Vanagon syncro Trans skid plate?
swissarmychainsaw
swissarmychainsaw is offline
PostPosted: Sat Nov 08, 2025 7:00 am    Post subject: Vanagon syncro Trans skid plate? Reply with quote
I have a syncro and I'll be off roading with it.
Did syncros have a stock bash plate for the engine? I have the bars that run front to back, with only some cross-over plates under the motor. Non for the trans.
I was going to get some armor to protect the underside and I noticed that there are no transmission skid plates.
Go Westy does not sell anything for the trans but I see that only Bostig has one.
I've read that they can trap heat, what do you say, yea or nay on a trans bash plate?
My Van has an SVX Subaru 6 and only has like 9" of ground clearance!
EMPI sells a generic plate:
https://www.appletreeauto.com/standard-skid-plate-...MTk7WO1h2U
[/img]
RawUmber
RawUmber is offline
PostPosted: Sat Nov 08, 2025 8:20 am    Post subject: Re: Vanagon syncro Trans skid plate? Reply with quote
You might find 'Voyages dans des conditions difficiles' (~'Travels in difficult conditions') interesting, as it shows some protective undercarriage designs for transaxles on pages 18 and 20. That said, I'm uncertain which transaxles they are for.
https://web.archive.org/web/20231224035316/https:/...ionnes.pdf
MarkWard
MarkWard is offline
PostPosted: Sat Nov 08, 2025 8:48 am    Post subject: Re: Vanagon syncro Trans skid plate? Reply with quote
I can appreciate an aftermarket bolt on solution, but a local metal fabrication shop could likely fabricate something specific to your setup. You could mock up with construction paper or cardboard to use as templates.
Keeping in mind, it should be sacrificial. You wouldn’t want it so stout it transferred damage into an expensive to repair spot.
Sodo
Sodo is offline
PostPosted: Sat Nov 08, 2025 8:55 am    Post subject: Re: Vanagon syncro Trans skid plate? Reply with quote
Rawumber, at least that skidplate has access to the drainplug.
Syncro skid bars blocked drainplug access.
With their complicated assembly/disassembly procedure....
rather than protect the trans, the added maintenance difficulty,
Syncro skid bars have ruined tens of thousands of Syncro transaxles from the inside-out.
Methinks the most important "mod" to protect your trans would be protection to the internals.
Easiest is cutting out E-Z access to the drain-plug.
More difficult is a mod to make it "easy" to remove the skid-bars.
Delete any impediment to maintenance.
Whatever you do, don't make frequent mainteenance "more difficult".
I would add a temperature gauge before reducing the cooling.
A gearbox can already overheat with full-flow (no covers) at 90hp
If you have a big engine already, you probably already drive fast&heavy in which case reducing cooling is gearbox suicide.
Know before you go. (temperature gauge!)
Isolate your gearbox from electricity too, that's easy, offer several permanent future benefits, and only $15.
....KTMs, GasGas, SPOT mtb
swissarmychainsaw
PostPosted: Sat Nov 08, 2025 11:35 am    Post subject: Re: Vanagon syncro Trans skid plate? Reply with quote
How about a couple of 6" cooling fans like you find on an oil cooler?
Do you mean by grounding it, with a ground wire?
MsTaboo Premium Member
MsTaboo is offline
PostPosted: Sat Nov 08, 2025 1:05 pm    Post subject: Re: Vanagon syncro Trans skid plate? Reply with quote
I have the Bostig transaxle bash plate (and engine bash protection), the transaxle plate is bomb proof! BUT, very heavy. It's fairly easy to mount/dismount so I only install when I figure I'm heading into rough country (and to access the drain plug - so no big deal).
Tried to cut some weight reduction holes into it but without cutting torch it was gnarly work. Plan to find a shop to do the cutting.
The thing is WAY overbuilt, but ample protection!
As far as mating it up with your SVX that may take some extra fabrication as the Bostig plate is designed to work with their engine cradle.
Considering the scarcity and expen$e of a nice Syncro transaxle I think the protection worth the effort.
Currently:
syncrodoka
syncrodoka is offline
PostPosted: Sat Nov 08, 2025 1:17 pm    Post subject: Re: Vanagon syncro Trans skid plate? Reply with quote
Gowesty has offered engine/trans skid plate in the past, you can see pictures of it in their other skid plate ads.
You don't have the stock engine crash bars?
Pic stolen from the gallery
swissarmychainsaw
PostPosted: Sat Nov 08, 2025 2:37 pm    Post subject: Re: Vanagon syncro Trans skid plate? Reply with quote
<snip>
I actually just ordered the Bostig transaxle skid plate!
swissarmychainsaw
PostPosted: Sat Nov 08, 2025 2:39 pm    Post subject: Re: Vanagon syncro Trans skid plate? Reply with quote
[quote="syncrodoka"]Gowesty has offered engine/trans skid plate in the past, you can see pictures of it in their other skid plate ads.
<Snip>
Yes this is exactly what I have, and that open section is where I fear large rocks will break my trans/motor.
Sodo
Sodo is offline
PostPosted: Sat Nov 08, 2025 3:36 pm    Post subject: Re: Vanagon syncro Trans skid plate? Reply with quote
I suspect fans blowing air could help a little, especially when grinding up a long hill in low gear, low speed.
But to KNOW this, you would need a temp gauge installed prior.
To know if they help.
Yes ground the starter directly then delete that forward ground so electricity is never again drawn thru the internal shafts.
Currently electricity exits at the mainshaft bearing via the VW forward ground strap.
Delete that strap.
Have you ever seen pics of a broken tranny case on theSamba or anywhere?
I have never seen a pic of a gearbox damaged by rocks.
Engine sumps damaged....yes I've seen that.
There's lots of known damage by gearbox overheat.
Too much power, too heavy, too fast. etc.
Ask any gearbox builder they see damage from, rocks or internal heat?
syncrodoka
PostPosted: Sat Nov 08, 2025 5:53 pm    Post subject: Re: Vanagon syncro Trans skid plate? Reply with quote
That is a valid point. I have had a large stick jam itself up near the shift lever that took some doing to get it dislodged.
I welded plate steel to the stock engine crash bars many years ago and the definitely have taken some impacts. If I was redoing it I might consider putting in rivnuts or timeserts to unbolt the plate vs unbolting the entire skid plate to service.
swissarmychainsaw
PostPosted: Sat Nov 08, 2025 6:55 pm    Post subject: Re: Vanagon syncro Trans skid plate? Reply with quote
dougnlina Premium Member
dougnlina is offline
PostPosted: Sat Nov 08, 2025 7:13 pm    Post subject: Re: Vanagon syncro Trans skid plate? Reply with quote
see
https://www.thesamba.com/vw/forum/viewtopic.php?p=9504007&highlight=#9504007
and
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mor+armour
theres a few others out there as well...
"Grover" a '87 Syncro Poptop 1.8T
"Olive" a '60 Ragtop Beetle (retired)
"Kermit" '79 Westfalia (retired)
"Patches" '72 Beetle (retired)
"Wilbur" '69 Camper (retired)
"Bernice" 67 Beetle, My first love, (Also Retired)
