seatown7 Samba Member
Posted: Thu Nov 27, 2025 10:15 pm Post subject: Re: What did YOU do to your van today? |
A before and after for the powder coating of my stove face plate. Installed it today before the holiday feasting began.
_________________ Current Rig: 1987 Westfalia with Subaru 2.2 conversion, Kennedy Engineering adapter plate, Peloquin limited slip differential, Schwenck springs, Rad-Flow shocks, Burley Big Brake front discs, Burley Rear Disc Brake kit, T3 Technique 711 Shifter, 16" Audi wheels, T3 Technique steering reinforcement, T3 Technique HD anti-sway bar, Powerflex bushings, 100w solar panel, Power-Sonic Life-Po house battery, Burley rear swing out spare tire carrier. |
BigPapaV Samba Member
Joined: February 05, 2023 Posts: 81 Location: Long Beach, CA
Posted: Fri Nov 28, 2025 12:14 am Post subject: Re: What did YOU do to your van today? |
Finished adjusting my shift assembly via markward's instructions with the bungie cord and a quarter. All gears are easy to get, and feels SOOO much better.
Before today I had tried the adjustment with my wife's help, but I thought I had read somewhere that the shift shaft elbow should be straight up and down. With that thought I had tried to pre-set or "twist" the rear shaft into this position and lock it down as such. Then when I checked the shifting 1st gear was actually R, and 3rd was 1st.  _________________ 1986 VW 3-knob Syncro Tintop w/ 1992? Suby Legacy 2.2L (KEP install) |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 8555 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Fri Nov 28, 2025 6:09 am Post subject: Re: What did YOU do to your van today? |
| seatown7 wrote: |
…powder coating of my stove face plate…
Beautiful! Very nicely done!
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
jlrftype7 Samba Member
Posted: Fri Nov 28, 2025 6:50 am Post subject: Re: What did YOU do to your van today? |
| dhaavers wrote: |
| seatown7 wrote: |
- Dave |
Agreed...  _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
RicMcK  Samba Member
Posted: Fri Nov 28, 2025 10:16 am Post subject: Re: What did YOU do to your van today? |
Rust repair, sound proofing and insulation.
Repaired the shelf behind the cabinet (at rocker panel). Rust Mort, Por 15, truck bed paint. Bonded in some sheet metal pieces to re make the shelf.
Removed all the fiberglass insulation.
Removed minor surface rust along the seams, and around the service panels(wire wheel, rust Mort / Rust fix, Por 15, truck bed paint).
Applied sound deading mats, and 1/2"open cell foam
Cut and glued single sided Thinsulate.
Fixed Rt rear leading edge quarter panel seam (water ingress into space between the rear of the sliding door and wheel well seam. De rusted, and treated the surface rust.
Cleaned up my Aux battery service panel, and associated wiring (battery ACR...) .
More to come:
Sound mats under cabinets
sliding doors and shelves for the closet.
sound proofing and insulation headliner, sliding door, rear hatch.
Sound mats on the metal on the engine lid area (seams covered with aluminum tape).
New front door, and A/C cabinet speakers
Manis Speed Throttle body. _________________ Rick McK
Seattle
89 Westfalia-2.2L WBX "VINNY"
2006 TDI Jetta
1936 Ford Pick up
70 tin top, 700k mi when sold in 91
58 split window bug - (first car) long gone. |
fxr Samba Member
Joined: December 07, 2014 Posts: 2709 Location: Bay area CA
Posted: Fri Nov 28, 2025 5:52 pm Post subject: Re: What did YOU do to your van today? |
Prophylactically refurbished the Chinese Diesel Heater with a new glow-plug, body temperature sensor and added a tiny drop of machine oil to the fan bearing. All ready for a winter trip or two - Alabama Hills next week.
I also replaced the CR1220 in the Afterburner controller - and spotted why this one appeared to have died within a year - the +ve connection to the circuit board must have been a very dry joint and had finally parted. Re-flowed that and all seems hunky-dory! _________________ Jim Crowther
Vespa GTS 300 |
AlfromNH Samba Member
Posted: Tue Dec 02, 2025 10:07 am Post subject: Re: What did YOU do to your van today? |
Removed a bent radius rod. Took. Some doing…
_________________ ‘88 2wd Auto Westy project |
randolph57 Samba Member
Joined: January 03, 2014 Posts: 37 Location: plymouth,uk
Posted: Sun Dec 07, 2025 2:18 pm Post subject: Re: What did YOU do to your van today? |
Finally finished my Vitrifrigio fridge installation powered by Lifepo4 105 Ah battery fitted behind/under drivers seat.Fridge choice confirmed after meeting 'Sam' at the T3 Busmeet early August at the end of his several month Europe Sabbatical!
Only real thought I had was to attempt to fit Vitrifrigo mounting frame inside original cabinet rebate instead of notching the cabinet where the rubber strip is left hand side. It was tight and I think it has turned out OK plus if next owner (unlikely) wants to return to original it can be done as all original wiring is still in place. Cold beers on demand:)
Posted: Sun Dec 07, 2025 3:06 pm Post subject: Re: What did YOU do to your van today? |
Scarped and brushed all our recent snow off the Vanagon for a drive around town.
We got approximately 8 inches a few days ago, then another 3-4 inches fell last night. Time to dig out the VW before it got snowed in .
The Dunlop Snow Tires are still working well. I had good grip while driving through our Winter Wonderland.
Packed snow, slick tracks on side streets, and cleared main streets. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
campism Samba Member
Joined: September 07, 2007 Posts: 4722 Location: Richmond VA
Posted: Mon Dec 08, 2025 7:44 pm Post subject: Re: What did YOU do to your van today? |
Exacted revenge on the hickory tree that fell and crushed it last winter. We bucked and split and stacked the wood last spring and now that woodstove season is here we're burning that sumbitch. _________________ '87 Westy in Wolfram Grey Metallic, tragically crushed by a falling hickory tree in my own driveway and now gone, leaving me Vanagonless and with no plans to replace it, alas. |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 4661 Location: Now - ABQ NM USA...Base ABQ, NM USA
Posted: Tue Dec 09, 2025 5:12 am Post subject: Re: What did YOU do to your van today? |
| campism wrote: |
| Exacted revenge on the hickory tree that fell and crushed it last winter. We bucked and split and stacked the wood last spring and now that woodstove season is here we're burning that sumbitch. |
Though I more wish you still had your van. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Posted: Tue Dec 09, 2025 7:45 am Post subject: Re: What did YOU do to your van today? |
| vanis13 wrote: |
| campism wrote: |
=D> =D>
Though I more wish you still had your van. |
We're sorry it got taken out of circulation. If we'd been able to proceed with selling it as planned, the van would still be out there making someone's life fun and interesting. _________________ '87 Westy in Wolfram Grey Metallic, tragically crushed by a falling hickory tree in my own driveway and now gone, leaving me Vanagonless and with no plans to replace it, alas. |
bertobarb Samba Member
Joined: September 05, 2024 Posts: 24 Location: Redwood City, CA
Posted: Sat Dec 13, 2025 9:55 pm Post subject: Re: What did YOU do to your van today? |
| Quote: |
| Finally finished my Vitrifrigio fridge installation powered by Lifepo4 105 Ah battery fitted behind/under drivers seat. |
VERY nice! Got my eye on one of those too. |
Posted: Sat Dec 13, 2025 10:59 pm Post subject: Re: What did YOU do to your van today? |
| RicMcK wrote: |
Made cover and added more gutter clamps to my modified Bus Depot Awing.
I just got a Bus Depot awning this summer and have been scheming how to modify it so that it is easier to set up. I'd be interested in more info about what you have done. |
VanTimm Samba Member
Joined: May 04, 2019 Posts: 28 Location: NE Oregon, USA
Posted: Mon Dec 15, 2025 5:05 pm Post subject: Re: What did YOU do to your van today? |
Installed Burley Motorsports Big Brakes on the front of my new-to-me '90 Carat:
I'm hoping that, between the Big Brakes and the added compression of a Suby EJ 2.5 mill, I'll never again experience the anus-clenching thrill of brake fade on a steep and winding mountain grade. Been there, done that--more than once. |
fxr Samba Member
Posted: Sat Dec 27, 2025 12:45 pm Post subject: Re: What did YOU do to your van today? |
Added a rapid jump-start switch.
Background - a few weeks ago we took a trip to Alabama Hills (CA). The first leg past Sacramento to South Lake Tahoe took about two hours, and we stopped for lunch there. The van started OK, but stalled at the exit of the carpark, and it was immediately evident the battery was depleted. Now the problem was that we were blocking the exit - and cars would soon be piling up behind us as finding the jump leads (well hidden at the bottom of the under-seat storage), getting the cover off the van battery and then getting access to the positive of the 300Ah LFP battery took many minutes.
So yesterday I installed a cheapo HF battery kill-switch across the alternator's input to the LFP charger and the LFP positive. The removable key is on a string and hides in the "black hole" between the rear seat and the kitchen cabinetry. Works a treat!
Oh, and the reason the van battery went flat? The bolt that goes through the EJ22 alternator adjuster into the alternator body had sheared through, the alternator eventually flopped down, and the belt just did nothing. It was lucky the battery lasted as long as it did, as stalling halfway down the Hwy50 downgrade into South Lake Tahoe would have created havoc, and we'd have been stranded for ages before a tow-truck could reach us.
The fix - there was an Autozone a few hundred yards away, so went and bought some M6 bolts and while tensioning the alternator belt with a screwdriver as lever, tightened the alternator up directly to the slot. And so it remains quite happily - I won't even bother to replace the adjusting device. _________________ Jim Crowther
Vespa GTS 300 |
Posted: Mon Dec 29, 2025 4:14 pm Post subject: Re: What did YOU do to your van today? |
Sliding Door Curtain Retention
The Problem: The elastic at the bottom of the sliding door curtain has long since given out and the little rings at the bottom corners of the curtain are long gone. So, the curtain hangs into the living space (where inches are precious) and allows prying eyes to see in from the outside.
The Solution: An elastic strap with female end snaps installed at each end and then attached to the male end snaps that are available for use when the short curtain straps that retain the curtains when they are pulled open are unsnapped.
Simple, inexpensive parts from a Craft Store (in this case, Michael's)
Measure out a length of elastic strap, allowing for as much or as little tension as you want and install the snaps at both ends.
Pull the curtain closed and attach the elastic strap. Done! |
cdussault Samba Member
Posted: Fri Jan 02, 2026 2:21 pm Post subject: Re: What did YOU do to your van today? |
This is brilliant! Entirely been trying different solutions for this and this is the best!
| bertobarb wrote: |
kamzcab86 Samba Moderator
Posted: Fri Jan 02, 2026 8:48 pm Post subject: Re: What did YOU do to your van today? |
| cdussault wrote: |
| bertobarb wrote: |
The Solution: An elastic strap with female end snaps installed at each end and then attached to the male end snaps that are available for use when the short curtain straps that retain the curtains when they are pulled open are unsnapped. |
When I made new curtains for my van, I added neodymium magnets to the side and bottom hems, getting rid of elastic (hate it; hate Velcro too). The replacement sliding door curtain attaches to the door when drawn. Can be done with the factory curtain, but will still "drape" a little bit into the living area due to its vertical length; however, you could simply attach magnets to the exterior of the curtain along the door and pillars.
Berto's solution works too!  _________________ 1986 Cabriolet: www.Cabby-Info.com
2016 Golf GTI S
Posted: Sun Jan 04, 2026 7:42 pm Post subject: Re: What did YOU do to your van today? |
| kamzcab86 wrote: |
| but will still "drape" a little bit into the living area due to its vertical length; however, you could simply attach magnets to the exterior of the curtain along the door and pillars. |
I considered magnets. Only slightly more difficult than creating a strap. But what killed it for me was the draping into the living area. And, if I added magnets along the bottom to counteract the draping, when I slid the curtains open they would all attach to each other, making it much more difficult to smoothly close the curtain again.
IMO, the best solution is to re-make the curtains so they attach on inside of the to the window well on the slider door and stay with the door when it opens. Never have understood why I would want the curtains to be separate from the door. In fact, all the curtains should be attached inside their respective window wells. But that is a much bigger job and not cheap. My solution was about $35 and took 5 minutes, including reading the instructions to learn how to use the tool. |
