Longer studs for 10mm carb spacer?
craigolio1
craigolio1 is offline
PostPosted: Fri Nov 21, 2025 1:13 pm    Post subject: Longer studs for 10mm carb spacer? Reply with quote
Hey all.
I’m hoarding the parts need to do an upgrade to an alternator in my 1971 Ghia.
From reading and videos I see people needing to add a 10mm spacer to the carb. I can’t seem to find longer studs or extensions.
I’d really like it to be a Canadian source if possible. Can anyone advise?
Thanks.
Craig.
Located in the Toronto area.
1971 Ghia Convertible
Join me on my Karmann Ghia journey.
https://www.thesamba.com/vw/forum/viewtopic.php?p=10441921#10441921
vwmerckx Premium Member
vwmerckx is offline
PostPosted: Fri Nov 21, 2025 2:44 pm    Post subject: Re: Longer studs for 10mm carb spacer? Reply with quote
I have a 10mm spacer on my carburetor and installed these longer studs - purchased from the local VW machine shop.
Sorry - cannot help you with a Canadian source, other than Scott at German Supply (https://germansupply.com) located in Toronto. I am sure he could help !!
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Nov 21, 2025 3:02 pm    Post subject: Re: Longer studs for 10mm carb spacer? Reply with quote
Any good hardware store should have M8x1.25 studs. They don't have to be made by VW... they're just hardware.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
craigolio1
PostPosted: Fri Nov 21, 2025 4:34 pm    Post subject: Re: Longer studs for 10mm carb spacer? Reply with quote
Thank you’ knowing the length is very helpful.
craigolio1
This was a big help.
Thank you.
runamoc Premium Member
runamoc is offline
PostPosted: Fri Nov 21, 2025 6:13 pm    Post subject: Re: Longer studs for 10mm carb spacer? Reply with quote
M8x1.25 studs
can be made by cutting the 'head' off of a metric bolt 1 3/8" (35mm) long.
Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires
craigolio1
PostPosted: Fri Nov 21, 2025 6:30 pm    Post subject: Re: Longer studs for 10mm carb spacer? Reply with quote
runamoc wrote:
M8x1.25 studs
I was wondering about that. The studs have the unthreaded part in the middle which I didn’t think was critical, but also I’m not well versed enough in this stuff to know for sure that they aren’t important in some way.
Mr. 010
Glenn is offline
PostPosted: Fri Nov 21, 2025 6:39 pm    Post subject: Re: Longer studs for 10mm carb spacer? Reply with quote
The unthreaded section is the set the depth that it's screwed into the carb flange. It's not needed.
Honestly if you can leave the head on and just screw it into the carb base.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
craigolio1
PostPosted: Fri Nov 21, 2025 7:25 pm    Post subject: Re: Longer studs for 10mm carb spacer? Reply with quote
That just makes too much sense. Hahaha.
runamoc is offline
PostPosted: Sat Nov 22, 2025 8:16 am    Post subject: Re: Longer studs for 10mm carb spacer? Reply with quote
in a way, length is more critical, especially on the rear mounting bolt..using bolts instead of studs for the fuel pump allows you to use a 'generator' style fuel pump with an alternator. It allows changing a 'generator' style fuel pump without having to lift up the alternator. BUT for some reason...'soft' metal 'things' use studs instead of bolts for mounting. I'm guessing pulling torque and twisting on the threads at the same time instead of just a pulling torque of a stud.
craigolio1
PostPosted: Sat Nov 22, 2025 11:22 am    Post subject: Re: Longer studs for 10mm carb spacer? Reply with quote
Interesting. I never thought of the pulling vs twisting AND pulling. I read 14ftlb of torque which I feel would be little stress on the threads.
My car already has an alternator style fuel pump so that one less thing to worry about.
On the subject of carbs. Are people using just paper gaskets? Just liquid gasket? Paper and liquid gasket? I’ve read all of these things.
Craig.
runamoc is offline
PostPosted: Sat Nov 22, 2025 11:45 am    Post subject: Re: Longer studs for 10mm carb spacer? Reply with quote
just paper gaskets?
I use just the cardboard ones that come in the kit. Back in the day, would trace and cut out cardboard gaskets from the phonebook cover, backs of note pads, and cereal boxes. I can buy that stuff now. Wink
craigolio1
PostPosted: Sat Nov 22, 2025 1:18 pm    Post subject: Re: Longer studs for 10mm carb spacer? Reply with quote
runamoc wrote:
just paper gaskets?
Hahahha. Amazing. So the paper ones are fine then. Noted.
