Pedal release for cruise control
Red Ryder
Red Ryder is offline
PostPosted: Thu Dec 04, 2025 1:00 pm    Post subject: Pedal release for cruise control Reply with quote
I am pleased to report that Scarlett still has a working factory cruise control! Well, until yesterday. The small clip on the brake (or clutch) pedal arm that pushes against the plunger of the CC switch broke. Anyone have one in their parts bin they are willing to share? Not looking to replace the whole switch with the GoWesty offering (at least not yet). Part 29 in the diagram below.
“Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
“Scarlett” — 1990 Vanagon Carat Wolfsburg Edition (Tornado Red)
“Nigel” — 1999 Jaguar XK8 convertible (Alpine Green Metallic)
Chootrain470
Chootrain470 is offline
PostPosted: Thu Dec 04, 2025 2:46 pm    Post subject: Re: Pedal release for cruise control Reply with quote
FYI, I know you are not interested, but I replaced mine with the Gowesty switch. It took less than an hour and I am slow at such things. Works perfectly.
Red Ryder
PostPosted: Thu Dec 04, 2025 3:21 pm    Post subject: Re: Pedal release for cruise control Reply with quote
Thanks! Glad it worked well for you. I know it replaces the electric operation of the original factory switch. What did you do with the associated vacuum tubing? Also, a functioning original switch is almost unobtainium. Did you sell yours?
Chootrain470
PostPosted: Thu Dec 04, 2025 3:49 pm    Post subject: Re: Pedal release for cruise control Reply with quote
The Gowesty kit eliminates the vacuum line the goes to the front of the van completely. I kept the original switch in a spare parts bin just in case, but it didn't function anyways. On the diagram, the hose #21 just goes from the pump directly to the diaphragm now (#23, 20, 25 eliminated)
kamzcab86
kamzcab86 is offline
PostPosted: Thu Dec 04, 2025 4:55 pm    Post subject: Re: Pedal release for cruise control Reply with quote
Dropped from the VW parts bin in 2007... not available new unfortunately.
I can't find a picture of it, but perhaps you could fabricate something similar? Kind of like what's shown on this page (albeit for a Subaru conversion): http://subaruvanagon.com/tom/Cruise%20Control.htm (just realized, it's Tom Shiels' site!).
2016 Golf GTI S
Red Ryder
PostPosted: Thu Dec 04, 2025 6:36 pm    Post subject: Re: Pedal release for cruise control Reply with quote
This “H-shaped” part sits over the brake pedal arm like a saddle. One leg broke off but I might be able to effect a repair.
Red Ryder
PostPosted: Thu Dec 04, 2025 6:39 pm    Post subject: Re: Pedal release for cruise control Reply with quote
Duplicate.
latelogan
latelogan is offline
PostPosted: Thu Dec 04, 2025 6:50 pm    Post subject: Re: Pedal release for cruise control Reply with quote
FWIW:
My brake switch vacuum section failed. I just plugged the tube that runs up front at the tee in the engine bay near the vacuum pump.
Electrical part remains working fine for me
1991 Westy stock 2.1 auto transmission
1978 Westy (Sold)
1971 Westy (Sold)
MarkWard
MarkWard is offline
PostPosted: Fri Dec 05, 2025 9:36 am    Post subject: Re: Pedal release for cruise control Reply with quote
latelogan wrote:
FWIW:
Dumping the cruise vacuum at the clutch or brake pedal was a quicker way to release the throttle and a fail safe if the electronics failed to slow the engine.
Seems a simple tab could be added to the pedal above to operate the switch. It could be bolted or welded.
Red Ryder
PostPosted: Sat Dec 06, 2025 11:17 pm    Post subject: Re: Pedal release for cruise control Reply with quote
Successfully created a replacement right-angled tab from another (non-Vanagon) project. Used a 3M double-sided pad to adhere the L-shaped part to side of the brake pedal arm. Then added a large spring clip on the bottom side of the arm for additional strength. Trying to drill into the cast arm seemed a fool’s errand.
MarkWard
MarkWard is offline
PostPosted: Mon Dec 08, 2025 7:17 am    Post subject: Re: Pedal release for cruise control Reply with quote
Glad you sorted it. If the adhesive doesn’t hold up, I’m pretty sure the pedal is mild steel and fairly easy to drill. Do an 1/8” pilot hole with a sharp bit and follow up with the bit that matches your fastener. Thanks for reporting back. As time goes on, we need to get more innovative when parts are NLA. Maybe post up a picture of your fix for others.
Red Ryder
PostPosted: Mon Dec 08, 2025 3:16 pm    Post subject: Re: Pedal release for cruise control Reply with quote
MarkWard
MarkWard is offline
PostPosted: Tue Dec 09, 2025 5:20 am    Post subject: Re: Pedal release for cruise control Reply with quote
A result. Thank you.
