hazetguy Samba Member
Joined: April 06, 2001 Posts: 10804 Location: the past
Posted: Tue Feb 07, 2012 12:17 pm Post subject: Re: '63 shift bushing front / M spring issue |
| Dirkdaddy wrote: |
| on my restored '63 and found that the shift bushing housing (whatever its called) must have been changed to a later version as it does not have a M spring slot, only a hole for the shaft. |
the M spring stopped being used in ~1960.
a '63 would use the later style, readily available bushing like seen here http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111701259A |
Tomasz Samba Member
Joined: September 08, 2005 Posts: 1097 Location: in a van down by the river
Posted: Tue Feb 07, 2012 2:40 pm Post subject: Re: '63 shift bushing front / M spring issue |
| Dirkdaddy wrote: |
... I also found it interesting that neither the OEM service manual or the Muir book shows this part or anything with it AFAICSee.
Cheers, DD  |
_________________ '56 - Wolfsburg Kombi (1200)
'74 - Type 181 (1600)
'85 - Westy Mosaik Joker Hightop (1.6 TD)
'87 - 16" Syncro High Top (1.9 TD)
'88 - Westy (EJ25)
'14 - Jetta Sportswagen (2.0 TDI) |
Posted: Tue Feb 28, 2012 8:06 am Post subject: |
well it has been one month since i asked for input on another batch of M springs. i also placed a feeler ad in the classifieds.
while there is certainly some interest and need for these, at this time it is not financially realistic for me to have another batch made.
to everyone who sent a PM or an email: i have your names on a list and will keep that list going.
i will continue to see how much interest in generated in the coming months, and perhaps i can do another run in the summer. |
vwserphguy Samba Member
Joined: April 30, 2009 Posts: 176 Location: Vail Valley
Posted: Tue Feb 28, 2012 7:59 pm Post subject: |
thanks for the update hazetguy on the m-spring.
i continue to have questions about shifting issues on my early 58 bus and am not sure if this relates to the 3 fingered bushing and a good m-spring. i don't have the bushing and my m spring is very worn with two holes in it.
could this explain why i can only find 1st, 2nd, reverse... or 3rd and 4th if I adjust the shifter and lockout plate over. I've been able to manually find all gears when I go under the bus and move the shift rod with my hands so I know the trans is ok. but no luck when the shifter is installed.
I've spent several hours on this and cannot get it. The shift rod looks original and straight. Shifter could be worn at the bottom perhaps? Front trans mount could be the problem? All shift rods are lined up correct and grub screws are lined up tight and secure.
Any suggestions would be appreciated. |
dstefun Samba Member
Joined: February 20, 2002 Posts: 3338 Location: Sacratomato
otis_bartleh Samba Member
Joined: August 19, 2009 Posts: 1153 Location: Burlington, WA
Posted: Tue May 19, 2015 11:09 am Post subject: |
To add to what seems to be an official M spring thread, I just got one of M springs above, and while I don't have her back driving yet, the part appears to be well made. _________________ -Adam
'59 Mango Bus
'69 Bug - Cobalt Blue |
Kiwi1966 Samba Member
Joined: August 18, 2009 Posts: 168 Location: Ohoka New Zealand
Posted: Thu May 21, 2015 4:44 am Post subject: |
I purchased the M clip and the birdie late last year off Evam for our 57 bus,posted to us down on the bottom of the planet New Zealand-- very well made ,fitted perfect and shifter once adjusted correcty shifts very well |
Nifartachi Samba Member
Joined: October 19, 2008 Posts: 222 Location: Wallachia
Posted: Fri Nov 09, 2018 4:04 am Post subject: Re: Early shift rod 'M' guide reproduction |
Please ignore my ignorance... but what's the role of this M spring?
I have a '57 and, apparently, I need one.  |
Suboval Samba Member
Posted: Fri Nov 09, 2018 8:43 am Post subject: Re: Early shift rod 'M' guide reproduction |
| Nifartachi wrote: |
Please see the first page, third post of this Thread. _________________ It all works on paper.
There's two things we learn from history:
1.) History repeats itself.
2.) We don't learn from history. |
Posted: Fri Nov 09, 2018 9:28 am Post subject: |
I presume you are referring to this picture. But I really don't see the point of that M spring, the rod is already hold in place by that early type of bracket.
Here's a better picture, with the rod:
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15458 Location: Casa de Oro, California
Posted: Fri Nov 09, 2018 10:44 am Post subject: Re: Early shift rod 'M' guide reproduction |
| It keeps it from chattering and trying to move on it's own. Think of it as two little people on each side of the hole pushing down with slightly slippery shoes. |
Posted: Fri Nov 09, 2018 11:30 am Post subject: Re: Early shift rod 'M' guide reproduction |
I'll try to live without it. At least until I can find an early bracket.
Does anyone have an early bracket for sale?  |
matthew henricks Samba Member
Joined: January 02, 2002 Posts: 1402 Location: So. Cal
ronjonlasvegas Samba Member
Joined: October 08, 2004 Posts: 966 Location: Las Vegas, NV
Posted: Thu Mar 14, 2024 9:13 am Post subject: Re: Early shift rod 'M' guide reproduction |
| matthew henricks wrote: |
| USA based "M" spring sourced. Thank you. |
There is a new ad for one in the classified section here.
https://www.thesamba.com/vw/classifieds/detail.php?id=2673017 _________________ September 1964 Standard Sunroof walk through SWR/BG original paint. |
Stocknazi Samba Member
Posted: Sun Aug 04, 2024 8:54 am Post subject: Re: '63 shift bushing front / M spring issue |
| hazetguy wrote: |
| Dirkdaddy wrote: |
Is there a known date in production when the M-spring front shifter support plate was replaced with the later style plastic bushing? I don't see it in PR.
My 12/59 has the bent shifter with M-spring support bracket; curious how late the spring was used. _________________ WANTED:
Thomas Jefferson |
Merlin Samba Member
Joined: August 19, 2004 Posts: 2119 Location: South Africa
Posted: Sat Nov 08, 2025 4:59 am Post subject: Re: Early shift rod 'M' guide reproduction |
Hi everyone,
Is anyone supplying the shift rod guide and M spring at present, please?
All the links in the thread are dead, unfortunately.
Thanks. _________________
| iowegian wrote: |
| People who are allowed to have signature lines annoy me. |
Posted: Sat Nov 08, 2025 7:17 am Post subject: Re: Early shift rod 'M' guide reproduction |
Is there a chassis number for when the M-spring ended and the newer polymer bushings started? _________________ WANTED:
Thomas Jefferson |
Lind Samba Member
Joined: November 06, 2000 Posts: 10269 Location: idaho
Posted: Sat Nov 08, 2025 8:10 am Post subject: Re: Early shift rod 'M' guide reproduction |
| Merlin wrote: |
Hi everyone,
Thanks. |
My previous supplier quit making/selling them. I provided an NOS example to another supplier who should reproduce them at some point. I am not sure of the timeline though. _________________ .
Wanted:
Merlin Samba Member
Posted: Sat Nov 08, 2025 9:04 am Post subject: Re: Early shift rod 'M' guide reproduction |
Thank you, gents.
It seems that a few suppliers are now stocking them. I'm not sure who the manufacturer is.
I'm placing my order with BusOK.  _________________
| iowegian wrote: |
