use is some advice or maybe anybody in the area who might even be able to take a quick visual at it today perhaps? I’m hoping it’s a blown seal or hose or something “easy”. Or any contact names you might know in the area who could offer advice, etc?
Thanks….. Don
Red Ryder Samba Member
Joined: June 26, 2021 Posts: 1230 Location: PNW — Washington
Posted: Sun Oct 26, 2025 8:39 am Post subject: Re: '87 Westy, auto, dropped all trans fluid |
A few possibilities but I would certainly check the external transmission cooler and its hose connections first. _________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
“Scarlett” — 1990 Vanagon Carat Wolfsburg Edition (Tornado Red)
“Nigel” — 1999 Jaguar XK8 convertible (Alpine Green Metallic)
Posted: Sun Oct 26, 2025 8:53 am Post subject: Re: '87 Westy, auto, dropped all trans fluid |
| That's what I'm hoping. There did seem to be a lot of fluid sprayed around in that area but it had mostly all dripped out before I was able to look under there. |
jlrftype7 Samba Member
Posted: Sun Oct 26, 2025 1:07 pm Post subject: Re: '87 Westy, auto, dropped all trans fluid |
Shop will possibly refilled your trans after washing everything off with brake cleaner, then briefly run the engine to locate your source of leakage, unless it’s so apparent, like a split or punctured hose, that diag isn’t fully need until the visible leak gets fixed first. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 19158 Location: Retired South Florida
Posted: Sun Oct 26, 2025 6:25 pm Post subject: Re: '87 Westy, auto, dropped all trans fluid |
| There really not a common failure that would pump the fluid out of the transmission stock. You’ve added an external cooler which as suggested is the likely failure. It could be safely bypassed with a loop of high pressure hose to get you on your way. |
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2688 Location: Southeast Kentucky
Posted: Sun Oct 26, 2025 7:55 pm Post subject: Re: '87 Westy, auto, dropped all trans fluid |
Well, we just got back from the Smokies.
I was in the general area most all afternoon today.
Unfortunately, I do not use a smart phone. So, I did not see your message until I got home. Hmm.
Anyway, I am tending to agree with what others are saying. Likely a hose or the cooler.
Keep us posted. _________________ '84 Vanagon Tin-top, ALH TDI, two trips to Alaska, 2014 & 16. 1989 Tin-top unmolested.
1983 Air-cool, 225k miles, 180k miles mine, seven trips to Alaska from 1986 thru 2003. 1975 Bay hopeful. |
Posted: Mon Oct 27, 2025 12:50 pm Post subject: Re: '87 Westy, auto, dropped all trans fluid |
| Thanks for the replies. Yup, loose hose clamp on the trans cooler and it dislodged. They had it ready by 11:00am, pretty great to squeeze me in on a Monday morning. And definitely can’t remember the last time I had just a $69 car repair! So, another thing to add to the “check often” list. |
SCM Samba Member
Joined: January 26, 2011 Posts: 3483 Location: Bozeman MT
Posted: Mon Oct 27, 2025 1:47 pm Post subject: Re: '87 Westy, auto, dropped all trans fluid |
Do you have a picture you could post? I ask because my trans (also rebuilt by GTA and running the "GoWesty-style" trans cooler) doesn't use any clamps to connect the hoses to the cooler. They use some sort of barbed fitting.
I worry that your cooler is maybe not connected properly (wrong diameter hoses, etc) if it needs additional clamps. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Posted: Mon Oct 27, 2025 3:25 pm Post subject: Re: '87 Westy, auto, dropped all trans fluid |
| I’ll crawl under there when I’m not in the woods and pouring rain and try to get a pic. The trans, trans cooler, Peloquin, and rebuilt Sub 2.5L were all installed by Small Car, they’ve done a bunch so I hope it’s right. The guy at the service counter today said it was same as a regular stainless hose clamp that you simply tighten up, but now you’ve got me curios! |
SCM Samba Member
Posted: Mon Oct 27, 2025 3:29 pm Post subject: Re: '87 Westy, auto, dropped all trans fluid |
Here's what mine looks like. I had one of the brass fittings leak a little bit but not the hoses.
Posted: Tue Oct 28, 2025 7:39 am Post subject: Re: '87 Westy, auto, dropped all trans fluid |
| Mine is off to the side, circular in shape, and fan only comes on via thermostat when needed. I assume trans fluid always flows through it, and its fan gives an extra airflow boost when it switches on. I’ll definitely take a close look when I get home, will be a few days. Is yours always “on”? Not thermostat controlled? Is there a fan? |
kamzcab86 Samba Moderator
Posted: Tue Oct 28, 2025 8:20 am Post subject: Re: '87 Westy, auto, dropped all trans fluid |
| purtypitcher wrote: |
fan only comes on via thermostat |
If SmallCar installed all of that, then it's not (or shouldn't be) a GoWesty trans cooler.
https://smallcar.com/t2-vanagon-automatic-transmission-cooler-supreme/
^That doesn't show all of the hardware that the basic version comes with: https://smallcar.com/automatic-transmission-cooler-kit/ . It does utilize worm-gear hose clamps, which can loosen over time.
Good to hear it was a simple issue, and easily resolved. _________________ 1986 Cabriolet: www.Cabby-Info.com
2016 Golf GTI S
Posted: Tue Oct 28, 2025 9:26 am Post subject: Re: '87 Westy, auto, dropped all trans fluid |
The GoWesty cooler has no fan unless you would add one. Thermostat limits ATF flow until ATF is hot enough to open the Thermostat. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
SCM Samba Member
Posted: Tue Oct 28, 2025 10:18 am Post subject: Re: '87 Westy, auto, dropped all trans fluid |
| jlrftype7 wrote: |
| The GoWesty cooler has no fan unless you would add one. Thermostat limits ATF flow until ATF is hot enough to open the Thermostat. |
Oh, yeah, we're talking about different types of coolers. I forgot about the type with the fan. Mine (GoWesty and also sold under other names) is a non-fan radiator type that has a T-stat the opens once the ATF gets warm enough.
But my point about the hose connections still stands. If a loose clamp can cause such a big loss of fluid maybe there's a better way to secure that hose.
FWIW, I wish I would've went with the older style heat sink cooler that mounts directly to the front of the trans. Seems like less failure points and, considering the older vans had NO cooler, would probably be just fine for my use. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Posted: Tue Oct 28, 2025 5:17 pm Post subject: Re: '87 Westy, auto, dropped all trans fluid |
| SCM wrote: |
| jlrftype7 wrote: |
FWIW, I wish I would've went with the older style heat sink cooler that mounts directly to the front of the trans. Seems like less failure points and, considering the older vans had NO cooler, would probably be just fine for my use. |
I have the GoWesty cooler kit- knock knock, never had a leak from the assembly- but, I should probably replace the hoses since they’ve been in service from 2019. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
SCM Samba Member
Posted: Wed Oct 29, 2025 3:06 pm Post subject: Re: '87 Westy, auto, dropped all trans fluid |
| jlrftype7 wrote: |
| I should probably replace the hoses since they’ve been in service from 2019. |
I hope you find a cheaper way to go than I did.
I looked into it, and got analysis paralysis trying to figure out what type/size of hose I needed to use and the type/size/thread pitch of the fittings. Then needing to buy tools to press the hoses into those barbed fittings because apparently you can't do it by hand...
I thought, I'm swamped at work and want to get this dealt with in time for an upcoming trip, should be an easy / cheap job for my shop. Nope, they quoted me something like $1k.
When I talked to them about it they had based the estimate on buying an entire new cooler kit from GoWesty because the time they would spend fabbing up new hoses would cost even more - apparently they hit the same unknowns I had. Add in shop labor and their quote was actually not off base at all.
When I turned down the work the guy at the shop asked, "do you plan to keep the van for a while?". "Yeah, a long time". "In that case, I would just buy the kit from GoWesty, use the new hoses that come with it, and keep the cooler for a spare or sell it". Soooo, I did. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Posted: Wed Oct 29, 2025 7:05 pm Post subject: Re: '87 Westy, auto, dropped all trans fluid |
| SCM wrote: |
| jlrftype7 wrote: |
When I turned down the work the guy at the shop asked, "do you plan to keep the van for a while?". "Yeah, a long time". "In that case, I would just buy the kit from GoWesty, use the new hoses that come with it, and keep the cooler for a spare or sell it". Soooo, I did. |
I remember Chris Corkins/10 Cent talking about what it takes to replace the oil cooler hoses on his kits. I was hoping the hoses and barbs would be like that with the GoWesty kit, hand tools needed only. Now you’ve got me wondering….
Sooo, I went to the GoWesty web site , the hoses in the current Cooler kit have changed, Big crimped look to all of them now . Price for the whole kit is sort of in the ball park of where is was in 2019. Might have to just buy another one like you did. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
Posted: Thu Oct 30, 2025 7:53 pm Post subject: Re: '87 Westy, auto, dropped all trans fluid |
Kamz, thanks for those Small Car links. Yes, mine is their circular "Supreme" cooler with the thermostat. I just got home from the Smokies and will look things over when I have a free day. I don't have the paperwork in front of me, but the previous owner included the GTA warranty notes. They apparently have a specific warranty for a Small Car/Subaru/GTA installation, I'll have to look at it again. I recall it requires 30,000 mile fluid changes and a specific fluid which I can't remember until I look at the notes.
Also, previous owner said GTA built the trans with "Subaru turbo" spec, but I don't know what that includes. Mine is a standard 2.5 built by Small Car. |
SCM Samba Member
Posted: Fri Oct 31, 2025 4:03 pm Post subject: Re: '87 Westy, auto, dropped all trans fluid |
[quote="purtypitcher"]
Also, previous owner said GTA built the trans with "Subaru turbo" spec, but I don't know what that includes. Mine is a standard 2.5 built by Small Car.[/]
I bet it’s the same as what I have. I’ll try to remember to post a photo of the build sheet but I think it’s basically an extra clutch pack or two on the forward gears. Another for reverse, and replacing plastic bushings with brass versions. Maybe another's planetary gear somewhere too?
Again , I’ll try to remember to to post the real specs later on. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Posted: Fri Oct 31, 2025 6:40 pm Post subject: Re: '87 Westy, auto, dropped all trans fluid |
| Thanks SCM. I've had it on my ToDo to call GTA and inquire what the turbo build means. I'm slammed for a few days with stuff but will check in with them later and report back. Also will let them know about the clamp failure that spit out all the fluid. |
