Engine parts
Hayden74SB
Hayden74SB is offline
PostPosted: Tue Dec 09, 2025 9:38 pm    Post subject: Engine parts Reply with quote
What suppliers are recommended to get the best mix of lower cost without too much sacrifise to quality?
We are doing a top-end overhaul of our new to us 73 Super Beetle. This is primarily to fix some significant oil leaks including at the base of jugs #1 and #3. We also are doing it to give my Son-in-law some hands-on wrenching to learn more about how these things work.
Other than the oil leaks, the engine ran well. We checked the warm engine compression and got the following results.
#1 – 140psi
#2 – 135psi
#3 – 144psi
#4 – 145psi
Are these pressures normal or is this higher than a stock engine should have. FYI, I forgot to hold the throttle open when testing.
After pulling the cylinders, I checked the conn rods for play and could not feel any. The oil was pretty black but there was no sign of any metal or grit.
We would prefer to not split the case if not necessary. Is this a fools errand?
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Yesterday 6:21 am    Post subject: Re: Engine parts Reply with quote
All you need is a gasket set... with that compression. Just keep pistons with the cylinders.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
baldessariclan
baldessariclan is offline
PostPosted: Yesterday 9:46 am    Post subject: Re: Engine parts Reply with quote
It's the old "good, quick, cheap -- pick any two" sort of deal. You'll have to decide which aspects are the most important to you, and then choose accordingly.
If you're primarily wanting "quick & cheap", vendors like "JBugs", "Cip1" and similar are very popular. Just don't expect all the stuff they send you to fit right, work right, and/or last long -- caveat emptor...
If you prefer "quick & good", some reputable options to consider are vendors like "Wolfsburg West", "West Coast Metric" (for rubber & seals), "Bug City", "VWNOS", Samba classifieds, etc. Be prepared for eye-watering prices in some cases though -- "buy once, cry once"...
Finally, if "good & cheap" are your game, then sources like swap meets, Samba classifieds, eBay sellers, small local shops & junkyards, etc. can all be viable opportunities. You need to know what you're looking for and at to get good deals on reasonable/high quality parts, though. And of course be willing to invest the necessary time + effort to wait for / search out good prospects.
Bobs67vwagen
Bobs67vwagen is offline
PostPosted: Yesterday 9:51 am    Post subject: Re: Engine parts Reply with quote
If you are just resealing everything, cip1 has a complete Eleing German gasket set with flywheel seal(you want the orange one so ask if that is the one included) for around 30 dollars.
pondoras box
pondoras box is offline
PostPosted: Yesterday 10:12 am    Post subject: Re: Engine parts Reply with quote
Just use some sealant, not RTV silicone, but aviation style gasket sealer at the base of the cylinders. Stretch the original push rod tubes to get the squish to seal them. Use a bit of the aviation sealant on the beveled edge of them. Reassemble and adjust valves etc.. maybe rebuild carb. Reinstall everything with new seals check crankshaft end play. Don’t replace good parts with cheap aftermarket stuff.
1961 23 Window (Bobo)
1965 13 Window (Lucas)
1957 Oval ragtop
1960 hardtop
1964 hardtop
1965 hardtop (Arschloch)
1973 standard bug (Dirty Gertie)
https://www.thesamba.com/vw/forum/viewtopic.php?t=804912
1988 Cabriolet VR6 conversion
