Hayden74SB Samba Member
Joined: December 04, 2025 Posts: 47 Location: Tucson, AZ
Posted: Sun Dec 07, 2025 8:57 am Post subject: Suggested motor manual for non-mechanic. |
My son-in-law has just gotten a 74 Super Beetle and is planning to do a full engine teardown and rebuild. He has never done any serious wrenching and I would like to find a good manual for this car to guide him through process.
Any suggestions for a book for the Noob. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11667 Location: Oregon
Posted: Sun Dec 07, 2025 9:36 am Post subject: Re: Suggested motor manual for non-mechanic. |
Well, a good starter book is, John Muar's "How to keep your VW alive, for the complete idiot" Almost everyone has that book on their shelf. It is a fun read and has some good tips for keeping your SIL's car on the road.
Another is a Bentley service manual for the year of make for the car. It's a little harder to digest but has all the information on maintaining a VW.
There are a few more books available, Prescott Phillips, VW engine rebuild book is likely the latest to be published. For a pro, there are a few mistakes in the book but, for a noob, they would never notice those. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
Bobs67vwagen Samba Member
Joined: March 27, 2005 Posts: 1034 Location: Eastern north carolina
Posted: Sun Dec 07, 2025 12:19 pm Post subject: Re: Suggested motor manual for non-mechanic. |
| Times 2 on the Muir idiots guide. I started on this in the 1960s and still use it today. It is written in a way that non mechanical types can understand the processes to accomplish repairs. Good luck |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 16800 Location: North Florida, USA
Posted: Sun Dec 07, 2025 1:01 pm Post subject: Re: Suggested motor manual for non-mechanic. |
I have these two books:
How to Rebuild Your Volkswagen air-Cooled Engine (All models, 1961 and up)(1987)
How to Rebuild VW Air-Cooled: 1961-2003 (2019)
While the second one is newer and details recent kits and parts that you can still buy... I feel the first book does a better job walking you thru every step of the process. IMHO.
My one criticism of the first book... it does a poor job linking the distributor installation/dependency steps together and could result in the distributor timing being off.
Step1 - Install the distributor drive gear, spacers and distributor into the left case half with the rotor pointing to where you want #1 spark plug on the distributor cap.
Step 8 - Drop the crank into the case half with the #1 connecting rod fully extended (TDC).
Step17 - Engage the cam gear with crank gear so "dot" index marks mesh.
The step numbers are just an example to show that there are many steps between these three. If you happen to rotate the crank 360deg between Step 8 and Step 17 to make sure the bearings are in their journals... the distributor will be 180-out when you install the cam in step17. It does a poor job explaining that these three steps are linked and rotating the crank between these steps could result in your distributor indexing being off.
The second book avoids this problem by installing the distributor drive gear and distributor AFTER the case (crank + cam) has been assembled into a short block. This slightly increases the risk you could drop one of the distributor drive spacers down into the case and have to re-open the case to retrieve it. My only issue is many of the key details and specs for the rebuild are in the description of the pics and not the text of the pages. That may just be a personal preference of mine.
In the end, both are good references for rebuilding an engine.
I would also suggest getting a copy of the proper Bentley manual for your Beetle/VW model year. If you have a question on what the spec is for any portion of the rebuild I find it often easier to search and find it in the different subsections of the Bentley than trying to find it in the text or picture descriptions. The Bentley is a better "reference doc" than either of the workflow books. The Bentley also has references to specs for other parts of the car other than just the engine. For example body and suspension specs. _________________ AshMan40
messenger123 Samba Member
Posted: Sun Dec 07, 2025 1:21 pm Post subject: Re: Suggested motor manual for non-mechanic. |
| How to rebuild your volkswagen air-cooled engine can be downloaded as a pdf for free if you want to have a look at it before buying a printed copy. Just do a search for the book name + pdf and you'll find the link. |
baldessariclan Samba Member
Joined: October 14, 2016 Posts: 2214 Location: Wichita, KS
Posted: Sun Dec 07, 2025 1:32 pm Post subject: Re: Suggested motor manual for non-mechanic. |
John Muir’s “How to Keep You Volkswagen Alive” manual is written specifically for non-experienced folks — it’s pretty much the original “train yourself to do your own VW mechanics” bible!
_________________ 1971 Standard Beetle — fairly stock / driver
baldessariclan -- often in error, never in doubt... |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 4577 Location: viroqua wi.
Posted: Sun Dec 07, 2025 1:49 pm Post subject: Re: Suggested motor manual for non-mechanic. |
| Non-mechanic? Decent tools #1. The Muir guide can stay in the bathroom.#2 How to rebuild your air-cooled VW. It has the tech specks you need. A lot of good videos on this box. |
Posted: Sun Dec 07, 2025 1:59 pm Post subject: Re: Suggested motor manual for non-mechanic. |
| bsairhead wrote: |
| ... A lot of good videos on this box. |
Oh, this reminds me... the BugMe video Volume3 is also a good reference. Some people absorb info better watching rather than reading.
Type 1 Complete Engine Rebuild
You might be able to find the BugMe videos at your local library. You can also find the DVDs for sale at some of the online retailers.
https://www.chirco.com/vw-videos-bug-me-tech/
https://www.mtmfg.com/vw/2353/Bug-Me-Dvds _________________ AshMan40
Rome Samba Member
Joined: June 02, 2004 Posts: 10835 Location: Pearl River, NY
Posted: Mon Dec 08, 2025 7:25 am Post subject: Re: Suggested motor manual for non-mechanic. |
| bsairhead wrote: |
| Non-mechanic? Decent tools #1. #2 How to rebuild your air-cooled VW. It has the tech specks you need. |
I've used the Compleat Idiot manual since a neighbor bought it for me when I was a teenager (over 50 yrs ago) and had my first VW. The "How to rebuild..." has many photos, which I feel are an excellent reference for a first-time rebuilder to compare his engine to the respective photos. It also has good section on component assessment during and after tear-down, again with many photos. Finally, the rebuild sequence is from the "inside-out" just like what a builder would do on his/her engine. The Bentley manual is the ultimate for exact specifications and wear measurements (^ the #1 tools come into play), but the sequence of the components are scattered.
I have noticed minor discrepancies in torque specs in the "Rebuild" manual compared to those in the Bentley (accurate). |
2type2 Samba Member
Joined: June 02, 2002 Posts: 1227 Location: SW Colorado
Posted: Mon Dec 08, 2025 7:49 am Post subject: Re: Suggested motor manual for non-mechanic. |
Despite there being an awful lot of misinformation and misguided advice doled out on the web, ! I have found that perusing--- and carefully choosing--- yutube vids has been beneficial. I have books I often refer to before/during a procedure since my memory seems to be shot.
But my point is-- watch educational and entertaining vids about your current or ongoing projects INSTEAD of mindless trash on tictok or fb or reddt while you are wasting life on screen time. You'll end up saving time , money and exasperation while you (almost subconsciously) improve your basic skills. That's a nickle's worth now that 02 is out of production.But if you round down it's nothing,lol. _________________ "A life of peace and happiness depends on your own gratefulness" |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36455 Location: Conejo Valley, CA
Posted: Mon Dec 08, 2025 8:55 am Post subject: Re: Suggested motor manual for non-mechanic. |
One of the changes since most manuals were written (including Muir's) is that parts are more variable today. You can't just bolt it together and expect it to last. This is where "feel" comes in.
I hear there is a good VW community in the Tucson area, so I would seek out local clubs and find an engine guru who will guide you in person. no book or video can replace an experienced engine man showing you the proper feel when checking fit.
But for books, a combo of Muir, Bentley, and Wilson is a good start. _________________ Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback |
Tridentine Samba Member
Posted: Mon Jan 05, 2026 9:05 am Post subject: Re: Suggested motor manual for non-mechanic. |
above poster is right about "feel".
These books are well written and do explain how to fix and maintain these cars as best as a book can.
However there is no replacement for having a patient mentor over your shoulder as you feel how the parts go together and hear how a healthy engine sounds as it idles, accelerates, and starts.
lock in with your local VW scene post haste. |
