mrinnovation1 Samba Member
Posted: Thu Nov 06, 2025 3:31 pm Post subject: Re: What did YOU do to your van today? |
| I've used the Dremel with a cutoff wheel for over 50 years. It is the most versatile tool I've ever had. |
Kdj Samba Member
Joined: January 28, 2017 Posts: 336 Location: Naptown
Posted: Mon Nov 10, 2025 6:50 am Post subject: Re: What did YOU do to your van today? |
Got a fun euro plate knock off mounted
dhaavers Samba Member
Joined: March 19, 2010 Posts: 8529 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Mon Nov 10, 2025 10:31 am Post subject: Re: What did YOU do to your van today? |
^^^ Classy!
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
campism Samba Member
Joined: September 07, 2007 Posts: 4716 Location: Richmond VA
Posted: Tue Nov 11, 2025 6:07 am Post subject: Re: What did YOU do to your van today? |
| Kdj wrote: |
You forgot the umlaut! _________________ '87 Westy in Wolfram Grey Metallic, tragically crushed by a falling hickory tree in my own driveway and now gone, leaving me Vanagonless and with no plans to replace it, alas. |
Kdj Samba Member
Posted: Tue Nov 11, 2025 8:26 am Post subject: Re: What did YOU do to your van today? |
Yeah wasn't an option with the online order form. Knew someone was going to point that out. Hell had to google just to spell!  |
Posted: Tue Nov 11, 2025 1:04 pm Post subject: Re: What did YOU do to your van today? |
| Kdj wrote: |
| Yeah wasn't an option with the online order form. Knew someone was going to point that out. Hell had to google just to spell! :oops: :lol: |
Get some white paint to match the background of the plate and add a line across each upright of the U to make your own. You owe it to die Sprache. _________________ '87 Westy in Wolfram Grey Metallic, tragically crushed by a falling hickory tree in my own driveway and now gone, leaving me Vanagonless and with no plans to replace it, alas. |
Kdj Samba Member
Posted: Tue Nov 11, 2025 3:34 pm Post subject: Re: What did YOU do to your van today? |
For “die Sprache”. Thanks for pointing out the errors of my way! |
Posted: Wed Nov 12, 2025 6:36 am Post subject: Re: What did YOU do to your van today? |
| Kdj wrote: |
Yay! I did something similar for my VELO plate so it would have the correct accent mark. Diacritical marks exist for a reason.
BigPapaV Samba Member
Joined: February 05, 2023 Posts: 81 Location: Long Beach, CA
Posted: Wed Nov 12, 2025 2:48 pm Post subject: Re: What did YOU do to your van today? |
Last night spent some time aligning my shift linkage after rebuild using markward's instructions. All gears except G are smooth and solid, G is kinda popping out, so today I'll clear out the driveway to test back and forth.
Also figured out a no crank condition: yellow-top battery read 12.2v off the charger, but next day it was 11.7v. Spare Duralast battery off the charger reading 12.7v, cranked right away.
Then it would crank but not start (had just finished a lot of engine wiring work)...turns out I forgot to plug in connector C (I think) back into the ECU, and then started up right away.
Followed by wine at the fire pit with the wife. _________________ 1986 VW 3-knob Syncro Tintop w/ 1992? Suby Legacy 2.2L (KEP install) |
jlrftype7 Samba Member
Posted: Sat Nov 15, 2025 8:51 am Post subject: Re: What did YOU do to your van today? |
Tis the Season for Snow Tire Swap, so did that at Work today.
Installed the previously broken Drivers Slider Window Glass as well. A BIG thank you to Ed in New Mexico for the used slider windows.....
Boy, even with some quality time learning about these windows last year when I put new Window Channel Seals and Fuzzy seals in, it's still a learning experience messing with the Slider Windows.
Getting the screw started in the latch is probably my least favorite part of it. Just begging for the thread to catch and start threading in.....
Battery test of the 2018 NAPA battery still shows unbelievable amount of capacity after all these years. It's like 98%. But, I'm wary of getting another year out of it, or at least Winter. We'll see.
Removed the Rear Drums to inspect the springs and cylinder after Howesights thought prose on what he went through with a rusted brake spring coming apart. Chicago after all DOES LOVE salt for Winter Driving...  _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
Camper_Velourium Samba Member
Joined: August 31, 2025 Posts: 31 Location: Sonoma, CA
Posted: Sun Nov 16, 2025 12:01 pm Post subject: Re: What did YOU do to your van today? |
Now I've just gotta figure out why the bleed screws aint bleeding...
Posted: Mon Nov 17, 2025 6:41 am Post subject: Re: What did YOU do to your van today? |
| Camper_Velourium wrote: |
Usual causes, rust clogged the pretty tiny hole in the screw, you use a very small drill bit , like 1/16", to gently work the bit through the rust on the side of the bleeder screw. Sometimes it's rust clogging the caliper body instead of the screw, but again, drill bit twisting through the rust block frees up the rust particles and you're back in business with fluid flow.
Hopefully not swelling rubber brake hoses- how old are your flexible brake hoses? _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
Posted: Mon Nov 17, 2025 10:14 am Post subject: Re: What did YOU do to your van today? |
| Now I've just gotta figure out why the bleed screws aint bleeding... |
As usual, jlrf is right on track!
Did your bleeders have caps in place? I know my van didn’t come with any, and they go a long way towards preventing this problem.
If not, time to restock…cheap insurance…this is what they’re for, and they work!
https://vancafe.com/brake-bleeder-valve-cap-front-...PhEALw_wcB
PS: Some generic versions from your FLAPS will work also.
"The WonderVan"
bobbyblack  Samba Member
Joined: May 21, 2015 Posts: 4705 Location: United States, Iowa
Posted: Mon Nov 17, 2025 12:17 pm Post subject: Re: What did YOU do to your van today? |
Agreeing with dhaavers, the rubber caps are pretty much necessary. One step further could help too: after bleeding, there will still be a bit of brake fluid in the stem of the bleeder, that should be cleared out with a blast of carb/brake cleaner, then the rubbers put on. To finish up, smear a bit of grease around the base of the bleeder stems at the caliper/cylinder/clutch.
Also, when bleeding, loop the clear hose up above the bleeder valve, so as to create a space where there is definitely NO air bubble, thus no chance for any air back into the system as you close the valve.
-bobby _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Icebox500 Samba Member
Joined: October 09, 2021 Posts: 262 Location: Louisiana
Posted: Mon Nov 17, 2025 3:38 pm Post subject: Re: What did YOU do to your van today? |
A couple of broken ribs could t stop me today (but they sure slowed me down). Chris had just sent me new T3 shocks for all 4 corners and I got them on in my tiny driveway.
Next up, play with settings.
Next next up, install his front anti-sway bar sitting in my garage.
Right now, Tylenol… _________________ 87 Westy 2WD “Van Geaux”
FAS 2.0 Gas GENV (10/2025)
AZ Transaxle + Peloquin Manual Transmission
GW lift springs, solar, Burley front & rear disc, etc...
New Orleans, LA (previously CO, WA, and CA)
Past
87, 90 Westys
64, 65 splittys + various air cooled |
Posted: Tue Nov 18, 2025 12:23 pm Post subject: Re: What did YOU do to your van today? |
| Thanks for all the input. I completely removed the bleed screws and nothing was flowing out of the caliper. Fluid was freely flowing from the brake line when caliper was originally removed But I was at the end of my day, no light and started to rain. Brake pedal feels rock solid and stops the wheel. So probably just some crud got forced towards the bleed ports when I pushed the pistons back? Bleed screws all had rubber covers. I'll do the lines next for safe measure, van is new to me, they don't look bad though.. Original owner kept it up well until parking it in the 00s, just drove it minimally and to smog it every two years. and it's California condition with minimal rust anywhere for an old vw. |
Posted: Tue Nov 18, 2025 12:57 pm Post subject: Re: What did YOU do to your van today? |
No Vanagon is old, when your first Type 2's were these:
Posted: Tue Nov 18, 2025 9:20 pm Post subject: Re: What did YOU do to your van today? |
| jlrftype7 wrote: |
Hopefully not swelling rubber brake hoses- how old are your flexible brake hoses? |
Drill bit to the caliper bleed port did the trick. Completely gunked up on both. Thanks.
Drove it around to break in the brakes a bit, felt great. Then parked it, went to try out the fresh keys I had ground and van would only crank, not start. First no start since I got it. A job for tomorrow lol |
Posted: Wed Nov 19, 2025 11:51 am Post subject: Re: What did YOU do to your van today? |
| …Drill bit to the caliper bleed port did the trick. Completely gunked up on both…Drove it around to break in the brakes a bit, felt great… |
Woot! Good work, now move on to the next project!
Oh wait, the van already did…
"The WonderVan"
seatown7 Samba Member
Posted: Thu Nov 27, 2025 10:15 pm Post subject: Re: What did YOU do to your van today? |
A before and after for the powder coating of my stove face plate. Installed it today before the holiday feasting began.
_________________ Current Rig: 1987 Westfalia with Subaru 2.2 conversion, Kennedy Engineering adapter plate, Peloquin limited slip differential, Schwenck springs, Rad-Flow shocks, Burley Big Brake front discs, Burley Rear Disc Brake kit, T3 Technique 711 Shifter, 16" Audi wheels, T3 Technique steering reinforcement, T3 Technique HD anti-sway bar, Powerflex bushings, 100w solar panel, Power-Sonic Life-Po house battery, Burley rear swing out spare tire carrier. |
