Autobahn(R) 560R15 Blackwall Tire
Page: Previous  1, 2, 3, 4
[email protected]
JERRY63VW@YAHOO.COM is offline
PostPosted: Thu Jan 25, 2024 11:59 pm    Post subject: Re: Autobahn(R) 560R15 Blackwall Tire Reply with quote
KingAir42 wrote:
That would be awesome to see for the lowered cars, I love those tires.
A 450x15 tire is about the same specs as a 145x15 tire ..... just so folks know ...
BruceFD
BruceFD is offline
PostPosted: Fri Jan 26, 2024 11:31 am    Post subject: Re: Autobahn(R) 560R15 Blackwall Tire Reply with quote
Question for others running this tire, what cold PSI are you using? I noticed on my bus at 36-38 PSI (cold) I still have quite a bit of squish in the tire. Max cold says 44, just wanted to see what others are using.
johnshenry
johnshenry is offline
PostPosted: Fri Jan 26, 2024 4:55 pm    Post subject: Re: Autobahn(R) 560R15 Blackwall Tire Reply with quote
I run the VW speced pressures in the Autobahns on my '57 Beetle. 17 front, 24 back.
John Henry
'57 Deluxe
'56 Single Cab
MuzzcoVW
MuzzcoVW is offline
PostPosted: Fri Jun 21, 2024 1:07 pm    Post subject: Re: Autobahn(R) 560R15 Blackwall Tire Reply with quote
You're going to have "squish" on a radial tire vs a bias ply. It's caused by the radial construction
sgmalt46
sgmalt46 is offline
PostPosted: Sat Jun 22, 2024 7:35 am    Post subject: Re: Autobahn(R) 560R15 Blackwall Tire Reply with quote
+2 yes they will look squishy no matter how much psi . on my bus
I run a little more on the rear. somewhere around 30 front 35 rear max?
on a beetle less 17-24 .
55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG
[email protected]
PostPosted: Sat Jun 22, 2024 3:48 pm    Post subject: Re: Autobahn(R) 560R15 Blackwall Tire Reply with quote
Looks like there will be autobahn tires for the vw/ porsche 16inch wheels ...still looking for autobahn 4.50x15 tires lets hope they make them ...
BFroebe
BFroebe is offline
PostPosted: Wed Nov 26, 2025 7:44 am    Post subject: Re: Autobahn(R) 560R15 Blackwall Tire Reply with quote
Wondering if anyone has an update on using Autobahn tires ?
good tire ? good performance ?
Thanks.
Page 4 of 4
