1955 Hardtop Resto - Way to much
Page: Previous  1, 2, 3
lardawge
lardawge is offline
PostPosted: Tue Dec 02, 2025 3:55 pm    Post subject: Re: 1955 Hardtop Resto - Way to much Reply with quote
Some quick updates;
One of the things I am doing with this car, is confirming that ideas work so when I assemble the 54, it goes together as expected. I have been worried about door alignment for a while given I was not sure how they would land when the car is bolted to the pan.
I decided to mount the body to the pan. On doing so, I figured out that the pads at the bulkhead and the beam have the biggest impact on door alignment. Think of the spacing at the bulkhead as a lever to raise and lower the doors.
When I initially bolted it down, I could quickly see that because the front pads were so thick, it caused the doors to be pulled down when tightening the bulkhead bolts. In this case, by a considerable amount. So I proceeded to trim the pads on the top of the front beam by about one-third. It got closer.
The biggest issue is that the pan gaskets for sale currently are made of very flimsy rubber. It compresses almost flat. I needed to get some lift at the bulkhead in order to support the doors. My aim was to get them 1-2mm high in order to give them room to settle.
I needed a rubber strip dense enough to hold the weight and not compress. So I phoned a friend. He suggested I search McMaster Carr, which I did. I ended up finding a 1" strip 3 feet long with varying thicknesses. I ordered three different thicknesses to experiment with.
I ended up with a 1/4" working pretty well. The driver's door is 1mm high, and the passenger is now dead level.
So, to recap. 1/4" rubber strip to replace the front pan gasket. I also trimmed the beam pads to 3/16". It is dense enough that it should last over time. Likely better than what is currently being sold.
Second order of business: test fit the engine. This is a really nice engine that I spent a fair amount of time getting correct.
11/2/54 L227 Strato Silver L275 Light Beige Ragtop - Build Thread
1/7/55 L275 Light Beige - Sold
9/1/56 (57 model) L331 Horizon Blue -Sold
lardawge
lardawge is offline
PostPosted: Fri Dec 12, 2025 11:10 am    Post subject: Re: 1955 Hardtop Resto - Way to much Reply with quote
Updating this thread with the latest. This has officially been posted up for sale here: For sale listing
I have a website with many pictures as well as a parts list. Please hit me up if I missed anything. It may seem like a lot of cash for a project... unless you have done one before.
As stated earlier, if anyone is interested here in SoCal and needs a painter, I can introduce you to the gentleman painting my 54. He is top tier but is willing to work within a budget as well.
Thx!
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Sat Dec 13, 2025 9:26 am    Post subject: Re: 1955 Hardtop Resto - Way to much Reply with quote
Nice website! Looks great!
Jimbo
TDCTDI wrote:
Page 3 of 3
