Did I just discover one of Vanagon's unknown secrets?
jakekoebrich
jakekoebrich is offline
PostPosted: Wed Oct 29, 2025 10:52 am    Post subject: Did I just discover one of Vanagon's unknown secrets? Reply with quote
Hi guys, I'm installing some sound deadening in my 85 Vanagon and I just realized there's an air vent on the door however there doesn't seem to be any port coming from the front dashboard to feed air into the door? Is that sliding vent useless? There seems to be a hole in the door that's supposed to pass the air into the bulkhead behind the cabinetry but again where does that airflow come from? Is this an unknown secret? (cue the spooky music)
kamzcab86
kamzcab86 is offline
PostPosted: Wed Oct 29, 2025 11:07 am    Post subject: Re: Did I just discover one of Vanagon's unknown secrets? Reply with quote
Nope; not a secret. It's your van's flow-through ventilation:
https://gowesty.com/blogs/article-library/ventilation-heat-and-a-c-in-the-vanagon-explained
Wink
2016 Golf GTI S
jimf909
jimf909 is offline
PostPosted: Wed Oct 29, 2025 11:11 am    Post subject: Re: Did I just discover one of Vanagon's unknown secrets? Reply with quote
The secret is that you can stow a full size umbrella in the door in that duct. Stash it in the passenger door so it can be accessed safely while on the side of the road.
- Jim
Butcher wrote:
Guilty as charged.
E1
E1 is offline
PostPosted: Wed Oct 29, 2025 11:14 am    Post subject: Re: Did I just discover one of Vanagon's unknown secrets? Reply with quote
The sliding vent indeed works, a dusty drive on a dirt road will prove it.
The front of the door has an oval opening sealed with a rubber perimeter to keep dust out, and it’s mated to the painted framework forward of it.
The rear of the door has another oval opening that mates to the chassis just aft of the door, where it’s surrounded by a “brush” trim on the chassis to keep dust out.
From there, the air feeding all this goes straight up the pillar forward of the sliding door, and continues to the upper vents above the slider.
On Westys anyway, I think the airflow stops at the pillar on the driver’s side… I can’t speak to non-Westys, but imagine they have upper wall vents like the passenger side of Westys have.
If ever twice as rich, we’re gettin’ a double-wide
’84 “Westfailure”/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans
The caveman’s first question to the headhunter: “Hey, you got any coffee?”
bobbyblack Premium Member
bobbyblack is offline
PostPosted: Wed Oct 29, 2025 12:51 pm    Post subject: Re: Did I just discover one of Vanagon's unknown secrets? Reply with quote
Careful on that tho, a big bump can jog that umbrella back into the B pillar and you can't open the door...
-bobby
mrinnovation1
mrinnovation1 is offline
PostPosted: Wed Oct 29, 2025 3:13 pm    Post subject: Re: Did I just discover one of Vanagon's unknown secrets? Reply with quote
Who needs an umbrella? Its just water.
?Waldo?
?Waldo? is offline
PostPosted: Wed Oct 29, 2025 4:55 pm    Post subject: Re: Did I just discover one of Vanagon's unknown secrets? Reply with quote
This seems obvious to the point of absurdity, but you asked. I can't say I've ever 'needed' an umbrella, but I prefer having one when walking in the rain simply because I prefer to be less wet especially if it is cold out. It is just a matter of my own personal comfort. Remarkably similar are the reason I wear clothes, have a house, have a car, etc... The umbrella I usually carry in inclement weather also has a nice wooden knob for a handle and could serve double duty as a nice bludgeon if necessary.
I'm curious, what was the motivation for your post?
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed Oct 29, 2025 4:59 pm    Post subject: Re: Did I just discover one of Vanagon's unknown secrets? Reply with quote
?Waldo? wrote:
This is remarkably similar to the reason I wear clothes
And we all thank you.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Abscate
Abscate is offline
PostPosted: Wed Oct 29, 2025 11:37 pm    Post subject: Re: Did I just discover one of Vanagon's unknown secrets? Reply with quote
Anyone walking in UV index >5
Ahwahnee
Ahwahnee is offline
PostPosted: Thu Oct 30, 2025 9:58 am    Post subject: Re: Did I just discover one of Vanagon's unknown secrets? Reply with quote
jimf909 wrote:
The secret is that you can stow a full size umbrella in the door in that duct. ...
It's where I keep my spare wipers blades. It rains so seldom that I don't replace them until they're really needed.
do.dah
do.dah is offline
PostPosted: Thu Oct 30, 2025 10:56 am    Post subject: Re: Did I just discover one of Vanagon's unknown secrets? Reply with quote
OR,, the umbrella slides forward into the 'A' pillar, especially if the umbrella has a long(ish) point.
-bobby
vanis13
vanis13 is offline
PostPosted: Thu Oct 30, 2025 11:28 am    Post subject: Re: Did I just discover one of Vanagon's unknown secrets? Reply with quote
-bobby
on mine, there is a plate that covers the A pillar. the speaker wires go through the plate.
the B pillar I have made a plate to cover it to avoid the umbrella sliding back.
.. I wonder what good storage could be in the B pillar through that hole!
vanis13
vanis13 is offline
PostPosted: Thu Oct 30, 2025 11:29 am    Post subject: Re: Did I just discover one of Vanagon's unknown secrets? Reply with quote
That is a GREAT idea on the blades!!!! Being from rarely-rainy NM my needs are similar to yours.
jakekoebrich
PostPosted: Thu Oct 30, 2025 11:39 am    Post subject: Re: Did I just discover one of Vanagon's unknown secrets? Reply with quote
Wink
Ok, that's the answer I was hoping for. I knew about the passthru on the passenger side but I didn't know about the low pressure zones in the door jams and this drivers vent allows internal air out of the van. Good to know. Thanks!
dhaavers
dhaavers is offline
PostPosted: Thu Oct 30, 2025 11:50 am    Post subject: Re: Did I just discover one of Vanagon's unknown secrets? Reply with quote
Remember, everybody’s at a different point on the sarcasm scale…no harm, no foul. Cool
- Dave
"The WonderVan"
mrinnovation1
PostPosted: Thu Oct 30, 2025 1:08 pm    Post subject: Re: Did I just discover one of Vanagon's unknown secrets? Reply with quote
BTW, where's the umbrella on an umbrella stroller?
jimf909
jimf909 is offline
PostPosted: Thu Oct 30, 2025 2:02 pm    Post subject: Re: Did I just discover one of Vanagon's unknown secrets? Reply with quote
Best idea of the month.
- Jim
Butcher wrote:
Guilty as charged.
E1
E1 is offline
PostPosted: Thu Oct 30, 2025 2:36 pm    Post subject: Re: Did I just discover one of Vanagon's unknown secrets? Reply with quote
I’ve personally seen Julie Andrews’ Westy, so Jim’s is not a new idea.
MartinJS
MartinJS is offline
PostPosted: Thu Oct 30, 2025 5:54 pm    Post subject: Re: Did I just discover one of Vanagon's unknown secrets? Reply with quote
Perfect place for a pair of hiking poles...
Andymon
Andymon is offline
PostPosted: Fri Oct 31, 2025 9:27 am    Post subject: Re: Did I just discover one of Vanagon's unknown secrets? Reply with quote
I keep a zombie machete in there.....just in case!!
"Blanch" '85 Westy
"Too many freaks and not enough circuses".
