bugfil Samba Member
Posted: Wed Dec 03, 2025 10:28 am Post subject: Cruise Control Operation |
I have a VW cruise control unit(VPC-Volkswagen Products Corporation), Part # ZVW201709, Type 2, and manual transmission kit ZVW201728 that I bought NOS on the Samba many years ago and installed it many years ago too.
It works well as long as you don't have to go up a hill that's steeper than 3 degrees.
I have a question about the operation of the unit. When I apply the brakes while using the cruise control it slows down as long as I am depressing the brake but when I let up on the brake pedal it starts to accelerate again meaning the cruise control is still engaged. This is a little disconcerting when you are used to a modern cruise control that cuts off when the brake pedal is applied. There is a cut off switch on the clutch pedal but not on the brake pedal.
Is this the way this cruise control is designed to operate or did I install it incorrectly? Does any one else have one of these installed on their bus that could comment on whether theirs work this way too?
The installation manual mentions an operators manual but I did not get that with the unit so I'm not exactly sure how it is supposed to operate. It is a manual transmission in a 78' Champagne edition Westy.
These units seem to be pretty rare and I have found very little information online about their operation.
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53222 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Dec 03, 2025 11:34 am Post subject: Re: Cruise Control Operation |
I see a clutch switch, does it disengage when you push the clutch?
There must be a brake switch, I've never seen a cruise control of any brand that didn't cut off when you touch the brake, what's the wiring diagram in the install instructions show? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Bobs67vwagen Samba Member
Joined: March 27, 2005 Posts: 972 Location: Eastern north carolina
Posted: Wed Dec 03, 2025 11:46 am Post subject: Re: Cruise Control Operation |
| Yeah something is not right on this. When the brake is applied the cruise should be deactivated by a switch on the pedal. Maybe another Audi/VW car of the same period that has cruise control might be a place to start looking for wiring and components for troubleshooting advice and information. |
rsbadura Samba Member
Joined: November 30, 2009 Posts: 771 Location: Berlin, Germany
bugfil Samba Member
Posted: Wed Dec 03, 2025 4:18 pm Post subject: Re: Cruise Control Operation |
Yes Busdaddy, the clutch disengagement switch does work correctly. There was
no wiring diagram provided in the install instructions. Here are the other two pages provided in the install instructions. I have not gone back in to look at
the wiring etc. yet. I believe the system has always been this way since I installed it so it may be connected incorrectly but I don't see anything in the instructions that describe or show a switch at the brake pedal.
Thank you for the manuals "rsbadura", having a wiring diagram to look at is very helpful. On page one of the manual I see a picture of the chrome stalk and switch end that looks like the one in my set up so they may be the same or close. I see in the trouble shooting section that when the bus continues to accelerate after releasing the brake pedal it is either a faulty engagement switch or faulty regulator. Sounds like I may need to learn more about how this system works to determine what's wrong.
Thanks "Bobs67vwagen" good idea about looking at other vVW/Audi models from the same years, that may help me see if something is missing from my cruise control.
I'll let you know what I see when I take a look at the cc system tonight.
bugfil Samba Member
Posted: Thu Dec 04, 2025 1:10 pm Post subject: Re: Cruise Control Operation |
Hi, so I pulled the front pan to look at the cruise control parts. I didn't see anything I can recognize as being wrong, of course that's with my very limited knowledge of cruise controls and how they work. How often does a guy who has worked on aircooled VWs for 40+ years need that knowledge?
Here are some more photos, definitely no switch for the brake pedal.
Here you can see the switch on the clutch pedal.
I'm thinking now that maybe the unit is electrically tied to the brake light as the brake does seem to shut the cruise control off temporarily. I'm not fighting the motor still trying to drive the vehicle forward when the brake is on so I believe something is cutting power to the cruise unit.
Does anyone out there know how to test for proper function of the different parts of the cruise control. I'm particularly thinking of the regulator since the information rsbadura provided says in the trouble shooting section that when a cruise unit acts like mine does it's either the switch or the regulator that is not working properly. Any ideas are greatly appreciated.
Posted: Thu Dec 04, 2025 1:36 pm Post subject: Re: Cruise Control Operation |
I wonder if the resume switch is stuck on, although it quits and doesn't resume when you clutch, correct?
No idea on the "regulator", is that the thing with the speedo cable on it?. It kinda looks like the GM system from that era, I figured out how that system worked years ago so I'll try and recall where I found that info. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11605 Location: Oregon
Posted: Thu Dec 04, 2025 1:38 pm Post subject: Re: Cruise Control Operation |
I would move that clutch switch to the brake lever.
The way it's currently installed, when you depress the clutch pedal while driving, it seems to me that the engine would rev up before the pedal is completely down and disengaging the CC.
I never liked those bead chain CC's.
We installed one in a 32 Ford Coupe some 40 year ago and had an incident when we hit the accelerator and the chain slack got wrapped around the brake lever. We almost hit a Walnut tree before we could switch off the engine.
To the person that commented on later model CC in their driver.
I have a 2003 EV Weekender and a 2020 Tundra TRD. I have to be careful driving the EV as the Tundra has radar detection and will slow mu truck as I approach a vehicle ahead of me when the distance closes rapidly.
My EV doesn't have the radar feature so, I have to remember to touch the brake lever in the EV when driving it and the approach distance closes in traffic. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 3455 Location: Hamble, Hampshire, UK
Posted: Sat Dec 06, 2025 1:40 pm Post subject: Re: Cruise Control Operation |
Read the first set of instructions you posted. There is a wire from the brake light switch mentioned in the bottom right paragraph.
There is no need for an extra switch on the brake pedal, there is already a switch. _________________ Ancient vehicles and vessels
bugfil Samba Member
Posted: Thu Dec 18, 2025 7:44 pm Post subject: Re: Cruise Control Operation |
So, I’m still trying to sort the problem out. Lots of ideas but nothing I’ve checked is wired wrong or connected incorrectly.
Mikedjames, I have read that part of the install section numerous times and double checked the wiring in the brake circuit, everything gets power like it should all the way to the CC regulator and power is cut when the brakes are applied. The problem is the CC comes back on when the brake pedal is released which it should not do. This is specified in the instructions too. Any ideas why depressing the brake pedal doesn’t cut the power for more than the time the pedal is depressed?
I’m wondering about the resume feature on this CC, which I haven’t checked into yet. There is so little information on these CC units that I can find even though these Dana Speedostats were use on many different vehicles. |
Posted: Thu Dec 18, 2025 8:10 pm Post subject: Re: Cruise Control Operation |
The factory one in my Chev truck stays off after you touch the brake (separate switch on pedal), it'll resume when you poke the resume button, I can't remember if it remembers the speed when the ignition has been off.
Yours sounds like the resume switch is stuck. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
blacka1vw Samba Member
Joined: September 11, 2013 Posts: 105 Location: N. Central PA
Posted: Fri Dec 19, 2025 7:49 am Post subject: Re: Cruise Control Operation |
Could there be an input switched between the brake switch signal and the clutch pedal signals? Maybe resuming after clutching could be ok. _________________ 64 SC truck.
71 Beetle -Skyy
71 Super -Sweet pea
73 Bus
79 Bus -Tic Tak
86 Cabriolet |
