raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23461 Location: Oklahoma City
Posted: Sun Nov 02, 2025 12:16 pm Post subject: Re: Annealing a vw engine case? |
| BFB wrote: |
| bumping because its interesting |
Not sure what it might do for an engine case but annealing does a lot for aluminum cylinder heads.
Over many miles and tens of thousands of expansion and contraction cycles, the metal gets work hardened, especially in areas where it is already under mechanical tension like around the valve seats. This is why over long miles and heat cycles and a fair bit of overheating we get valve seats falling out on type 4s that had 0.006" of interference fit.
One crappie method if you have enough meat in the head is to cut for seats that are grossly oversized on the OD to try to get to metal that has some elasticity left.
The better method and still is in machine shops that specialize in heads...especially racing shops for Detroit metal.....is to load the heads into the oven after all ferrous metal has been removed and heat them for between 1-3 hours depending on alloy. Typically they then get put into a bin full of insulating material like vermicullite to cool down slowly. The last set ai had done were done this way.
This restores elasticity to the whole casting. Without doing this, installing valve seats that will stay in requires higher interference fit.....which accelerates the work hardening done by heat cycling so the next lifespan is shorter.
Now.....if the case because of pounding over high miles get work hardening to the case bores....I could see annealing helping with that but it will still need align bore. Ray |
oprn Samba Member
Joined: November 13, 2016 Posts: 15203 Location: Western Canada
Posted: Mon Nov 03, 2025 5:17 am Post subject: Re: Annealing a vw engine case? |
What Gene Burg described that VW did to cases back then was absolutely true except for the annealing. I have no way to confirm or deny that. Yes the original engine in our '69 Bus only lasted 34K miles but the re-machined by VW case went another 80K under our ownership in the same car without any further issues or rebuilding. I would definitely say it was as good as new when they were finished with it.
As for annealing softening up the case material, I cannot see that as being a good thing in the bearing saddle area. They are too soft to start with as far as I am concerned!
If modern machine shops can only get few thousand miles out of an align bore like Gene Burg suggested then they are doing something wrong! _________________ Our cars get old, we get old but driving an old VW never gets old! |
Posted: Mon Nov 03, 2025 6:04 am Post subject: Re: Annealing a vw engine case? |
| oprn wrote: |
If modern machine shops can only get few thousand miles out of an align bore like Gene Burg suggested then they are doing something wrong! |
Not saying I know anything from experience....but just searching on annealing magnesium and its alloys.....and someone already mentioned this in this thread.....it does reset the crystalline structure, make it less brittle and less prone to stress cracking.
Remember that magnesium as it ages alone even before heat cycling, becomes brittle. Before they changed the type one casting and added that big block of metal over behind #3 on the flywheel side....used to commonly crack.
So yes....I guess if they were going to make a business out of recycling engine cases to the point where they could make a profit and offer a warranty, I could see them annealing them. Also, annealing them in a factory setting set up for them would not be a big deal. It would probably be the least expensive part of refurbishing a case.
I could see cases coming out of the cleaning vat....passing through a station where a couple of dudes with proper tools were quickly pulling all of the steel studs and dowels out....throw all the cases on a rolling rack like sides of bacon and wheel them into batch oven room where several hundred cases at a time can be rolled in....maybe a 10' x 20' room. Those are even cheap to build. I have worked in numerous plants that had those for annealing plastics and sheet metal.
Close the door and set the furnace that heats the room. About 12 hours later when the heating and cool down is done....you wheel out racks of annealed cases. You can even do that as a batch even before sorting them to figure out which ones are really rebuildable.
Ray |
oprn Samba Member
Posted: Mon Nov 03, 2025 10:24 am Post subject: Re: Annealing a vw engine case? |
As for a factory fix, the case we sent in for repair all those years ago never left Canada. As I recall it was post marked Quebec. I highly doubt VW had an engine manufacturing facility there! _________________ Our cars get old, we get old but driving an old VW never gets old! |
Posted: Mon Nov 03, 2025 10:51 am Post subject: Re: Annealing a vw engine case? |
| oprn wrote: |
| As for a factory fix, the case we sent in for repair all those years ago never left Canada. As I recall it was post marked Quebec. I highly doubt VW had an engine manufacturing facility there! |
Depending on where you read....vw did not have a rebuild plant in Canada in the 1970s but they did in the 1980s. Various sources say they manufactured for a decade-ish....quality ranged from just fine to crap (dang....kinda like GEX? )
Here is a thread
https://www.thesamba.com/vw/forum/viewtopic.php?t=340283
Ray |
BFB Samba Member
Posted: Mon Nov 03, 2025 11:02 am Post subject: Re: Annealing a vw engine case? |
| raygreenwood wrote: |
| oprn wrote: |
Here is a thread
Ray |
well really, what'd they expect from Canadians ?? hahaha just kidding Oprn, I couldn't let the opportunity pass me by. all in good fun, but feel free to return fire! _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
Most experts aren't. |
Nitramrebrab72 Samba Member
Joined: November 10, 2018 Posts: 990 Location: France
Posted: Mon Nov 03, 2025 11:15 am Post subject: Re: Annealing a vw engine case? |
There are different annealing processes, some done cold some for coating a surface some for changing molecular structure of certain metals, some for making samurai swords. The one I think you mean is the following process. With a special hardened forged high tensile strength steel bar the size of the bearing holders fit the bar in place of the bearings holders, clamp the case together with external claps above the bearing holders.
Heat to over 700°f and cool the case repeat the process until the bearings holders are pulled and pushed into line. It realies on different speeds of contraction and different volumes of different types of expanded metals .
It is an extremely high level metal working stroke engineering process that only few know of and even fewer can get right that needs to use the right temperature and right cooling process for good results. |
modok Samba Member
Joined: October 30, 2009 Posts: 27754 Location: Colorado Springs
Posted: Mon Nov 03, 2025 10:46 pm Post subject: Re: Annealing a vw engine case? |
There is no right answer if it's a good idea or not without knowing what is wrong with the particular engine case.
If it was welded or has suffered a BURNED UP main bearing that's caused it to warp in a unhealthy way..... then it becomes necessary to stress relieve, to relax the ABNORMAL stress in it, so it doesn't warp later in service.
Becase otherwise it absolutely will. It will stress relieve itself over the course of the next few years and then be all out of shape again, and we don't have time to wait 5 years before fixing each engine case.....
or do we?
But relieving ALL stresses is not ALWAYS best.
Half of why the concept of "seasoned" parts is because castings do shift a little after being subjected to normal stresses of being bolted together and and run and it's better to leave those normal residual stresses alone.
One thing I do see as a pattern is guys who prefer to bake every engine block ARE DOING a full re-manufacturing type process. Which sometimes makes sense, especially if the aim is to build many engines exactly the same, using all the same machining processes and setups and parts, RATHER THAN individually inspecting each engine case to see specifically what's wrong with it.
The mass production way is not how I prefer to do things or was trained to do things, but I understand the utility.
For instance you can reface a valve as quick as you can check if it's bent, so your just wasting time checking the valve to see if it's bent, but, you know what.....? You can't deny more energy efficient to not fix what ain't broke!
And I like measuring things anyway. It's interesting. Working in a factory doing the same thing over and over isn't as interesting to me.
Quite a difference in philosophy between the two far ends of the spectrum of remanufacturing and individual repair.
But anyway, for what most of us do around here with the VWs
If the saddles aren't warped and you didn't weld on it, then, it's good to go. And if it is warped and you welded on it, may be better to just call it dead, or, let somebody else fix it, like. send it to gex  |
oprn Samba Member
Posted: Tue Nov 04, 2025 6:53 am Post subject: Re: Annealing a vw engine case? |
| BFB wrote: |
| oprn wrote: |
Here is a thread
Ray |
well really, what'd they expect from Canadians ?? hahaha just kidding Oprn, I couldn't let the opportunity pass me by. all in good fun, but feel free to return fire! |
My only experience with them was that one case align bore back about 1972 and the quality was excellent! _________________ Our cars get old, we get old but driving an old VW never gets old! |
Posted: Tue Nov 04, 2025 10:37 am Post subject: Re: Annealing a vw engine case? |
| oprn wrote: |
| BFB wrote: |
| oprn wrote: |
Here is a thread
Ray |
My only experience with them was that one case align bore back about 1972 and the quality was excellent! |
Personally I have heard nothing but good from the few people I personally know who have had dealer supplied total rebuilds from the recycle program.
Bear in mind though, from what I understand these engines were not supposed to really be "brand new" with "0" miles...same as a new case, new heads etc. They were (so I have been told) warranty replacements.
So if you had a VW you bought new and lets say it had 40k miles on it and had a catastrophic issue that the dealer was willing to furnish a new engine at a pro-rated or partial cost. If you got another 60-70k miles out of it with perfect running before it succumbed to an age related issue with the case....most people would be more than happy with that and think they got their moneys worth.
As both modok and nitramrebrab72 noted....there are different reasons for annealing.
From back on page 1 in 2014 when Mr. Duncan posted the Gene Berg excerpt about what VW does to "refurbish" a case....in essence what he is describing there...is exactly what I described...annealing the case.
But he went further and stated what Nitramrebrab72 was pointing out....that during the annealing process they werev ALSO "STRAIGHTENING" the case with alignment bars bolted in.
He also stated that this would be far more costly than a new case. Having been inside of thousands of factory with every sort of jig fixtures, semi-automation to full automation and methods.....I am not so sure it would be that expensive. I am also not all that sure that they need to remachine every single major case orifice.
If its about generally straightening the case AND recrystallizing the magnesium alloy to prevent cracking....thats a little simpler. It becomes all about the sorting and all about the fixturing and jigs.
This is how I imagine it could go and be very eqconomical.....
The intake process on a line like that would be ppallets of returned engine cores. I would say they probably had a punch list of baseline requirements for cases to be pre-sorted at dealerships.
No obvisously broken cases
No burned cases
No cases that were under water with massive external rust and corrosion
Maybe even no locked up engines.
Maybe no complete engines...all sheet metal and systems get stripped off. Just short and long blocks.
From there onward, its just long and short blocks arriving at the rebuild plant ....when they get to the rebuild plant they get hot tanked....a couple of guys zapping them apart with air tools an tables and putting the big parts in bins. All small hardware...nuts...bolts...gets thrown in the recycle bin. Oil pumps...recycle bin.
Anything with visible cracks or more than scratches on the case parting line that 30 seconds on a lapping plate cannot take away goes in the recyle bin.
From there, they could have a whole pile of alignment bars. It would take a couple of mintes per case to pull all studs and pins. A couple more to slap the alignment bars in and torque the bolts. It all goes to the annealing ovens.
When they come out, ....each case half gets brushed with dye on the parting line...then slapped onto a lapping plate.
Have you ever seen one of those? I watched a guy at an old private VW shop in Norman OK do this to a VW case. He dyed the parting line....had a 3' x 4' carbide lapping plate on a granite slab. He did about 10-15 oval shaped passes at a time flipping the case 180* once. Then would lift it up and inspect how much dye was lapped off and where the high and low spots were if any. Set it aside and do the other half. He might make one more pass on each. It took under 5 minutes.
He said it takes off about 0.003" to 0.005" total. Very smooth, He ran a deburring tool around the perimeter. Then he threw it in the parts washer and then set it up for align bore.
If just doing this....just a few thousandths off...I would not see where the oil pump bore or the main or pulley seal bore seal bore would need to be re-bored. Just the crank and the cam bores.
Yes....a line like this may have a handful of guys working it but each operation with jigs fixtures and tools would be pretty fast. Ray |
