boxer74 Samba Member
Joined: July 03, 2011 Posts: 873 Location: Ontario, Canada
Posted: Thu Jul 08, 2021 5:28 am Post subject: Re: 1915 Build Suggestions |
| Alstrup wrote: |
If anyone is interested, I have the proper throttle arms for CSP linkage and DCNF.
Details on these arms? _________________ 74 Super
84 Westy |
Posted: Thu Jul 08, 2021 6:55 am Post subject: Re: 1915 Build Suggestions |
| Brian_e wrote: |
| The only air filters around are the thin stamped tin chromed ones. |
What about these?
https://www.ebay.com/itm/272543944409 _________________ 74 Super
84 Westy |
Brian_e  Samba Member
Joined: July 28, 2009 Posts: 4317 Location: Rapid City, South Dakota
Posted: Thu Jul 08, 2021 8:44 am Post subject: Re: 1915 Build Suggestions |
Those would be far better than the stamped chromies. The large filter will make it really tight around them when trying to adjust, but they should work well.
Brian _________________ So more or less the lazier and stupider you want to be, the nicer quality parts you need to buy.
-Modok
Narrowed beams, Drop adjustable spring plates, Bus disk brake and IRS kits.
www.type-emotorsports.com
https://type-emotorsports.com/collections/engine-parts |
Posted: Thu Jul 08, 2021 9:55 am Post subject: Re: 1915 Build Suggestions |
| Brian_e wrote: |
Brian |
Just so I'm clear on this, the thicker billet base would make for a tighter seal and prevent un-filtered air from getting in and clogging the idle jets? _________________ 74 Super
84 Westy |
Posted: Thu Jul 08, 2021 10:02 am Post subject: Re: 1915 Build Suggestions |
I'll give them a run first and if I like them over the kads, I'll order the billet filters. _________________ 74 Super
84 Westy |
Posted: Wed Dec 10, 2025 8:54 am Post subject: Re: 1915 Build Suggestions |
Bringing my old thread back to life.
My dual relief AS41 case is with my machinist to be bored for 94's and decked.
I have the following parts to use for the build:
- DPR 69mm CW crank
- DPR balanced stock rods
- DPR lightened flywheel
- This exhaust: https://store.vintagespeed.com.tw/38MM-HEADER-&-SUPER-FLOW-1-9-FOR-BEETLE-57-35-p132807509
- CSP Pacemaker Bluetooth (123 internals) distributor
- CB 2239 (post 2020) and matching lifters (broken in and lightly used) - could go with something else if it makes sense.
Planning to buy a 94mm AA kit.
Looking for suggestions for cam, heads, induction.
Not necessarily planning EFI for this build for now. Thinking maybe some Sherryberg china 40mm IDF copies.
Going for good low end power, nice driver. This is going in a super beetle.
Advice appreciated. Thanks. _________________ 74 Super
84 Westy |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7976 Location: Videbaek Denmark
Posted: Wed Dec 10, 2025 9:07 am Post subject: Re: 1915 Build Suggestions |
| Alstrup wrote: |
| The easy way would be a set of corrected cnc chamber Panchito´s. |
Yes, I reached out to Brian_E about those earlier this year. If he's still offering his work on these, I will likely go that route.
With those, do you think I should stick with the CB 2239, and run 40's? _________________ 74 Super
84 Westy |
Posted: Wed Dec 10, 2025 9:48 am Post subject: Re: 1915 Build Suggestions |
Fixed panchitos would be fine, but I will toss Tims ported 37x32 heads into the suggestion pile. Especially with the smaller 2239 cam.
The Tims heads will be the only real bolt on solution. They will be flycut to your exact spec, and they will be beautifully blended and ported. He also does the manifolds if you send them to him.
-Modok
Posted: Wed Dec 10, 2025 10:01 am Post subject: Re: 1915 Build Suggestions |
| Brian_e wrote: |
Brian |
Going with a different cam isn't off the table yet.
Any other cam recommendations for this build? _________________ 74 Super
84 Westy |
Posted: Wed Dec 10, 2025 10:08 am Post subject: Re: 1915 Build Suggestions |
My idea of the perfect 1915cc engine is pretty much what you have in your parts pile, but add a web 163, 1.3 rockers, Tims 37x32 PORTED heads and 40mm IDF's. Make it 9.0:1 with a .040" deck height, and you will be right up town.
-Modok
Posted: Wed Dec 10, 2025 10:11 am Post subject: Re: 1915 Build Suggestions |
| Brian_e wrote: |
Brian |
Nice. Thanks. What lifters work with the web cam?
Also, when choosing china IDF's, are sherrybergs the ones that people seem to have success with?
My last set of spanish IDF's was crap. _________________ 74 Super
84 Westy |
daveblank Samba Member
Joined: November 07, 2024 Posts: 294 Location: Dallas, TX
Posted: Wed Dec 10, 2025 11:41 am Post subject: Re: 1915 Build Suggestions |
| Brian_e wrote: |
Brian |
Tim is a great guy to deal with. I have his S2 heads for my 2180 & will be ordering the 37x32 for Isaac's 1776 |
Posted: Wed Dec 10, 2025 11:59 am Post subject: Re: 1915 Build Suggestions |
| boxer74 wrote: |
| Brian_e wrote: |
Brian |
My last set of spanish IDF's was crap. |
I run all web cams with CB light lifters.
I have been using IDF's off amazon.
-Modok
Posted: Wed Dec 10, 2025 7:23 pm Post subject: Re: 1915 Build Suggestions |
| Brian_e wrote: |
Something like this?
https://a.co/d/dkuGl4C _________________ 74 Super
84 Westy |
Posted: Tue Dec 16, 2025 6:45 am Post subject: Re: 1915 Build Suggestions |
I'll likely try the amazon IDF 40 clones and Tims 37x32 super stock heads (is it worth paying for the polished option?). Will keep my CB 2239 and matching lifters since they are already broken in.
Going by the rule of 3-5mm smaller than intake valve for venturi size, I'm thinking of the following for a starting point with jetting.
32 venturis
50 idles
135 mains
200 airs
F11 e-tubes
Look ok? _________________ 74 Super
84 Westy |
sled Samba Member
Posted: Tue Dec 16, 2025 11:27 am Post subject: Re: 1915 Build Suggestions |
| boxer74 wrote: |
I'll likely try the amazon IDF 40 clones and Tims 37x32 super stock heads (is it worth paying for the polished option?) yes, for a 1915 its going to need to breathe, and the porting is more important than the polishing. Will keep my CB 2239 and matching lifters since they are already broken in.
32 venturis
50 idles
135 mains
200 airs
F11 e-tubes
Look ok? yes, that looks like a good starting point! |
_________________ drive your split. |
