qweedqwag Samba Member
Posted: Mon Nov 10, 2025 6:01 pm Post subject: Steering box choices |
Hey Guys,
Hope everyone is running on all four.
I read and saw a video from Empi talking about the high quality of their steering box, anyone here have any experience with it, any other decent stuff out there, open to opinions. Wife asked me what I wanted for Christmas and I need one so there's that.
Thank you all.
Texas Mike. |
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7572 Location: Houston, Texas
Posted: Mon Nov 10, 2025 8:21 pm Post subject: Re: Steering box choices |
I'll toot my own horn here.
I sell a box that is made with NOS steel caged bearings. The bearings are FAG bearings and made in Germany. They are no longer made but are the original bearings that VW used in their German boxes. There is no aftermarket box that has steel caged bearings unless they are using NOS bearings. The plastic cage on the aftermarket bearings fall apart and they have less balls in them. I won't sell a box with those plastic cages.
Whomever you buy a box from make sure they guarantee it and will take it back or make it right. I've had customers come to me a year later or they adjusted the box and needed some help. I took the boxes back and made sure they received something that worked.
Many other places will not take a box back that has been installed/adjusted. _________________ www.vwnos.com [email protected]
EVfun  Samba Member
Posted: Mon Nov 10, 2025 10:13 pm Post subject: Re: Steering box choices |
There are a lot of no name aftermarket steering boxes of questionable quality out there after the TRW replacement steering boxes were discontinued. I have no idea about the quality of the EMPI replacement box. I'm only aware of two that I would trust. Heimlich, of VW NOS, is a reputable member here who I would be comfortable buying from. I have also purchased other parts from Pete at Airkewld and he sells a rebuilt original steering box.
That said, while my buggy has an Airkewld front beam the steering box is just a carefully adjusted original 1963 Bug steering box. I purchased in that time window after Pete could no longer get the TRW boxes but before they started rebuilding original boxes. I recommend you take a little time and see if your original box can be adjusted. There are 2 adjustments to make and many boxes can work well after being properly adjusted. If the roller is shot you'll discover it quickly when even an adjusted box has play in the center of travel. You can look in the fill holes to make sure the roller is turning. _________________
| Wildthings wrote: |
| As a general rule, cheap parts are the most expensive parts you can buy. |
heimlich  VWNOS.com
Posted: Tue Nov 11, 2025 8:22 am Post subject: Re: Steering box choices |
Another choice is to rebuild your existing box if it is the original VW box. I sell a rebuild kit with the same parts in it as my box. There's a huge writeup on here on how to rebuild your box. _________________ www.vwnos.com [email protected]
Posted: Tue Nov 11, 2025 6:42 pm Post subject: Re: Steering box choices |
Heimlich,
I have my wife order one from you, thanks for the heads up.
Texas Mike. |
