Electronic ignition ignition wires-the truth?
Backtotheeightiesagain
Backtotheeightiesagain is offline
PostPosted: Tue Sep 02, 2025 12:40 am    Post subject: Electronic ignition ignition wires-the truth? Reply with quote
From looking at a few retailers websites it seems that they do not have are definite facts on what ignition wires to use and why.
Some (powerspark, uk) list use only silicone non copper leads or interference will.....
123 ignition, Denmark/Netherlands said copper is fine.
Each one differing answers but no real evidence.
Maybe bs to 'link sell' new parts you didn't need....
I don't have a degree in electronics or electro magnetic fields but someone out there will!
All the new vw I worked on years ago came with bosch electronic ignition, all with copper wires. Bosch certainly knew back then how to make quality systems. So I like copper. It lasts.
The aftermarket stuff feels cheap.
As I can't find decent OE type 4 leads with the correct ends,
So what is the best performance lead (especially for upgrading to CDI)???
Or is copper still OK?!
dunk
dunk is offline
PostPosted: Tue Sep 02, 2025 1:21 am    Post subject: Re: Electronic ignition ignition wires-the truth? Reply with quote
If using cdi, imo..
Msd for example, don't recommend solid core wires.
So go for low resistance per foot helically wound , you're looking at-
taylor thundervolt 8.2,
msd superconductor,
moroso ultra 40.
Or similar.
If type 1 just buy the taylors from CB. Great price.
You can buy these wires per foot and make your own.
Non resistor plugs would be nice.
Don't forget to remove the resistor from the rotor arm if it has one. The extra power of cdi will burn it out.
mikedjames
mikedjames is offline
PostPosted: Tue Sep 02, 2025 9:06 am    Post subject: Re: Electronic ignition ignition wires-the truth? Reply with quote
In the UK the Accuspark silicone wires sold on eBay for instance have spiral wound cores identical to Taylor Spiro Pro for a lot less money - I have had both types but changed because I am using a wasted spark system and needed different plug ends. Used with points, electronic modules until I gave up on replacing them, points until I gave up on replacing new condensers, EDIS. ..
The 123 is electrically just a points replacement like the in- distributor electronic( hot failure )modules we all get sold with different branding. So the spark energy is the same or slightly less than with points ( the transistors used feed the coil with 1 volt less than points so for some coils the energy stored may be a little less). .So plug wires should all be the same style. Maybe when we all used AM radio you could hear it. Apparently with DAB radio and an engine at 3000 rpm the spark pulses neatly jam it too..
Where the 123 wins is that it has really stable timing with vacuum advance and is well made and new.
Ancient vehicles and vessels
runamoc Premium Member
runamoc is offline
PostPosted: Tue Sep 02, 2025 4:26 pm    Post subject: Re: Electronic ignition ignition wires-the truth? Reply with quote
How you do that? I know the water cooled engines use a rotor arm that has less resistance than the Beetle. Seems soldering a wire on the arm would do the same thing...but removing it? Then what?
Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires
DesertSasquatchXploration
DesertSasquatchXploration is offline
PostPosted: Tue Sep 02, 2025 7:17 pm    Post subject: Re: Electronic ignition ignition wires-the truth? Reply with quote
Tons Performance, screw MSD Taylor Moroso ETC
Key is to have downward travel Preload keep both wheels on the ground at all times once you lift a tire your DONE. Guys worry about clearance instead think of the opposite you want the suspension to drop that tire in the hole and keep you going. A spider for example they keep their body low but their legs can reach pretty far so they don't (bottom out)
dunk
dunk is offline
PostPosted: Wed Sep 03, 2025 2:10 am    Post subject: Re: Electronic ignition ignition wires-the truth? Reply with quote
I wasn't clear, yes.. soldering a piece of wire or brass/copper onto the rotor arm instead of the resistor. Or just buy one without a resistor. I have seen resistor versions burn out. A simple fix when you find it, but very annoying at the time.
oprn
oprn is offline
PostPosted: Wed Sep 03, 2025 3:10 am    Post subject: Re: Electronic ignition ignition wires-the truth? Reply with quote
I am running Ford's EDIS 4 on my type 4 engine. I went down to my local NAPA and bought a set of wires for a mid 80's Ford V8 and picked 4 wires out of the set that closest matched the length I needed.
Done.
runamoc is offline
PostPosted: Wed Sep 03, 2025 6:41 am    Post subject: Re: Electronic ignition ignition wires-the truth? Reply with quote
Ran across this before too. Used a strobe timing light as a 'test' light. Had the flashing light on the coil wire going to the distributor but not on any of the plug wires. Ohm meter confirmed the diagnosis. Cool
PostPosted: Mon Sep 08, 2025 7:47 am    Post subject: Re: Electronic ignition ignition wires-the truth? Reply with quote
Yes taking all that in.
Am already doing the rotor mod, if the solder iron can cope well on that size copper.
I just want to buy leads that work and last a good while. They were made to size, how come it's my job now?! Maybe they are better at crimping properly....
Aren't most of the silicone fancy colour ones carbon core?
That was what people binned in the 1970s.
NGK did years ago excellent blue and clear see through wound ones, if I could get something similar to them then I'd try them.
Ps is that crane Xr700 optical system reliable...?
Or is points and CD I a better option?
PostPosted: Mon Sep 08, 2025 8:04 am    Post subject: Re: Electronic ignition ignition wires-the truth? Reply with quote
MIKEDJAMES
What modules have you got through that bust?
I liked the factory bosch electronic type 4 ignition till bosch gave up making parts/anything useful
/there are no good hall units that last.
I checked and they are ok to 125*c. They seem to fry less in front engine water cooled cars.
In fact I never changed one in them.
Is accuspark better than the others (pertronix etc gone to the dogs now)?
That stuff in bromsgrove store seems more toys r us than O.E.
About 3 different brands for the type 4 leads listed as one confused mess,
then another sort completely actually on the shelf .
PostPosted: Mon Oct 06, 2025 2:38 am    Post subject: Re: Electronic ignition ignition wires-the truth? Reply with quote
I am calling bull on the special plug lead requirements.
An American company with a distributor tester measuring with an oscilloscope doing the R&D for 123 distributors on YouTube said it was possible- but not certain to affect it.
Anyway 123 ignored that and recommend copper.
Am going to adapt a crane fireball Xr700 to replace bosch hall and see what happens.
If anyone has pics or measurements of the shutter wheel disc post .
I'd much appreciate it, ta...
raygreenwood
raygreenwood is offline
PostPosted: Mon Oct 06, 2025 5:44 am    Post subject: Re: Electronic ignition ignition wires-the truth? Reply with quote
Sorry I am late on this reply. Those NGK transparent blue spiral wound wires were fantastic. I ran them with a pertronix module on my type 4 with a pertronix 42kv coil through the 90s. They were excellent, affordable but definitely had a lifespan. I believe it was a heat issue. Typically about 40k miles but that was less than a year for the mileage I was driving in high heat in Texas. But they were inexpensive and I could buy them at Beck Arnley dealers.
The last set I bought was in the early 2000's and I have not seen them in a long time.
Ray
BFB
BFB is offline
PostPosted: Mon Oct 06, 2025 6:32 am    Post subject: Re: Electronic ignition ignition wires-the truth? Reply with quote
I think with any ecm or computer circuitry you're supposed to run resistor plugs, wires, etc. doesnt mean you necessarily have to, but from my understanding they create an emp that can fry the ecms. from what ive been told , if you had an old car and ran just straight copper wire ( not sure if itd have to be bare or not ) you could create enough of a field to disrupt modern cars next to you at a light. true or not? I dont know, sounds plausible though.
ive ran non resistor plugs with quite a few Black Boxes and they've been ok but they are also on rail Buggys & Bajas and not in a closed engine bay which would probably make a difference.
Most experts aren't.
mikedjames
PostPosted: Mon Oct 06, 2025 12:02 pm    Post subject: Re: Electronic ignition ignition wires-the truth? Reply with quote
MIKEDJAMES
I broke an Ignitor 1 by swapping the leads Sad
I bought Powerspark and Accuspark after that and have a collection of not-quite working modules. I even started reverse engineering my collection so I couild identify the mistake in the design. ( I think its a capacitor that gets damaged by being hot and starts making the engine stopped detector circuit malfunction)
vamram Premium Member
vamram is online now
PostPosted: Mon Oct 06, 2025 1:40 pm    Post subject: Re: Electronic ignition ignition wires-the truth? Reply with quote
I've never had an issue w/Compu-Fire that I didn't cause myself (damaging a wire, insufficiently tightening down the hold down bolt on the points plate). I've had Pertronix & Hot Sparks burn out. The latter are truly crap. But I'd buy a Compu-Fire or Accu-Fire (knock-off of the former) w/out a 2nd thought.
'75 Super Le Grande...we hardly knew ye. Sold 2025 for peanuts.
Click to view image
Save the Supers!!
PostPosted: Thu Dec 25, 2025 9:40 am    Post subject: Re: Electronic ignition ignition wires-the truth? Reply with quote
There are a couple of electronic ignitions from FAST.
Formally known as the crane fireball xr700.
I think were american not chinese made.
Im thinking of trying them, if anyone has experience good or bad?
Maybe better than whats let mikedj down severely.....
Ps its optical and requires ballast, so need foolproof rewiring directions.
The add on boxes = CDI ,retaining points seeeeeem better cant warranty that
mikedjames
PostPosted: Mon Dec 29, 2025 1:22 am    Post subject: Re: Electronic ignition ignition wires-the truth? Reply with quote
If you have a distributor with backlash in its drive and centrifugal advance, the advantage of points is that it provides some friction from the points cam follower, holding the backlash at one end of its travel.
If the idle is lumpy, and you get your timing off a sensor in a distributor housing downstream of a timing gear and a dog drive, the engine speeding up and slowing down may cause the timing to bounce back and forwards because of the backlash, ending up with worse timing scatter than driving an amplifier off the points or a CDI off points.
And the backlash induced timing shift can make the idle lumpier too.
jim martin
jim martin is offline
PostPosted: Mon Dec 29, 2025 4:21 pm    Post subject: Re: Electronic ignition ignition wires-the truth? Reply with quote
I run and make my own sets from MSD wires ,have gone through so many other brands and have experienced everything from cylinders dropping out under load to intermittent misfires. I tell you not what you need at hi mph . But Not with MSD wires . Quality product in my opinion.
Off topic .
If you have ever melted caps , rotors ect yes and even with real MSD brand caps and rotors fyi ,you most likely have hi resistance in the secondary ignition circuit. Tighten your gap way down and measure your lead resistance . Hi resistance causes major unnecessary voltage increase and results in excessive heat being generated. You don’t need to run a .028-.035 gap with a cdi ignition. Adding this after a pm , think this way every gap takes voltage to overcome the air gap . If you have a high plug gap and the gap to dist cap to rotor is large you get it . Spark jumping in cap and heat and melting and no spark at plug under load .Tighten that gap down .
B.C's fastest street legal vw , June 2006 Hot VW's feature car 9.81 sec at 145.26mph.
Sponsored by :
LUCAS OIL PRODUCTS http://www.lucasoil.com
KROC head porting services
Dialedinperformance.com
Airspeedparts.com topic http://airspeedparts.com/forums/index.php?topic=914.0
jpaull
jpaull is offline
PostPosted: Mon Dec 29, 2025 11:10 pm    Post subject: Re: Electronic ignition ignition wires-the truth? Reply with quote
Off topic .
Appreciate your feedback and experience. Lots of great points!
This is the difference between people that truly know, and others that just have to post cause they cant keep their mouth shut and feel like they are
doing the world a service by commenting on every thread in sight.
[email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth.
raygreenwood
PostPosted: Tue Dec 30, 2025 7:24 am    Post subject: Re: Electronic ignition ignition wires-the truth? Reply with quote
jpaull wrote:
Off topic .
Can't get too detailed posting from my phone this morning but Jim Martins comment brings up an excellent point.
Along with this thread, one could also add in some detail about/from the thread half a page down about timing scatter.
I have been keeping my mouth shut in threads about timing scatter for years because a certain amount of it.....in my experience.....is well meaning but not well researched conjecture. Yes, timing scatter exists but from the point of view of many a few years back, timing scatter with any and all distributor based ignition is so bad that one MUST go with crank fire.
Sorry, in my experience no. After seeing some timing scatter and cleaning a few easy things up...I find virtually 0 scatter.
It's not really about gear lash at all. Think clearly through what is operating here. The brass gear driving the steel pinion. It's not one single tooth engaged at any one time. It never fully disengages from the brass drive gear as it rotates. Unless you have a really worn, crappy or bent brass gear or a really worn drive pinion.....its not the gear lash. Even with rpm moving up and down, the engine is running in forward motion. It's not removing pressure/contact with the pinion.
However....this rpm oscillation is causing SOME scatter.....because its shifting the pinion VERTICALLY. The biggest MECHANICAL timing scatter is caused by vertical oscillation in the distributor drive pinion and distributor drive shaft.
Put the right shim in. Make sure the pinion to case tolerance is not excessive....and above all tighten up the gap between the drive dog and the distributor body. It really only needs about 0.010" max and can run just fine and even better with about 0.005". This cleans up a LOT of scatter.
Then make sure there is no excessive wear under the upper cam section that is held on to the shaft by the snap ring above. If you have vacuum advance, flatten, clean up , check for wear and tighten up the points plate. I have a whole how to thread on that.
Make sure the pivot points on the weights are not worn, make sure the bushing to shaft tolerance is not excessive allowing "helicoptering" of the shaft.
You do all of this you will have almost imperceptible timing scatter.
But there still is some and it can be bad. All of that is mechanical timing scatter. Electrical timing scatter is its own thing.
Poor connections at wires.....and.....one thing I started checking is that almost any brand of distributor cap.....if you place it on your distributor without locking the clips.....hold it tight and slide it around. The average distributor has 0.030" to as much as 0.040" of slack between tbe diameter of the cap ledge and the diameter of the distributor.
That can cause the rotor tip to be closer or further from the spark contacts....this is higher and lower resistance and variable spark. This is no different that vertical oscillation of the distributor shaft and rotor caused by excessive slack in the shaft, shims and drive dog.
You can see this and feel the effect it causes by putting the engine at high idle and carefully with the cap clipped tight, slide it around to take up the tolerance and watch the timing os illiterate with the light.
Having larger and smaller gaps or higher and lower resistance....anywhere in the stack up creates heat and timing variation as Jim Martin is speaking about.
One thing I will be doing at some point is measuring the exact gap distance with a tool I am making from a rotor. Find out how to center it exactly. Find the right spot. Then drill a couple of 2mm holes in the lip of the distributor and install a couple of small set screws to act as exact centering nubs.
Ray
