Nitramrebrab72 Samba Member
Joined: November 10, 2018 Posts: 1038 Location: France
Posted: Thu Dec 04, 2025 4:06 am Post subject: Is it possible to make an AirFuel Ratio meter for under 10$??? |
https://www.ebay.co.uk/itm/172343718358
Looking at making a AFR reader from an analog voltmeter and broadband lambda sensor from a scrapped car.... |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 4239 Location: Georgia
Posted: Thu Dec 04, 2025 8:49 am Post subject: Re: Is it possible to make an AirFuel Ratio meter for under 10$??? |
Let us know how it goes.
I used the PLX set up with Bluetooth to my phone since I didn’t feel like ripping the interior apart to run wires. _________________ Volkswagen!
(Compression 8.7:1) |
Posted: Thu Dec 04, 2025 9:28 am Post subject: Re: Is it possible to make an AirFuel Ratio meter for under 10$??? |
| I am going to remove the backround dial ,out and colour the 0.4-0.6volts range with a green tint and a tall white line in the middle at 0.5v and 0.6v-0.7/0.4-0.3 yellow 0.3-.02/0.8-0.9 orange and the rest red. |
panel Samba Member
Joined: December 02, 2001 Posts: 1232 Location: Victoria B.C. Canada
NJ John Samba Member
Joined: September 21, 2007 Posts: 3076 Location: HdG, MD & NJ
Posted: Thu Dec 04, 2025 3:54 pm Post subject: Re: Is it possible to make an AirFuel Ratio meter for under 10$??? |
I’ve done it. It work’s. I never used it for tuning. Narrow band will drive you crazy. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
Rubix12345 Samba Member
Posted: Thu Dec 04, 2025 4:50 pm Post subject: Re: Is it possible to make an AirFuel Ratio meter for under 10$??? |
| You can grab a proper wideband for $75-100 on ebay or amazon. Just do that. |
Posted: Thu Dec 04, 2025 7:44 pm Post subject: Re: Is it possible to make an AirFuel Ratio meter for under 10$??? |
| I believe the wide band is actually 5 volts , so I can use a scrapped 6 volt gauge..So could be possible to make one from lying around gathering dust parts.. |
Bugsy61 Samba Member
Joined: March 20, 2011 Posts: 273 Location: Peoria, Illinois
Posted: Thu Dec 04, 2025 8:25 pm Post subject: Re: Is it possible to make an AirFuel Ratio meter for under 10$??? |
| You can use any volt meter with a low range, and a narrow band oxygen sensor. I used one back in 1998, 1999 when wide bands were way expensive. The needle bounces around so much it is tough to make sense of. Just bite the bullet and buy a wide band test set up. You'll use it for decades to come. It is a great investment in your future projects. |
Posted: Fri Dec 05, 2025 3:23 am Post subject: Re: Is it possible to make an AirFuel Ratio meter for under 10$??? |
| Bugsy61 wrote: |
It's not a money thing, I spend a lot of time with financially poor people, but very rich in knowledge ,joy and happiness making things from nothing which I now enjoy doing , the other thing is I burn mixed fuels depending what I can find in the country I'm in Europe right down to Africa alcohol/petrol/light oils so I am looking for the stoichimetry of the burnt mixture as quite often I don't know what mixture of fuel I am burning so the AF ratio is little help without knowing the exact composition of the fuel . ...
As you say it bounces a lot that means an inertia weighted needle voltmeter is required or maybe was it down to the narrow band lambda sensor  |
tencentlife Samba Member
Joined: May 02, 2006 Posts: 10164 Location: Abiquiu, NM, USA
Posted: Fri Dec 05, 2025 8:07 am Post subject: Re: Is it possible to make an AirFuel Ratio meter for under 10$??? |
| Quote: |
| making things from nothing |
Well if you can make a wideband controller from nothing I'd say you have a new career in front of you.
Without a controller, though, good luck getting any output of any voltage out of a wideband O2 sensor. _________________ Shop for unique and useful Vanagon accessories at the Vanistan shop:
At birth you only know how to suck. Spend the rest your life learning how not to. |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 3477 Location: Hamble, Hampshire, UK
Posted: Fri Dec 05, 2025 9:00 am Post subject: Re: Is it possible to make an AirFuel Ratio meter for under 10$??? |
| Nitramrebrab72 wrote: |
Measure the DC resistance of the 1 volt meter. Connect a resistor that is exactly 4 times larger in value in series with it. And now when 5 volts is across the series connection of the resistor and meter, it will draw the same current as 1 volt across only the meter.
And there you have a 5 volt meter.
In fact all those moving coil meters are current meters, with a resistor in series to turn them into volt meters. If you know the max current for full scale, Ohms law will tell you the resistor you need to make a volt meter. (full scale voltage) divided by (full scale current) = total resistance.
Of course the meter movement itself has a resistance, that limits the lowest voltage you can measure - I think my 1mA meter has a resistance of 75 ohms so the lowest voltage it can measure is 0.075V. _________________ Ancient vehicles and vessels
DesertSasquatchXploration Samba Member
Posted: Fri Dec 05, 2025 9:34 am Post subject: Re: Is it possible to make an AirFuel Ratio meter for under 10$??? |
Already been over this many times use your multimeter set to mV and a o2 sensor one wire. 1v is rich .100 is lean.
You first get in the ballpark the old school way.
https://www.aircooled.net/vw-carburetors-jetting-102/
The AFR gauge is for fine tuning _________________ Key is to have downward travel Preload keep both wheels on the ground at all times once you lift a tire your DONE. Guys worry about clearance instead think of the opposite you want the suspension to drop that tire in the hole and keep you going. A spider for example they keep their body low but their legs can reach pretty far so they don't (bottom out) |
Posted: Fri Dec 05, 2025 12:02 pm Post subject: Re: Is it possible to make an AirFuel Ratio meter for under 10$??? |
| mikedjames wrote: |
Of course the meter movement itself has a resistance, that limits the lowest voltage you can measure - I think my 1mA meter has a resistance of 75 ohms so the lowest voltage it can measure is 0.075V. |
Now thats quite useful for my little project.. Thank you... |
2pist Samba Member
Posted: Wed Dec 10, 2025 5:07 pm Post subject: Re: Is it possible to make an AirFuel Ratio meter for under 10$??? |
| I was thinking about a wideband diy too. I would use an Arduino to output the voltage to 2 lm 3914 linear LED drivers. That would give you 10 led resolution. It would be easy to scale. Somebody made a shield over in England and attempted to make a business but things are quiet over there now. |
