E1 Samba Member
Joined: January 21, 2013 Posts: 8765 Location: Westfalia, Earth
Posted: Sat Aug 16, 2025 1:29 pm Post subject: Re: Blown head gasket or something else? |
| my_vw_sucks wrote: |
| Crooked Designer wrote: |
Simple test on the blue cap. I have never done this as by the time I became aware of this video I already moved on to an aluminum expansion tank, but seems pretty simple.
Ran the test and have a dying trumpet and can easily drink a coke through the cap (no closed b-hole on this one). Back to being optimistic. That new cap needs to hurry up. |
No Coke, Pepsi.
Awesome. The suck test shows the *much-more* important flaw, not holding 1 bar. Fingers crossed.
FWIW you should always carry another spare (we have like three ). I’ve only been getting Meyles which are fine, but Blaus seemed a little more reliable.
Regardless, hopes and odds high that this is all it was! _________________ If ever twice as rich, we’re gettin’ a double-wide
’84 “Westfailure”/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans
The caveman’s first question to the headhunter: “Hey, you got any coffee?” |
?Waldo? Samba Member
Joined: February 22, 2006 Posts: 10135 Location: Where?
Posted: Sat Aug 16, 2025 2:24 pm Post subject: Re: Blown head gasket or something else? |
| My first thought was maybe blown head-gasket pressurizing the cooling system. But coolant is very, very clean. Checked the oil and that too is clean. No signs of milkshake. |
This sort of comment regarding head gaskets is very common but demonstrates a misunderstanding about the function of head gaskets in most engines along with a misunderstanding of how they fail.
The different symptoms of head gasket failure are not typically cumulative. In other words, you typically get only ONE symptom, e.g. ONLY exhaust gases in the coolant, OR ONLY oil in the coolant, OR ONLY coolant in the oil, OR ONLY coolant leaking to the exterior of the engine, OR ONLY oil leaking to the exterior of the engine. Sometimes severe overheating or some other dramatic event can combine more than one symptom, but those cases are rare.
In other words, if you have a symptom that indicates that exhaust gases are getting into the coolant, that could indicate a blown head gasket. The lack of milkshake in the sump or lack of oil in the coolant reservoir in that situation is completely irrelevant. The lack of other symptoms cannot be taken as any sort of indication that the head gasket is not blown.
The Vanagon 'head gaskets' are also quite unique and comprised of individual orings/gaskets between the individual cylinders, the head, the sump and large rubber gaskets between the block and the heads. Those again fail in individual ways and have individual symptoms. Failure of the orings at the base of the cylinders will allow coolant into the sump creating milkshake in the oil. Failure of the large rubber gaskets will allow coolant to leak to the exterior of the engine. Failure of the fire rings between the head and cylinders will allow combustion gases into the coolant. Those symptoms are individual to the particular failure mode and a lack of another symptom from a different failure mode does not in any way indicate that the 'head gaskets' have not failed in the manner that the single symptom indicates.
I'm not trying to say your head gasket has failed or has not failed. Just giving information that might help you perform your due diligence to determine that for yourself. |
my_vw_sucks Samba Member
Posted: Wed Nov 05, 2025 10:06 pm Post subject: Re: Blown head gasket or something else? |
I've been crazy busy with work, but finally got around to replacing my expansion tank cap. After driving a bit the coolant that had been forced to the resivoir migrated back into the system totally emptying it. With the van warm and the front parked on ramps on a slight uphill grade, I carefully cracked the bleeder valve on the radiator. Only air escaped. I topped up the radiator using a thin hose and funnel into the bleeder vavle opening. Once full I closed it up, topped up the resivoir, and took a quick test drive. When I got back to my house I checked the resivoir level and it had stayed steady. I cracked the radiator bleeder valve again and coolant flowed out.
I've been driving it for the last week and everything looks all good. The only thing I've noticed is that the radiator fan comes on for a very short period on start up. I don't recall if it always did this or not.
Anyways thanks for the help! On to the next project; rebuilding the motor in my 74 2002tii. This time the head gasket actually is bad (and no there's isn't any oil in the coolant...).
Franklinstower Samba Member
Posted: Wed Nov 05, 2025 11:00 pm Post subject: Re: Blown head gasket or something else? |
'74tii with '72 bumpers? Or gray market?
Chamonix White?
Love it! _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug
YITB |
Posted: Mon Nov 10, 2025 9:09 pm Post subject: Re: Blown head gasket or something else? |
| Franklinstower wrote: |
Chamonix White?
Love it! |
First thing I did was ditch the diving boards. Color is Sahara. |
Posted: Mon Dec 08, 2025 9:34 am Post subject: Re: Blown head gasket or something else? |
The cap unfortunately wasn't the fix in my case. Around town everything was fine, but on freeway trips the reservoir still overflows. I tested the coolant and there are combustion gasses present. Looks like it's cylinder o-rings.
At this point I'm trying to decide if it makes sense to pull the motor or try and do the job with the engine in place. I'm thinking pulling the motor is the way to go. I can chase down the random oil leaks while it's out.
I'm a bit disappointed with the Gowesty 2.3L rebuild installed by the PO. It only has about 55K on the clock. As I noted it leaks a bit of oil, but more concerning it burns a ton of it. A trip from the Bay Area to Tahoe and back (400-500 miles) is a minimum of a quart of oil. Now the cylinder o-rings are toast! Does it make sense to look into an engine swap? I know this is thousands vs hundreds $, but it would be nice to have something with a bit more power. |
Posted: Mon Dec 08, 2025 9:58 am Post subject: Re: Blown head gasket or something else? |
The WBX engine has a reputation for quickly burning off any oil added above the midpoint of the range on the dipstick.
Assuming you are only filling to midway between the marks, then your oil consumption is very excessive. 1qt per 1,000 miles is what I consider max oil consumption for a reasonably healthy engine and you say you are double that consumption.
Engine swap vs. rebuild is not thousands vs. hundreds, it's ten+ thousand vs. a few thousand.
Considering your username, I wonder why you are considering either vs. selling and no longer having a vehicle that sucks. _________________ I am a high-functioning autistic into VW diesels and Vanagons along with other things that are unrelated to this site. |
E1 Samba Member
Posted: Mon Dec 08, 2025 10:07 am Post subject: Re: Blown head gasket or something else? |
Sorry to read all this. Dang.
Before giving up on this engine you might try running an oil level just above the bottom of the stick. I have repeatedly observed that Wasserboxer engines use a lot more oil the closer the level gets towards the top notch, not to mention it at least appears that high levels clog the crankcase vent aka oil breather.
The latter can be easily shown by finding the small vent on the breather — either a tiny hole under the top lip if original, or a nearly-imperceptible slot atop the breather if an aftermarket breather.
In either style, you’ll see a collection of oiled dirt where it vents and notice it may not be venting at all. I use an excess amount of Brakekleen to spray off the excess, and do not rub a rag on it for fear of forcing the oil and dust composite in there.
On factory vents, once sprayed, a little prod with a paper clip may help clear the hole. The best way to know it’s clean is removing the tower, soak it with a mild solvent like mineral spirits awhile (I once ruined one with a five-minute soak of carb cleaner, don’t be me!), and cupping your hand to seal the base while blowing into the large exit port of the tower. If original you’ll hear a slight hiss, if aftermarket it sounds more like a wheeze. If clogged, you’ll immediately know it is.
It helps or is at least wise to have a new o-ring available when re-installing the breather. While it probably won’t leak when re-using the old seal, now’s a good time to replace it anyway. The old one turns to almost a hard “plastic” over time and they can and do leak and make a mess of everything nearby.
Or do you see a physical leak, such as above the exhaust where the engine and trans bolt together, or anywhere else? A clogged vent can over-pressurize the engine a bit — particularly when vacuum is at max down a long, off-throttle grade — and oil can or will pass through the point of least resistance (like the mainseal).
I had an oil leak for a couple years, and had the mainseal swapped a year ago July when the trans was out for an unrelated issue. 500 or so miles later, the leak returned.
Last summer, I drilled and installed a threaded nipple at the base of the tower, to a two-foot by 1/2” clear hose with a cheap, clear fuel filter on the end, thinking I might see misted oil in either — which I didn’t.
Regardless, it seems to help with venting excess pressure and my second leak slowed significantly — but didn’t fully stop until adding a quart of Lucas oil stop leak (which made no difference on the initial, larger leak). I’ve not seen any oil loss whatsoever in well over 1,000 miles since — and while I’d like to think my “genius” vent was the ticket, it’s possibly just the Lucas or — far less likely — the mainseal expanded just enough in about 8,000 miles (estimate, odo is out) to self-seal.
Not saying your issue is related to the crankcase vent/breather, but there’s a reference point. The most-obvious sign of a clogged breather is if off-throttle down a long grade — ESPECIALLY if oil level is high — then once back on throttle it’ll want to stall and you’ll likely see a UGE cloud of blue oil smoke in the mirror that sure causes mass concern… though it’s really just a sign that vacuum is sucking in excess oil into the intake from a non-venting breather.
Not a good condition to ignore though, as that can foul your air-fuel meter if ignored.
One factor I DO NOT KNOW is if these engines were intentionally designed to use excess oil in normal operation, and therefore running less oil is denying that — and maybe, possibly increasing upper-engine wear slightly.
But overall I kinda doubt that, thinking it would have been documented before now if only to reduce initial engine warranty claims. So I err in favor of proper crankcase pressure relief instead. _________________ If ever twice as rich, we’re gettin’ a double-wide
Posted: Mon Dec 08, 2025 11:26 am Post subject: Re: Blown head gasket or something else? |
| ?Waldo? wrote: |
| Considering your username, I wonder why you are considering either vs. selling and no longer having a vehicle that sucks. |
Hell no! I've got a whole list of vehicles that suck beside this one; a few BMWs (one previously pictured), Porsche, Jeep, Lucid, and a mountain bike!!! The only one I'm giving up on is the Porsche, that is getting lemoned in the next few days. Despite sucking, I love each and every one of them. The username started with my 1996 VW GTI that really sucked. Out of frustration in figuring out what was wrong with it I used that when signing up for vwvortex. It has stuck around since May 2004 (the username not the car). The GTI was replaced shortly thereafter with a R32.
I do try to keep the oil between the bottom of the and midway on the dipstick. It seems to be fine around town. The engine really doesn't like the highway, where I think most of the consumption happens. I switched from Gowesty's recommended 10w60 to 20w50 and that has helped a bit, but not much.
The actual oil leaks are pretty minor. I replaced the clutch about a year ago and did the rear main seal while the trans was out. The oil leak is more from the front of the engine (rear of the van). I'm hoping it's the oil heat exchanger seal. It tends to pool on the engine support and leak out the holes in the support. There's really nothing up top, but I'll clean the breather as suggested.
I think pulling the motor is the route I'm going to go. It just seems so much easier than pulling the intake, the exhaust, and everything else while the engine is in the car. It will just make it that much easier out of the car. Plus seeing the bottom of the cylinders will be a lot easier with the engine on its side. I'll spend the hundreds to keep this one limping along.
I'll keep exploring the engine swap and bury my head in the sand on the cost. |
E1 Samba Member
Posted: Mon Dec 08, 2025 11:56 am Post subject: Re: Blown head gasket or something else? |
Per your username, note our van’s nickname in sig — given me by a damned Brit friend who must have never heard of Lucas electronics.
By the way, this same friend’s a lifetime race engineer and confirmed something I’ll try if the gas tests positive like you — and maybe you might before throwing in the rag as well — re-torquing the head.
We’re in similar spots… and may need head gaskets, to be finally determined this week with our gas tester. We would have to hire out a gasket swap to avoid our own install elsewhere but a campsite. Not feelin’ it.
I’ve concluded a pair of gaskets could be three Grand, plus motel time, and that *only* if things go perfectly right, *and* the bottom end is proven sound.
At that point we’re ordering a fresh rebuilt engine, so I have mostly avoided reality on this topic.
Our case could still damned-well be air coming in when cooling, possibly getting stuck in the front heater core while both temp and fan await repair, coming in from the factory plastic coolant tank, or elsewhere.
To be determined…
Best no matter what you do. _________________ If ever twice as rich, we’re gettin’ a double-wide
zerotofifty Samba Member
Posted: Mon Dec 08, 2025 11:59 am Post subject: Re: Blown head gasket or something else? |
My engine loves to have the oil just barely above the low mark, it will stay there for along time, fill it much higher and it consumes the excess. Of course staying at the low mark is a bit nerve wracking. Thus I do check the level fairly frequently, which necessitates a level van to assure accuracy.
I do run a oil pressure gage in drivers line of sight, so that I will detect the engine sucking air in a timely manner if the level were to get too low So far that has not happened. But I like the reassurance that gage gives.
So run her near a bit above the low mark, check level frequently, just in case, as at the low mark you have little margin for a leak. _________________ Sorry About That Chief.
Give Peace a Chance.
Words to live by. |
