Tweed2863 Samba Member
Joined: March 18, 2024 Posts: 42 Location: Pittsburgh Pa
Posted: Fri Nov 07, 2025 12:34 pm Post subject: Re: Intermittent No Crank-1972 bus |
| Xevin wrote: |
| SGKent wrote: |
| leave the hard start relay off the bus until you solve the issue or you are just adding one more variable to cause you issues. Fix the problem first. |
SGKent and I 100% agree again  |
I will follow both of your advices!!
Thank you again |
Xevin  Samba Member
Posted: Fri Nov 07, 2025 1:41 pm Post subject: Re: Intermittent No Crank-1972 bus |
| airschooled wrote: |
1972 buses have a nonstandard (terrible) battery ground strap location in the engine compartment. That’s the first place I would clean and tighten the fasteners.
Robbie |
And This _________________ Keep on Busin'
| 67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
| Clatter wrote: |
Damn that Xevin...  |
| skills@eurocarsplus wrote: |
| SGKent wrote: |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42948 Location: at the beach in Northern Wokistan
Posted: Fri Nov 07, 2025 3:35 pm Post subject: Re: Intermittent No Crank-1972 bus |
| Xevin wrote: |
Robbie |
And This |
OMG Xevin and I agree again. The world is shifting on its axis _________________
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
dodger tom  Samba Member
Joined: March 25, 2013 Posts: 2065 Location: Central Coast, CA, but we're all still Ukrainian and Californian
Posted: Fri Nov 07, 2025 4:18 pm Post subject: Re: Intermittent No Crank-1972 bus |
| Xevin wrote: |
| SGKent wrote: |
OMG Xevin and I agree again. The world is shifting on its axis |
i agree with you both a lot.
does that make me wishy washy? _________________ 1978 Champaign Edition 2 Westfalia
Would never find the time to keep up another classic air-cooled. |
SGKent  Samba Member
Posted: Fri Nov 07, 2025 10:50 pm Post subject: Re: Intermittent No Crank-1972 bus |
| dodger tom wrote: |
| Xevin wrote: |
| SGKent wrote: |
does that make me wishy washy? |
no, washy wishy and not wishy washy _________________
George Carlin:
Posted: Sat Nov 08, 2025 10:31 am Post subject: Re: Intermittent No Crank-1972 bus |
Robbie |
Good to know. I did replace the negative battery cable first. It looks like a typical battery cable (black) and it does attach to the frame inside the engine compartment. It doesn't look like the ground strap pictured earlier in this thread.
Thank you for the information |
SGKent  Samba Member
Posted: Sat Nov 08, 2025 2:28 pm Post subject: Re: Intermittent No Crank-1972 bus |
| Tweed2863 wrote: |
Robbie |
there are a minimum of two ground straps. One between the battery and body, and one between the body/chassis and engine/transmission. The starter where it bolts onto the bell housing has to be clean of paint or the paint may keep it from a making good connection. _________________
George Carlin:
aeromech Samba Member
Joined: January 24, 2006 Posts: 17753 Location: San Diego, California
Posted: Sun Nov 09, 2025 12:07 am Post subject: Re: Intermittent No Crank-1972 bus |
For the next guy reading this with the same problem. Take a battery jumper cable and connect one clamp to somewhere on your starter. Then the other clamp to either the bus frame or directly to the battery negative post. If the starter cranks then you’ll know that your problem is the ground connection between the starter and the battery.
Most electrical components have both a positive wire and a negative wire. Starters have just a positive wire. They need to be bonded to the transmission which is bonded to the frame via the ground strap pictured by Xevin on page one. As Steve said, the starter pad to bell housing must be clean and unpainted for this bond.
Funny thing…. As much as I love Eric at Transworks in El Cajon, he always paints the starter pad when he does a rebuild and when I get a trans from him I always have to remove that paint. I tried explaining it to him and he thought I was nuts. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
