Rear Brake Line
volkswagen_bug
volkswagen_bug is offline
PostPosted: Thu Nov 27, 2025 10:16 am    Post subject: Rear Brake Line Reply with quote
Good afternoon. I purchased a nearly all-original 1958 Bug a few days ago. My intention is to maintain it for a few years and then do a full pan-off restoration with my son. As with all vintage vehicles, a few things need attention. I noticed a pool of brake fluid under the vehicle, and the driver’s carpet is wet near the firewall. When pressing the brake pedal, I see small bubbles coming from the grommet between the firewall and the brake line. I’m assuming the line somehow has a pinhole leak.
My question is: is this common, and how difficult is it to replace the entire line?
1958 Volkswagen Bug w/ 1200 Single Port
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Thu Nov 27, 2025 10:42 am    Post subject: Re: Rear Brake Line Reply with quote
Yep! That is a brake fluid leak, most likely from the master cylinder. If you remove the dust boot at the rear of the unit and push the pedal, you might be able to see it leak. If not find it quickly, as brake fluid will strip the paint off of the steel, leaving the steel exposed to moisture.
Brake fluid is hygroscopic. So, to clean it and neutralize the damages it can do, you flood it with water. Down side is flash rust will find a way in after that. After it dries up. Apply some Ospho with a squirt bottle, allow it some time to do its thing, then rinse with water. Allow that to fully dry, then hit it with an etching primer. Followed by paint.
Be sure to fix the leak during those down cycles in the brake fluid mitigation!
Also, check the wheel cylinders and the brake rubber hoses. They are probably all on the same wear point.
If it does end up being a hard line. The one running down the outside of the tunnel. The job is not difficult. You just need to know how to bend brake lines without kinking them. Watch some YouTube videos. Remove the interior on the drivers side (seat, floor mats, carpet) then get to the fun! A 11mm or 7/16” flare nut wrench is your best friend along with a 17mm open end wrench for support!
Jimbo
TDCTDI wrote:
67rustavenger wrote:
volkswagen_bug
PostPosted: Thu Nov 27, 2025 10:51 am    Post subject: Re: Rear Brake Line Reply with quote
Thanks for the reply, VM_Jimbo. I didn’t consider the master cylinder being the culprit because I saw small air bubbles between the rear brake line and the rubber grommet at the firewall. I’ll continue to dig further before purchasing any parts.
Cusser
Cusser is offline
PostPosted: Thu Nov 27, 2025 11:08 am    Post subject: Re: Rear Brake Line Reply with quote
Agree: make sure first that the leak is not from the rear of the master cylinder.
Ask me how I know this....
https://www.thesamba.com/vw/forum/viewtopic.php?t=747133&highlight=1971+super+beetle+thread
volkswagen_bug
PostPosted: Thu Nov 27, 2025 11:11 am    Post subject: Re: Rear Brake Line Reply with quote
The grommet around the brake line broke apart, and I cannot see anything wrong with the line. In between, though, I can see fluid and it’s wet, so I’m assuming it’s the master cylinder. Is it worth rebuilding, or should I just replace it?
daveblank
daveblank is offline
PostPosted: Thu Nov 27, 2025 11:22 am    Post subject: Re: Rear Brake Line Reply with quote
I would replace it. Now would be the perfect time to convert it to a dual circuit master cylinder.
volkswagen_bug
PostPosted: Thu Nov 27, 2025 11:30 am    Post subject: Re: Rear Brake Line Reply with quote
I'm trying to keep it as stock as possible. Is there much benefit to converting it to a dual circuit master cylinder.
OldSchoolVW's Premium Member
OldSchoolVW's is offline
PostPosted: Thu Nov 27, 2025 1:59 pm    Post subject: Re: Rear Brake Line Reply with quote
[quote=]"volkswagen_bug" Is there much benefit to converting it to a dual circuit master cylinder.[/quote]
Plenty. With a single circuit, a failure anywhere in the brake lines or wheel cylinders results in a failure of the brake system. With a dual circuit you would only experience a partial loss of braking ability. Do as daveblank suggests. You will be glad you did.
Tom
"Following distance is proportional to IQ."
"It's okay to think."
"If you don't do it this year, you'll be one year older when you do." Warren Miller
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback
volkswagen_bug
PostPosted: Thu Nov 27, 2025 2:26 pm    Post subject: Re: Rear Brake Line Reply with quote
Is there a common part number used for the dual circuit master cylinder that you can share?
PostPosted: Thu Nov 27, 2025 2:49 pm    Post subject: Re: Rear Brake Line Reply with quote
A master cylinder for a later Karmann Ghia or Beetle would work well as an upgrade for an earlier Beetle. This one from NAPA has a lifetime warranty and would be compatible with front disc brakes if you decided to do that worthwhile upgrade during a brake overhaul. I have it in my '63 bug.
https://www.napaonline.com/en/p/NMCM2110
You said you believe your bug to be all original. If you believe that to be the case for the brake hard lines, you may want to plan on replacing them ... sooner rather than later. As they say, it really doesn't matter how well it goes if it doesn't stop when you need it to. Wink
Tom
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback
viiking
viiking is offline
PostPosted: Thu Nov 27, 2025 2:54 pm    Post subject: Re: Rear Brake Line Reply with quote
It's not just the MC you need but you will also have to get/make brake lines to go from single circuit to dual circuit.
PostPosted: Thu Nov 27, 2025 3:11 pm    Post subject: Re: Rear Brake Line Reply with quote
Kind of why I'm nudging our OP to consider doing the brake overhaul now. I totally get the desire to drive and enjoy a recently purchased bug (the fun part of ownership) and get around to stuff like brake overhauls later on. Unless certain of what recent work was done to the bug (and that it was done properly), taking the time to tend to the mechanicals early on goes a long way toward preventing costly, unfortunate failures (brake failure, fuel line leak in engine compartment, fuel pump diaphragm leak, etc.) that can take the bloom off the rose.
Tom
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback
viiking
viiking is offline
PostPosted: Thu Nov 27, 2025 3:29 pm    Post subject: Re: Rear Brake Line Reply with quote
Agree 100%.
Not many of us would agree to an aeroplane taking off and waiting for a failure to happen before doing preventative maintenance.
Schnitzelfuss
Schnitzelfuss is offline
PostPosted: Thu Nov 27, 2025 5:54 pm    Post subject: Re: Rear Brake Line Reply with quote
I’m of the belief that it’s OK to keep the single circuit brake system provided you’ve ensured all system components are inspected regularly and maintained in good working order. As others have stated, for your safety and peace of mind, replace the components with moving parts, all rubber seals and lines, inspect the rest of the system using the workshop manual information, and put fresh fluid in the system.
volkswagen_bug
PostPosted: Fri Nov 28, 2025 5:33 am    Post subject: Re: Rear Brake Line Reply with quote
Thanks for all of the replies. At this time I will be keeping the single circuit brake system and saving any future upgrades for when we do the full restoration. All moving parts, rubber and seals have been ordered.
daveblank
PostPosted: Fri Nov 28, 2025 8:43 am    Post subject: Re: Rear Brake Line Reply with quote
That"s the one that I'm installing.
I was able to reuse the rear & right front. The one for the left front was too short, NAPA has a 12in hose that I was able to bend & make work. A 10in or possibly 8in would have worked too, the original was 6.
volkswagen_bug
PostPosted: Fri Nov 28, 2025 8:57 am    Post subject: Re: Rear Brake Line Reply with quote
I've seen a master cylinder much like that one but with the reservoir mounted on top. Not sure where those are from though.
daveblank
PostPosted: Fri Nov 28, 2025 10:05 am    Post subject: Re: Rear Brake Line Reply with quote
There is a reservoir that mounts directly to the master cylinder. I don't like those because I'm old & don't want to crawl around on the ground just to check the fluid level. I'm mounting a 67 dual circuit reservoir to mine.
Bobs67vwagen
Bobs67vwagen is offline
PostPosted: Fri Nov 28, 2025 12:44 pm    Post subject: Re: Rear Brake Line Reply with quote
I put one on my IRS pan that I am going to use on my 67. I got it form rock auto, here is a picture.
