early Samba Member
Joined: January 19, 2012 Posts: 291 Location: Glen Carbon, IL
BFB Samba Member
Posted: Mon Dec 15, 2025 5:59 pm Post subject: Re: Line bore using a lathe. |
you should actually copy & paste the article or if its a video post it here. not everyone has FB and unless you let FB corrupt everything in your computer system by joining , FB won't let you view FB. _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
Most experts aren't. |
Brian_e  Samba Member
Joined: July 28, 2009 Posts: 4313 Location: Rapid City, South Dakota
Posted: Mon Dec 15, 2025 6:09 pm Post subject: Re: Line bore using a lathe. |
Not sure how they can do the whole line bore that way.
I wanna see what they did on the nose end to hang onto all that weight swinging around. I think they are only trimming the #1 in that video? Maybe not.
Rimco, and lots of others have used the lathe to line bore cases, but they mount the lathe on the carriage, and the bar between centers. Then run the carriage to feed the case into the bar.
Brian _________________ So more or less the lazier and stupider you want to be, the nicer quality parts you need to buy.
-Modok
Narrowed beams, Drop adjustable spring plates, Bus disk brake and IRS kits.
www.type-emotorsports.com
https://type-emotorsports.com/collections/engine-parts |
RWK Samba Member
Posted: Tue Dec 16, 2025 7:42 am Post subject: Re: Line bore using a lathe. |
The case is usually mounted on the cross slide, (need a large lathe) to a fixture,
case is located on the flywheel flange side and or cyl. deck, fixture would look like a large angle plate, boring bar is spun in the chuck supported by tail stock, case is traversed along bar.
This is how I have seen it done, some larger lathes have T slots on cross slide to bolt tooling to. It seems Rimco used to do it that way, not sure tho _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4946 Location: sanger ca
Posted: Tue Dec 16, 2025 12:18 pm Post subject: Re: Line bore using a lathe. |
Notice in the vid there is a bearing in the case, they are modifying a bearing. _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
jbbugs Samba Member
Joined: September 16, 2002 Posts: 2193 Location: Behind the wheel
Posted: Wed Dec 17, 2025 1:43 pm Post subject: Re: Line bore using a lathe. |
It looks like there's a bearing in the case.
Notice the groove?
Just seems like a really bad idea. _________________ Drag bus! http://www.youtube.com/watch?v=s2MOVmKdhX4
69 OG paint Transporter
73' Super Beetle Champcar Endurance Roadracer
Patina my ass, that's a Rust Bucket! |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 4261 Location: San Diego
Posted: Wed Dec 17, 2025 2:00 pm Post subject: Re: Line bore using a lathe. |
I cant imagine how you could get the case, that far away, to run true. Seems wobble would be hard to get rid of spinning it in that manner
early Samba Member
Posted: Wed Dec 17, 2025 2:22 pm Post subject: Re: Line bore using a lathe. |
| chrisflstf wrote: |
| I cant imagine how you could get the case, that far away, to run true. Seems wobble would hard to get rid of spinning it in that manner |
Agree on that. Looks like he's got a counterweight on one side to balance it.
I dunno just thought it was pretty bizarre setup. |
bedlamite Samba Member
Posted: Wed Dec 17, 2025 2:55 pm Post subject: Re: Line bore using a lathe. |
That looks like the hard way.
If you have a lathe and basic knowledge on how to use it, you could build a proper boring bar. |
liquidrush Samba Member
Posted: Wed Dec 17, 2025 6:09 pm Post subject: Re: Line bore using a lathe. |
| As a guy who runs a lathe pretty much daily I can tell you I've had some off-shapen and odd stuff chucked up over the decades. If you can mount up, maintain rigidity and center you're golden. If you have enough lathe you can do some stuff on it. I learn and figure out stuff all the time. Earlier this summer there was an elderly gentleman in the store and he overheard me talking about multiple start threads and how to do it. Turns out he was machinist by trade and long since retired and he offered to teach me how to do it. He was incredibly nice and patient with me, especially when I wanted to use indexable inserts and he wanted to grind bits. I agreed with him about how grinding a hss tool definitely has its place and I showed him the ones I use. He was fine with the carbide, he said he never really used them. . We were back there messing around for almost two hours. There's no better teacher than an older retired machinist. |
