Rear rubber mat alternative?
zoti
zoti is offline
PostPosted: Tue Dec 09, 2025 9:18 pm    Post subject: Rear rubber mat alternative? Reply with quote
I’m bringing my 62 back to life and decided to go with rubber mats like the original. Unfortunately, no one has the rear rubber mats in gray so I will need to find an alternative until I hopefully find one.
I have the old original which is all torn up and nasty. I might just tape it up for now but it kind of ruins it all when I put all
That effort to make the car nice.
Any ideas?
1962 Beetle
1979 Super Beetle Convertible
1988 Vanagon Westfalia
rcooled
rcooled is offline
PostPosted: Tue Dec 09, 2025 9:38 pm    Post subject: Re: Rear rubber mat alternative? Reply with quote
zoti wrote:
Any ideas?
Have you tried deep cleaning the mat using steam and/or some citrus-based cleaner? It looks to still be in pretty good shape and that one big tear will be mostly hidden down between the tunnel and the seat.
Maybe a set of coco or sisal mats can help hide the damage and protect the front mat as well.
'63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
zoti
zoti is offline
PostPosted: Tue Dec 09, 2025 9:48 pm    Post subject: Re: Rear rubber mat alternative? Reply with quote
rcooled wrote:
zoti wrote:
Any ideas?
It’s completely torn up to 3 pieces.
I am thinking of getting some cheap gray carpet from Home Depot and tracing the shape of the mat on it so I can use that temporarily.
1962 Beetle
zerotofifty
zerotofifty is offline
PostPosted: Tue Dec 09, 2025 11:32 pm    Post subject: Re: Rear rubber mat alternative? Reply with quote
A scrub brush and some 409 cleaner may make that matt look much better.
then put some carpets over it to protect it. orignal is always cool.
Nice car!
Sorry About That Chief.
Give Peace a Chance.
Words to live by.
OldSchoolVW's Premium Member
OldSchoolVW's is offline
PostPosted: Tue Dec 09, 2025 11:51 pm    Post subject: Re: Rear rubber mat alternative? Reply with quote
Any ideas?
Buy a second set of front mats in gray and use the old rear mats as a template to cut a piece for the rear out of the new front mats. Color and texture will then match the front.
Tom
"Following distance is proportional to IQ."
"It's okay to think."
"If you don't do it this year, you'll be one year older when you do." Warren Miller
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback
finster
finster is offline
PostPosted: Wed Dec 10, 2025 5:04 am    Post subject: Re: Rear rubber mat alternative? Reply with quote
I've had good results using lexol vinylex on rubber mats after a good clean. it makes them supple again. other rubber cleaners and rejuvenators are available
stale air
stale air is offline
PostPosted: Wed Dec 10, 2025 5:30 am    Post subject: Re: Rear rubber mat alternative? Reply with quote
Im guessing your front is from WW. Maybe clean, and run your og rear til WW gets the rears back in stock. Then at least they would match down the road.
zoti
zoti is offline
PostPosted: Wed Dec 10, 2025 8:37 am    Post subject: Re: Rear rubber mat alternative? Reply with quote
Any ideas?
That's actually not a bad idea.
1962 Beetle
zoti
zoti is offline
PostPosted: Wed Dec 10, 2025 1:00 pm    Post subject: Re: Rear rubber mat alternative? Reply with quote
I decided for now to just get some cheap floor mat from Home Depot and use my old rubber mat as a template to cut the mat.
Worked really nice. Simple solution for now.
1962 Beetle
zerotofifty
PostPosted: Wed Dec 10, 2025 2:24 pm    Post subject: Re: Rear rubber mat alternative? Reply with quote
Nice!!!! looks swell!!!
Words to live by.
PostPosted: Wed Dec 10, 2025 2:31 pm    Post subject: Re: Rear rubber mat alternative? Reply with quote
Thumbs Up
Tom
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback
scottyrocks
scottyrocks is offline
PostPosted: Wed Dec 10, 2025 2:44 pm    Post subject: Re: Rear rubber mat alternative? Reply with quote
That looks great.
– D. Tartt, 'The Goldfinch'
zerotofifty
PostPosted: Wed Dec 10, 2025 3:38 pm    Post subject: Re: Rear rubber mat alternative? Reply with quote
This thread has brought up a very good idea. One can get a very nice carpet with some inexpensive carpet and some brains and elbow grease to cut it into a nice shape
I wager that this carpet cost very little compare to a ready made one.
And it looks great too.
Fixing the Bug nicely need not break the bank.
Words to live by.
Bobs67vwagen
Bobs67vwagen is offline
PostPosted: Wed Dec 10, 2025 4:42 pm    Post subject: Re: Rear rubber mat alternative? Reply with quote
Nice solution even if only temporary. Maybe use that as padding under the grey mat when it eventually is available.
zoti
zoti is offline
PostPosted: Wed Dec 10, 2025 9:02 pm    Post subject: Re: Rear rubber mat alternative? Reply with quote
It was $27.50 at Home Depot but it’s much thinner than the ones I got from WW.
https://www.homedepot.com/p/TrafficMaster-Unbound-.../202800194
1962 Beetle
