Cam bearing remains?
slayer61
slayer61 is offline
PostPosted: Thu Dec 11, 2025 10:59 am    Post subject: Cam bearing remains? Reply with quote
So, I was getting ready to mount up the turbo... again, and I pulled the sump for cleaning and found this....
Any chance it's NOT the remainder of a cam bearing shell?
Pray
Cusser wrote:
... Most folks are idiots when it deals with electrical !!!
67rustavenger wrote:
3/4 race cam? What's missing, one of the lobes? Shocked
Paul
'68 Manx clone... Sears??
RLR/Strange brakes
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
Garrett turbo
Tim's stage II turbo heads
MSD Box and distributor
Car Craft turbo header
View user's profile Send private message Send e-mail AIM Address Yahoo Messenger MSN Messenger Facebook Twitter Instagram Gallery Classifieds Feedback
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Dec 11, 2025 11:13 am    Post subject: Re: Cam bearing remains? Reply with quote
Sure is something... it needs to come apart.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
67rustavenger
67rustavenger is offline
PostPosted: Thu Dec 11, 2025 11:44 am    Post subject: Re: Cam bearing remains? Reply with quote
Paul, is this a rebuilt engine or just a top end job?
Sorry to say it but, I would tear it down and investigate where that bearing shell came from.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
slayer61
slayer61 is offline
PostPosted: Thu Dec 11, 2025 12:03 pm    Post subject: Re: Cam bearing remains? Reply with quote
This motor was previously turbo charged and suffered some detonation damage, rings and cylinders
Originally my intention was to replace the damaged parts and the heads that had chambers too small really, to be used for a turbo application.
The small rod ends are still smooth and showed no signs of slop.
Paul
RLR/Strange brakes
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
Garrett turbo
67rustavenger
PostPosted: Thu Dec 11, 2025 12:07 pm    Post subject: Re: Cam bearing remains? Reply with quote
I know your wife heard the head leak while you were out for a drive.
What I didn't see in your thread was weather you did a full build when you replaced the heads or, if you just top ended the engine.
Either way, you need to know where that bearing shell came from before moving any further forward, IMO.
Buy Once, Cry Once!
Zed999
Zed999 is offline
PostPosted: Thu Dec 11, 2025 12:33 pm    Post subject: Re: Cam bearing remains? Reply with quote
How does a shell get out and still look like a shell?
slayer61
slayer61 is offline
PostPosted: Thu Dec 11, 2025 2:42 pm    Post subject: Re: Cam bearing remains? Reply with quote
It was just new Mahle pistons and cylinders and new turbo heads from Greg Tims. I never intended to split the cases. The motor has less than 1000 normally aspirated miles, and I never had any problem with it.
Paul
RLR/Strange brakes
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
Garrett turbo
slayer61
slayer61 is offline
PostPosted: Thu Dec 11, 2025 2:44 pm    Post subject: Re: Cam bearing remains? Reply with quote
That's what I was wondering, that's why I asked the experts Very Happy
Paul
RLR/Strange brakes
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
Garrett turbo
slayer61
slayer61 is offline
PostPosted: Thu Dec 11, 2025 2:47 pm    Post subject: Re: Cam bearing remains? Reply with quote
That's what I was wondering, that's why I asked the experts.
Very Happy
Paul
RLR/Strange brakes
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
Garrett turbo
Zed999
Zed999 is offline
PostPosted: Thu Dec 11, 2025 3:18 pm    Post subject: Re: Cam bearing remains? Reply with quote
Very Happy
Maybe it fell out during case assembly, I can't think of anything else. You know you'll have to split the case whatever.
slayer61
slayer61 is offline
PostPosted: Thu Dec 11, 2025 3:52 pm    Post subject: Re: Cam bearing remains? Reply with quote
Zed999 wrote:
Very Happy
Sadly, yes. Brick wall Brick wall
Paul
RLR/Strange brakes
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
Garrett turbo
Mr. 010
Glenn is offline
PostPosted: Thu Dec 11, 2025 3:57 pm    Post subject: Re: Cam bearing remains? Reply with quote
1000 miles... hows the case? Did the cam tear up the bearing saddle?
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
rugblaster
rugblaster is offline
PostPosted: Thu Dec 11, 2025 4:24 pm    Post subject: Re: Cam bearing remains? Reply with quote
looks like part of the sump screen to me....
'69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
'09 MB E350 '18 MB E400, '65 Plymouth Valiant convertible and a '19 Ford F250 King Ranch (nicer, but dirty, farm truck)
VWoA factory trained line tech 75 till 90 or so
ASE Master Certification
VWoA Assoc. of Quality Technicians inductee (One of 25 in the five state southwest region)
La Confrerie des Chevaliers du Tastevin (San Angelo Chapter)
TCU ......GO FROGS!!!!!!
slayer61
slayer61 is offline
PostPosted: Thu Dec 11, 2025 4:55 pm    Post subject: Re: Cam bearing remains? Reply with quote
I didn't get the case split yet. I was called upon for domestic responsibilities Embarassed
Paul
RLR/Strange brakes
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
Garrett turbo
BFB
BFB is online now
I think we have a winner here.
edge of that thing looks too rounded vs cam bearing being more of a 90, also looks like thing has the same cut / taper as the fingers in the sump screen
Most experts aren't.
raygreenwood
raygreenwood is offline
PostPosted: Thu Dec 11, 2025 5:01 pm    Post subject: Re: Cam bearing remains? Reply with quote
At first I was genuinely going to ask...which part? Because I do not work on many type 1's...and just could not visualize it....but I think he is correct!
Dug around on a few sites:
Ray
Rob Combs
Rob Combs is offline
PostPosted: Thu Dec 11, 2025 5:15 pm    Post subject: Re: Cam bearing remains? Reply with quote
Radius is all wrong for a cam bearing flange.
You should be hearing some stuff slapping (knocking) around in there if anything is missing that much bearing.
Width is just about right to be a part of the oil screen. So is the radius.
And it has scrape marks on it, the kind you get when you push the oil screen up onto the oil pickup tube.
Hopefully that's all it is. Do you have an inspection camera to poke up past the pickup tube bell and take a peek around in there?
Mr. 010
Glenn is offline
PostPosted: Thu Dec 11, 2025 7:08 pm    Post subject: Re: Cam bearing remains? Reply with quote
Give her some fresh "D" batteries amd tell her you'll be back later Wink
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
67rustavenger
PostPosted: Fri Dec 12, 2025 6:56 am    Post subject: Re: Cam bearing remains? Reply with quote
Ray
As BFB and Ray indicate, It does appear to be from the sump screen.
I freely admit my initial assessment was incorrect. Embarassed
Buy Once, Cry Once!
slayer61
slayer61 is offline
PostPosted: Fri Dec 12, 2025 7:17 am    Post subject: Re: Cam bearing remains? Reply with quote
It's not a cam bearing shell! Huzzah! And onwards Very Happy
A special thanks to the forum members for their support and assistance
Paul
RLR/Strange brakes
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
Garrett turbo
