1980 Vanagon won't pass California smog
Nitramrebrab72
Nitramrebrab72 is offline
PostPosted: Tue Nov 04, 2025 1:20 am    Post subject: Re: 1980 Vanagon won't pass California smog Reply with quote
LordHuron95 wrote:
Nitramrebrab72 wrote:
There is a little trick to adjust and check the mixture without going to the test center with a high impedance voltmeter connected in parallel with the lamda sensor.
If the voltage at the lamda sensor is stuck above or fluctuates above 0.5 volts it needs leaning out , stuck under 0.5 volts it needs enrichment. It should stay/fluctuate around the 0.5 volts
So had a probe in the O2 sensor plug to the harness, other ground to the body. Was a relatively stable .54 volts. This is a cold, running engine.
0.54 is almost bang on(it would of been better to know on a hot engine anyway)and as you only fail on CO it's sounds like the CAT is tarred up with oil after the rebuild and/or you have been doing a lot of toodling/slow city driving, drive it like you stole it for a while keeping the load and revs up for 15/20 mins and keep driving it hard until and all the way to the test center and go from there..Like this testimonial from a similar situation as yours with high CO fail only.
"I had a similar experience with my 98 Mazda 626, slightly lean Lambda with too much CO in the exhaust. One thing that happens occasionally is that crud ( carbon, sulfur, etc. ) builds up in the catalytic converter ( and on the spark plugs ) especially if you do a lot of low RPM City driving. What I did was to take a drive in low gear for about 10 or 15 minutes and kept the RPM above 3500 for that time. High RPM driving creates higher combustion temps and higher temp exhaust which will burn that crud out of the system and you may be able to pass the emissions test after that. It happened to me two years in a row and I used this solution both times to pass the test."
do.dah
do.dah is offline
PostPosted: Tue Nov 04, 2025 9:15 am    Post subject: Re: 1980 Vanagon won't pass California smog Reply with quote
I run high content zinc, engine oil, which is bad for CATs.
While my engine doesn't burn oil, about once a year, as a possible preventive maintenance deal, I remove my o2 and spray this stuff into the cat.
https://www.amazon.com/dp/B07DHB2Z88?ref=ppx_yo2ov_dt_b_fed_asin_title
When I had my engine rebuilt, my engine builder wanted me to use a very high zinc break-in oil.
I asked him about using the spray-in cat cleaner after running the break-in oil, and he was ambivalent about it, but did say it couldn't hurt?
I have no idea if the stuff actually works.
I do have an after-market cat with about 40k miles on it, and last time I took it to my mechanic to have him double check the health of my van, one of the things he does, is stick a sniffer into the tailpipe, and it all checked out fine.
It would be kinda interesting if you tried some kind've spray-in cat cleaner and reported back if it made any kind've difference?
LordHuron95
LordHuron95 is offline
PostPosted: Tue Nov 04, 2025 12:46 pm    Post subject: Re: 1980 Vanagon won't pass California smog Reply with quote
Just talked to a local VW mechanic. Showed him my emission results and talked about changes I made between each one.
He said he feels my CAT is okay, not new but doesnt think it is the issue. He pointed towards the AFM, specifically the spring. He mentioned turning the CO screw 2 or 3 full turns out, and if that wasnt enough, to tighten the spring a couple notches.
Gonna take a look at things and will report moving forward.
Never swing a mean loop. Never do dirt to man nor animal.
-1980 Vanagon Westy
Xevin Premium Member
Xevin is offline
PostPosted: Tue Nov 04, 2025 3:25 pm    Post subject: Re: 1980 Vanagon won't pass California smog Reply with quote
How will you determine if 2 turns out is enough?
Keep on Busin'
67rustavenger wrote:
Clatter wrote:
skills@eurocarsplus wrote:
SGKent wrote:
E1
E1 is offline
PostPosted: Tue Nov 04, 2025 3:34 pm    Post subject: Re: 1980 Vanagon won't pass California smog Reply with quote
We all do things differently, but:
1). Premium gas will burn cleaner
2). Octane booster helps, pour it in before filling tank and drive a few miles
3). To see if the cat is working, buy an infrared temp gauge, get engine up to full temp, let idle, measure cat temp at inlet and outlet pipes on the cat itself
(I’ve tested a dozen times this year, and another dozen before on bad cats)
4). Take several readings and average them, temps will jump around a little, outlet should be hotter than inlet by about 100-150 degrees F
5). If equal temps after several test repeats on different drives, cat is shot
6). Check a spark plug before and after adjusting the AFM screw, and KNOW where you started!
Good Luck.
If ever twice as rich, we’re gettin’ a double-wide
’84 “Westfailure”/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans
The caveman’s first question to the headhunter: “Hey, you got any coffee?”
LordHuron95
PostPosted: Tue Nov 04, 2025 4:56 pm    Post subject: Re: 1980 Vanagon won't pass California smog Reply with quote
That's the thing, I wont...
He sounded pretty sure but without having it actively hooked up to an emissions tester, I wont know if its dialed in, rich or lean. Main reason I've been so hesitant to mess with the AFM thus far. My smog guy didnt say no to hooking it up and actively turning it, but wasnt jumping at the opportunity either.
-1980 Vanagon Westy
Nitramrebrab72
PostPosted: Tue Nov 04, 2025 10:42 pm    Post subject: Re: 1980 Vanagon won't pass California smog Reply with quote
I thought the same and have been telling you something similar on the this topic and your other one since the begining.
Until I saw you have 0.54 volts at the Lambda sensor(almost perfect mixture) I thought it was the right thing to do.... Now I have a small doubt and believe you have a tarred up CAT as CO only failure on a smog test is the number symptom from an oiled up cat...
Something that can be gotten rid of with some more intense driving maybe with some cat cleaner additive .
A combination of extra oil consumption after the rebuild and soft driving probably brought this on.
Abscate
Abscate is offline
PostPosted: Wed Nov 05, 2025 12:41 pm    Post subject: Re: 1980 Vanagon won't pass California smog Reply with quote
Thats great. Now go do some real diagnostics instead of 'feeling'
(Thats aimed at the mechanic, not you)
LordHuron95
PostPosted: Wed Nov 05, 2025 5:36 pm    Post subject: Re: 1980 Vanagon won't pass California smog Reply with quote
Yeah, based on dropping a valve seat and continuously driving it a good deal afterwards. My guess was it got a good deal of oil and unburnt fuel in there. I had the SAE 30 oil in and revved the engine for about 20-30 minutes at like 2000-3000 rpms. Then changed the oil and filter, that is what is in the van now. High zinc and thick oil. Driving now, I live in a flat valley but when I drove it yesterday, I stayed in 2nd and 3rd the whole time, revving the engine in high rpms. No glowing CAT but it currently has CAT cleaner in it. That went on for about 25 minutes.
-1980 Vanagon Westy
E1
E1 is offline
PostPosted: Wed Nov 05, 2025 6:02 pm    Post subject: Re: 1980 Vanagon won't pass California smog Reply with quote
Measure the cat temps to find gold.
Or at least to discount a bad cat.
If you meant the van was stationary at 2-3,000 rpm for 20 to 30 minutes, know that that’s *really hard* on the engine when freewheeling it.
If you were driving, apologies, the above is how it read to me.
LordHuron95
PostPosted: Wed Nov 05, 2025 6:18 pm    Post subject: Re: 1980 Vanagon won't pass California smog Reply with quote
Yeah, gonna grab my buddy’s thermometer to do just that. If he can find it.
I had it out of gear and doing that. It’s what my engine builder recommended.
-1980 Vanagon Westy
E1
E1 is offline
PostPosted: Wed Nov 05, 2025 6:21 pm    Post subject: Re: 1980 Vanagon won't pass California smog Reply with quote
An infrared is invaluable, and cheap.
Engine builder is dead wrong, Sorry.
Nitramrebrab72
PostPosted: Thu Nov 06, 2025 3:05 am    Post subject: Re: 1980 Vanagon won't pass California smog Reply with quote
High revving out of gear is not good for both a worn in engine and more so for an engine breaking in ... You need compression load on the rings, when breaking in an engine, that is staying in the high bhp part of the power curve,(through fast accelerations or climbing hills) this increases the pressure behind the piston rings as much as possible pushing them hard against the sharp edges of the cylinders honing scratches before they become blunt and are no longer able to shape the rings to the exact form of the cylinder wall something needed for a good ring seal...
As for cleaning the cat you need exhaust heat and exhaust volume. So up in the revs and load a combination of fast accelerations, and/or up a hill and/or a long motorway drive at least 55mph with accelerations upto 65mph for a sustained period of time.
Abscate
Abscate is offline
PostPosted: Thu Nov 06, 2025 3:11 am    Post subject: Re: 1980 Vanagon won't pass California smog Reply with quote
There is a simple reason cheap cats are 1/4 the price of OEM cats - 1/8 as much of the expensive material. OEM cats last 20-25 years - well, do the math...
I plugged up two cats on an X83 and had one look at the Magnaflow replacements and sent them back. OEM was a 1500 sting but went in like butter.
LordHuron95
PostPosted: Fri Nov 07, 2025 1:54 pm    Post subject: Re: 1980 Vanagon won't pass California smog Reply with quote
Tested fuel pressure just to knock that out as an issue.
With pump running, 38psi
Immediately after letting off, it drops to ~35-36 and creeps down.
After ~20 minutes it still read 26 psi.
I say this instead of the CAT temps because for some reason it isn’t starting. It wants to but refuses. All I did since last driving it was compression testing each cylinder. I have triple checked plugs, wires, vacuum. I added fuel to the tank. Not sure what the issue is right now...
-1980 Vanagon Westy
E1
E1 is offline
PostPosted: Fri Nov 07, 2025 3:03 pm    Post subject: Re: 1980 Vanagon won't pass California smog Reply with quote
Did you pull the fuel pump relay or unbolt the pump ground (and pull and ground the coil wire) to do the test?
If you didn’t, it’s probably massively flooded. A friend once did the same thing ( Wink ) — Once.
See if the dipstick smells like gas. If it does, pull and clean all the spark plugs and air the crankcase out overnight.
It is wise to do an oil change if it does smell gassy, if not the filter, too (or at least empty the oil from it if it’s fairly new).
LordHuron95
PostPosted: Fri Nov 07, 2025 4:27 pm    Post subject: Re: 1980 Vanagon won't pass California smog Reply with quote
No and no. All I did unplug were the injector plugs (not lines) and the coil to distributor wire. Hopefully it was a simple fluke as you’re saying Laughing
-1980 Vanagon Westy
LordHuron95
PostPosted: Thu Nov 13, 2025 10:16 am    Post subject: Re: 1980 Vanagon won't pass California smog Reply with quote
Update: after confirming fuel pressure is good, the engine wouldnt start. Would turn over, crank spark inconsistently but not start. Had planned on checking the temp on the cat but obviously cant do that without it running.
I took the plugs out and noticed they were all pretty wet. Left them out for the fuel to evaporate for the weekend. Came back, popped em back in. Engine started but died, then returned to not starting.
Compression test because why not. All 4 cylinders were roughly 125-130. Okay.
Spark plugs out again. I wiped them down as they all were wet and black again. Re-gapped them as well. One was particularly open. Also lightly sanded their points to clean off the carbon. Friend mentions that on such new everything, a FI engine shouldn't have such carbon buildup. Says it points to running extremely rich, which we know has been a possibility.
As an aside, there is a fresh new puddle of oil under the engine. No idea why considering I've only been turning the engine over and not starting it.
(Is everyone on here in on the prank and I dont actually get to drive this thing ever? Confused )
-1980 Vanagon Westy
LordHuron95
PostPosted: Thu Nov 13, 2025 2:24 pm    Post subject: Re: 1980 Vanagon won't pass California smog Reply with quote
Just tested the injectors. All read 2.6 ohms. Book says 2-3 is spec so that's good.
I tested each one by building pressure with the afm and then with a battery hooked to the injector terminals, manually firing it. I think they shot okay. Went through them all again just holding them up and building pressure, didnt see any dripping/leaking.
-1980 Vanagon Westy
MarkWard
MarkWard is offline
PostPosted: Thu Nov 13, 2025 3:15 pm    Post subject: Re: 1980 Vanagon won't pass California smog Reply with quote
Probably time to investigate the 5th injector or cold start valve operation.
Page 3 of 6
