DIY propane tank fill
Igeo
Igeo is offline
PostPosted: Sat Nov 29, 2025 8:15 am    Post subject: DIY propane tank fill Reply with quote
I'm pretty sure I saw that we can fill the propane tank via a 20 lb bottle. Was I dreaming or can this be done with the correct adapter? Is it simple gravity feed? Does the receiving tank need to be chilled?
1987 Westfalia 2.1 WBX Manual
DanHoug
DanHoug is offline
PostPosted: Sat Nov 29, 2025 8:36 am    Post subject: Re: DIY propane tank fill Reply with quote
i fill my tank from a 20lb bottle. i use the Flame King valve used for refilling the 1lb bottles, remove the bottle thread and put an ACME valve in its place. bottle must be upside down and doesn't require a temperature differential but it does need the 80% valve open nearly all the way to create the pressure differential for the liquid propane to flow between the bottle and the tank. it flows pretty slow but does fill the tank until the 80% valve spits liquid.
all manner of woe can be had if you don't think this thru. use unregulated propane pressure rated hose, frost barrier gloves, extreme ventilation, no flames, fire extinguisher handy.
-dan
www.thefixitworkshop.com
jimf909
jimf909 is offline
PostPosted: Sat Nov 29, 2025 9:54 am    Post subject: Re: DIY propane tank fill Reply with quote
The receiving tank needs to be lower in temp so I warm the donor tank.
I had a similar adapter made to transfer 1 lb bottles to the Westy propane tank in case I ran out. In 10 years I’ve primarily used it to test the concept but I’m ready if need be. Laughing
This thread is on transferring from 1 lb bottles. Similar concept. There are threads on the 20 lb bottles but I can’t find ‘em now.
- Jim
Butcher wrote:
Guilty as charged.
Sodo
Sodo is offline
PostPosted: Sat Nov 29, 2025 10:16 am    Post subject: Re: DIY propane tank fill Reply with quote
If your receiving tank is cooler (thus lower pressure) than the supply tank, the liquid propane will flow faster.
This method can work pretty fast if your home is in a cold climate. Put the supply tank in the house for a day or two, maybe near a heat-register. Your transfer will be quickest when the receiving tank is coolest and supply tank is warmest.
When the pressure differential is higher it will flow faster.
Like DanHoug wrote you can open the bleed valve on the receiving tank to reduce tank pressure (and its temp) but that wastes propane, you don't want to leave it open long. If you have the time it's kinda better to use temperature to transfer. It's a little safer and less waste.
It works best with a "full" 20lb BBQ tank (supply tank).
....KTMs, GasGas, SPOT mtb
Van den Broke
Van den Broke is offline
PostPosted: Sat Nov 29, 2025 10:30 pm    Post subject: Re: Temperature differential Reply with quote
To aid in the flow by utilizing temperature variation I spray painted the BBQ tank black. Then I transfer in the sun with the receiving vessel shaded by a small piece of plywood.
Abscate
Abscate is offline
PostPosted: Sun Nov 30, 2025 3:20 am    Post subject: Re: DIY propane tank fill Reply with quote
Welders warm their acetylene tanks with flame. Don’t use too much oxygen
Igeo
Igeo is offline
PostPosted: Sun Nov 30, 2025 7:59 am    Post subject: Re: DIY propane tank fill Reply with quote
Thanks guys, I'll see what I can cobble together. I ran out of propane last weekend. First time actually running out! Really only thinking to keep the hose/fittings in the van as a backup or plan B if I can prove it works for me.
Xevin Premium Member
Xevin is offline
PostPosted: Sun Nov 30, 2025 8:07 am    Post subject: Re: DIY propane tank fill Reply with quote
About how long does it take to fill an empty tank on the van with a full 20lbs bbq style tank? Using the techniques mentioned
Keep on Busin'
67rustavenger wrote:
Clatter wrote:
skills@eurocarsplus wrote:
SGKent wrote:
Igeo
Igeo is offline
PostPosted: Sun Nov 30, 2025 8:14 am    Post subject: Re: DIY propane tank fill Reply with quote
I think it will depend primarily on the temperature dfferential and position of the donor bottle. I'll post up a result when I try it here in Oakland.
Sodo
Sodo is offline
PostPosted: Mon Dec 01, 2025 11:15 am    Post subject: Re: DIY propane tank fill Reply with quote
And the heights. If you have a longer hose and put the donor higher it goes faster due to gravity.
When you finish it's useful to drain the liquid out of the hose into the receiving tank.
A longer hose holds more liquid.
Liquid propane in the hose flashes to vapor upon disconnect
and can be a little "disconcerting".
It takes thought, understanding and a little effort to drain the hose.
Much like using the word disconcerting instead of its sloppy modern slang "concerning", you may be the only person who notices effort spent.
Put your ear to the hose while it's transferring.
Then later. listen again, it will be going slower.
This gives a little perspective in guessing when flow has stopped.
To do this you must be in a quiet area or during quiet part of the day.
MsTaboo Premium Member
MsTaboo is offline
PostPosted: Mon Dec 01, 2025 2:33 pm    Post subject: Re: DIY propane tank fill Reply with quote
I went with this setup years ago, allows carrying a mini tank for backup when winter camping and using Propex heater:
I don't try to refill the stock tank, just use as a passthrough to the onboard system. We keep the hose and adaptor in the camper all the time but only pack along the mini tank if planning extended trip.
Currently:
Sodo
Sodo is offline
PostPosted: Tue Dec 02, 2025 10:22 pm    Post subject: Re: DIY propane tank fill Reply with quote
Next time hang that tank upside down from the drip rail for a few hours. Then you can put it away (empty) and next campsite you won't have to get it out again.
Igeo
Igeo is offline
PostPosted: Tue Dec 02, 2025 10:43 pm    Post subject: Re: DIY propane tank fill Reply with quote
So the donor tank is con8nected to the fill of the stock tank.. And this just creates extra capacity? What's a mini tank?
Ahwahnee
Ahwahnee is offline
PostPosted: Wed Dec 03, 2025 10:00 am    Post subject: Re: DIY propane tank fill Reply with quote
Looks like a 5lb tank.
https://a.co/d/gAtgtpz
