craigolio1 Samba Member
Posted: Sat Nov 15, 2025 4:32 pm Post subject: Trying to identify my engine |
Hey all.
I’m trying to learn about my engine.
It doesn’t have a number on the case below the generator stand as I’ve seen elsewhere. The number is beside it on the top to the left.
Not a great picture but it’s U0470992
According to this thread here:
https://www.thesamba.com/vw/archives/info/engine_letters.php
It looks like it was maybe from a Type 3? So would I be correct in assuming this block is from a type 3, and was rebuilt with the components that would have been used in the beatle/ghia?
If anyone can tell me any more from the picture, or lead me to things I can check to learn more about it, I’d be very appreciative.
Also, I’d like to do an upgrade to an alternator. Can anyone tell me if this fuel pump will need to be replaced to accommodate the alternator/stand?
Thanks.
Craig. _________________ Located in the Toronto area.
1971 Ghia Convertible
Join me on my Karmann Ghia journey.
https://www.thesamba.com/vw/forum/viewtopic.php?p=10441921#10441921
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80446 Location: Sneaking up behind you
Posted: Sat Nov 15, 2025 4:34 pm Post subject: Re: Trying to identify my engine |
Type 3 converted to upright with dual port heads and a generator. 74 intake with EGR fitting, 34PICT carb and 009 distributor. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
rcooled Samba Member
Joined: September 20, 2008 Posts: 2854 Location: Santa Cruz, CA
Posted: Sat Nov 15, 2025 4:56 pm Post subject: Re: Trying to identify my engine |
| craigolio1 wrote: |
| Can anyone tell me if this fuel pump will need to be replaced to accommodate the alternator/stand? |
No, that fuel pump will work with an alternator.
FYI...the 009 distributor doesn't play well with a 34PICT-3 carb. It'll run, but can exhibit a notorious flat spot off idle that's nearly impossible to tune out.
An SVDA (single vacuum, dual advance) distributor will work much better.
One other thing...the outlets in the shroud that supply air to the heater boxes (if present) are blocked off, so you'll have no heat/defrost in the cabin. _________________ '63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
'62, '63, '65, '69 Bugs (all long gone) |
Posted: Sat Nov 15, 2025 5:30 pm Post subject: Re: Trying to identify my engine |
| Glenn wrote: |
| Type 3 converted to upright with dual port heads and a generator. 74 intake with EGR fitting, 34PICT carb and 009 distributor. |
Well that’s impressive.
Would you mind helping me see how to spot the dual port heads, ‘74 heads and carb type?
Thank you!
Edit: never mind that used my own brain and google. Thanks again for the info!
Craig _________________ Located in the Toronto area.
Posted: Sat Nov 15, 2025 5:33 pm Post subject: Re: Trying to identify my engine |
| rcooled wrote: |
| craigolio1 wrote: |
One other thing...the outlets in the shroud that supply air to the heater boxes (if present) are blocked off, so you'll have no heat/defrost in the cabin. |
That’s great info! Thank you.
This car has an electronic ignition conversion inside the distributor. Will that bit about the flat spot still apply? I just got the car and I’ve only driven it six or seven times. I can’t say I’ve noticed a flat spot but then I’ve never driven any other Volkswagen so I don’t have a frame of reference. What does a flat spot feel like when you’re driving?
I’m aware of the no heat. The heater boxes are gone and it has J-tubes. I’m ok with that as it’s just a fair weather fun car for me.
Again thanks for the info!!
https://www.thesamba.com/vw/forum/viewtopic.php?p=10441921#10441921 |
Posted: Sun Nov 16, 2025 1:39 pm Post subject: Re: Trying to identify my engine |
| craigolio1 wrote: |
| What does a flat spot feel like when you’re driving? |
Feels like the engine will stumble a bit when moving off from a stop. Not all 009s exhibit this trait...maybe you got lucky. It has more to do with how the distributor advances rather than if it uses points or an electronic module. _________________ '63 Ragtop (current)
Era Vulgaris Samba Member
Joined: August 22, 2012 Posts: 1950 Location: Raleigh, NC
Posted: Sun Nov 16, 2025 2:14 pm Post subject: Re: Trying to identify my engine |
| craigolio1 wrote: |
Would you mind helping me see how to spot the dual port heads, |
You can tell it's dual port from the intake manifold. The ends of the intake manifold split into two passages for an individual port on each cylinder.
With single port heads the intake manifold doesn't split, and there's only a single port on the head for the two cylinders.
You'd be wise to remove the block-off plates on the fan shroud outlets, or at least drill a dime-size hole in them. When those outlets are fully blocked off, it'll create turbulence inside the fan shroud that reduces cooling efficiency. _________________ Currently own:
66 Karmann Ghia, L390 Gulf Blue, under construction, here: www.thesamba.com/vw/forum/viewtopic.php?t=760505&highlight=
99 Mazda MX-5 10AE, Sapphire Blue Mica, 6 speed, LSD
Previously owned:
98 Porsche Boxster, silver, 2.5L -- 67 Karmann Ghia, Black, 1500sp -- 98 BMW Z3, Atlanta Blue Metallic, 2.8L I6 -- 75 Porsche 914, Laguna Blue, 2270cc -- 72 Porsche 914, Signal Orange, 1.7 FI -- 74 Karmann Ghia, Black, 1600dp -- 74 Triumph TR6 with O.D., sapphire blue |
Glenn  Mr. 010
Posted: Sun Nov 16, 2025 2:22 pm Post subject: Re: Trying to identify my engine |
You don;t want the fuel filter touching the spark plug wires.
Old plastic filters leak and old wires spark. Recipe for a fire. _________________ Glenn
Member #1009
#BlueSquare
Posted: Sun Nov 16, 2025 4:54 pm Post subject: Re: Trying to identify my engine |
| rcooled wrote: |
| craigolio1 wrote: |
Feels like the engine will stumble a bit when moving off from a stop. Not all 009s exhibit this trait...maybe you got lucky. It has more to do with how the distributor advances rather than if it uses points or an electronic module. |
Thank you. I do feel a little of that in maybe the first 15 min of driving. When I first start it I have to keep a bit higher RPM for maybe 5 min. And then for bit after that I have to accelerate slowly from a stop to keep from stalling. Then fine after that. This was this past month when outside temps were quite cool. I figured the engine just needed to warm up. When I’m back on the road in the spring I’ll pay more attention to see if there is a flat spot.
Thanks again for that info.
Posted: Sun Nov 16, 2025 4:55 pm Post subject: Re: Trying to identify my engine |
| Glenn wrote: |
Old plastic filters leak and old wires spark. Recipe for a fire. |
Yikes! Ok I’ll take care of that asap.
Thank you!!
Posted: Sun Nov 16, 2025 4:58 pm Post subject: Re: Trying to identify my engine |
| Era Vulgaris wrote: |
| craigolio1 wrote: |
You'd be wise to remove the block-off plates on the fan shroud outlets, or at least drill a dime-size hole in them. When those outlets are fully blocked off, it'll create turbulence inside the fan shroud that reduces cooling efficiency. |
Awesome, thanks for that.
I’ve seen it posted else where that those holes need to blocked off so that hot engine air isn’t fed into the engine bay and then drawn back into it, potentially causing over heating. Your position is it’s better to have them open? Maybe I’m confused. This happens often, haha.
Posted: Sun Nov 16, 2025 6:38 pm Post subject: Re: Trying to identify my engine |
| craigolio1 wrote: |
I’ve seen it posted else where that those holes need to blocked off so that hot engine air isn’t fed into the engine bay. |
It's not a matter of hot air getting into the engine bay...the shroud directs cool air from the fan thru the oil cooler and down over the heads & cylinders. If those outlets are left open, a bunch of that cooling air will escape from the shroud instead of being sent where it's needed most. _________________ '63 Ragtop (current)
Glenn  Mr. 010
Posted: Sun Nov 16, 2025 6:56 pm Post subject: Re: Trying to identify my engine |
Nothing wrong with having them closed off.
Old baby food jar lids fit perfectly.
Member #1009
#BlueSquare
Posted: Sun Nov 16, 2025 7:45 pm Post subject: Re: Trying to identify my engine |
| rcooled wrote: |
| craigolio1 wrote: |
It's not a matter of hot air getting into the engine bay...the shroud directs cool air from the fan thru the oil cooler and down over the heads & cylinders. If those outlets are left open, a bunch of that cooling air will escape from the shroud instead of being sent where it's needed most. |
Ah ok. I’ve never heard it explained that way. That makes sense.
Thanks. _________________ Located in the Toronto area.
Posted: Sun Nov 16, 2025 7:46 pm Post subject: Re: Trying to identify my engine |
| Glenn wrote: |
I love it. Required in California as a recycling initiative? _________________ Located in the Toronto area.
Posted: Mon Nov 17, 2025 7:21 am Post subject: Re: Trying to identify my engine |
See this thread where Jake Raby mentions this exactly. Fully blocking off the fresh air outlets creates turbulence in the fan shroud. His recommendation is to use a plug with a small hole, which mimics the backpressure of the heat exchangers, but also allows for the air bleed that VW designed into the shroud.
There is always air flowing through those outlets, so it's not lost air -it's a common misconception to think it is. When the heat is off, the fresh air moving through them is still bled off to the atmosphere through the heat exchangers. When the heat is on, the air moves through the heat exchangers into the cabin. Air that enters those fresh air outlets has zero chance of being used for engine cooling anyway, and the shroud was designed for air to ALWAYS be moving through them. There is no lost cooling air. But if they are fully blocked it will disrupt how the air that is actually used for cooling flows through the rest of the shroud.
I mean keep them fully blocked if you want, but I'll take the advice of a world class engine builder who has mountains of data on these engines.
https://www.thesamba.com/vw/forum/viewtopic.php?p=1256992#1256992 _________________ Currently own:
Previously owned:
Posted: Mon Nov 17, 2025 10:36 am Post subject: Re: Trying to identify my engine |
| craigolio1 wrote: |
| When I first start it I have to keep a bit higher RPM for maybe 5 min. And then for bit after that I have to accelerate slowly from a stop to keep from stalling. Then fine after that. I figured the engine just needed to warm up. |
This could be due to the intake manifold heat risers being blocked...not all that unusual on these motors.
Do you notice any moisture, or even frost, building up on the manifold just below the carb? The heat risers warm the manifold in order to keep fuel from condensing on the inside walls and causing the condition you describe. _________________ '63 Ragtop (current)
Posted: Mon Nov 17, 2025 12:00 pm Post subject: Re: Trying to identify my engine |
| rcooled wrote: |
| craigolio1 wrote: |
Do you notice any moisture, or even frost, building up on the manifold just below the carb? The heat risers warm the manifold in order to keep fuel from condensing on the inside walls and causing the condition you describe. |
Interesting, I was just reading about heat risers. The weather hasn’t been cold enough for frost but I can do that test in a month when the weather here has reached maximum discomfort. But I can go and run it and check for moisture and report back.
Thanks! _________________ Located in the Toronto area.
wagen19 Samba Member
Joined: November 16, 2007 Posts: 877 Location: germany
Posted: Tue Nov 18, 2025 3:04 am Post subject: Re: Trying to identify my engine |
| craigolio1 wrote: |
Hey all.
Thanks.
Craig. |
Hello, if this is really a type 3 engine, what of course can be, where is the oil pressure switch and the tube for the oil level dipstick?
How is that solved on that engine?
Individual handmade solutions? |
Glenn  Mr. 010
