Flaps & Thermostat…
garym999
garym999 is offline
PostPosted: Mon Jan 05, 2026 12:20 pm    Post subject: Flaps & Thermostat… Reply with quote
So I have not been on the scene for that long (4 years now) so every day is a school day. When we first got the bus it ran rough and to cut a long story short I ended up buying a long block from a well known uk builder.
I soon realised I was missing loads of tinware, flaps, thermostat etc. and set about collecting the pieces. These got installed with the new engine. Which as been running great but I have noticed runs hot on long runs at 60MPH ~3600RPM. Oil gets up to 100-110C.
Although we use the bus all year I now have a little downtime between events so have pulled the engine to give it a once over and check a few things regarding engine temps. The operation of the flaps is one thing another is checking the castings for flashings between fins etc.
I think the thermostat and bracket are correct, 65-75c and operates fine one the bus and with a heat gun.
I brought the flaps and the link as a set at a swap meet but now suspect the link is not correct as it’s fouling and causing ware on the oil cooler bracket. Despite the ware it does not seem to impede operation
The parts did not come with any fixings and I just used washers and circlips but looking through the gallery I now realise that’s not original.
The 13mm of bellows travel relates directly to 13mm of bar/flaps travel although with the links disconnected there is a much greater range of travel available.
Where the link rod connects to the bellows and hooks on to the first flap there is a curved arm on the flap which was slightly bent.
Depending on how it is bent will affect the amount of travel does anyone know how much travel there should be at the flaps and what link arm I should have.
While the engine is out I am considering modifying the doghouse for a type 4 cooler so I will have to mod the link anyway. I also have an APC Venturi ring to fit
1975 South African Fleetline
mikedjames
mikedjames is offline
PostPosted: Mon Jan 05, 2026 12:46 pm    Post subject: Re: Flaps & Thermostat… Reply with quote
What is hot for a bug is not hot for a bus.
Running at 100-110C(212-230F) is quite normal.
I used to run a VeGe 1641 at 122C / 252F, with the bus doing 57-62 mph. With smaller than stock tyres , it gets to 4200 rpm at times.
I bought it a full flow oil filter and additional external cooler - that dropped the temperatures maybe 10 degrees C . With working flaps and all tinware.
Then I damaged that engine and built another for about £600 and some of the old engine, and including an AS21 case I got for £51, which ran the same sort of temperatures until it dropped a valve and bent a rod and put bits of piston everywhere and that was the end of that. Each of the first two engines lasted around 30000 -40000 miles.
Now I have a new-parts engine based on an Autolinea aluminum case, with EMPI rather than stock VW heads and this runs about 10 degrees C cooler with the old engine's tinware and other ancilliaries. The latest engine has taken me another 40000 miles.
After it was run in, I refitted the full flow filtration and cooler, so when the air is about 0 degrees C, you have to drive hard for many miles to see the oil temperature reach 95C. Like this weekend.
Maybe you can bend the rod for the flaps a little more to clear the cooler.
My original thermostat did not fully contract, I found another one mis-described on eBay for £30.
Ancient vehicles and vessels
garym999
garym999 is offline
PostPosted: Mon Jan 05, 2026 1:35 pm    Post subject: Re: Flaps & Thermostat… Reply with quote
Cheers Mike. In an ideal world I think I would like the norm to be more like 80-90 for a bit more headroom. This time of year like last weekend hovering around 2C I can get 100-110. In the height of summer in Europe at 35C getting close to 115-120C and need to manage engine.
I think the engine has always been like this but has only come to light since fitting the worry gauges a year ago. Glad I have though cos it gives me a much better understanding of the engine.
As soon as the oil temps start to pass 85C you can visibly start to see it thin as the oil pressure starts to drop. Below this it’s the recommend 10PSI per 1000RPM. And that’s with a CB Maxi 2 spin on filter and 26mm pump
The stat is fine, fully closes and expands as designed. Since my last post I have pulled the fan shroud. And taken a look at the flaps using the pushrod, 14mm seems to be full travel from the bump stop to vertical. So things seem to be about right.
As per the thread about electronically controlling flaps I’m planning on using a 20mm travel slider pot to monitor the position so moving forward I’ll have some definitive data. Looking simple enough to 3D print a couple of brackets to pick up the motion
mikedjames
PostPosted: Tue Jan 06, 2026 5:42 am    Post subject: Re: Flaps & Thermostat… Reply with quote
The oil temperature needs to reach around 100C fairly regularly to clear out condensationb and the emulsion that forms.
Yes the oil does thin and pressure drops, its expected to, to help control the engine temperature by flowing more through the stock cooler, by bypassing it less at lower pressure.
Provided you are still running around 2-3 bar at speed that should be OK.
What makes me back off is cylinder head temperatures- oil temperature is a slowly changing proxy for the heads. I have CHT sensors in a strange place , normally it reads maybe 10C more than the oil, but on a long hill on a hot summers day, it goes about 30-40C hotter.
dunk
dunk is offline
PostPosted: Tue Jan 06, 2026 7:49 am    Post subject: Re: Flaps & Thermostat… Reply with quote
With respect, I'm interested..
Can you show where you got the info for this statement?!
WATER boils at 100 degrees c... it can evaporate at lower temps fairly easily..
Why does the OIL need to be at 100 degrees c to remove the condensation?
Just get it to 80-95 and drive it for longer, the water will go...
I'm not too sure about buses being ok at 100-110 degrees c either...
Will it do it? Yes... for how long... hmmnnnnn...
Are buses under more load? Yes!... does that mean the characteristics of the engine are now different compared to it being in a bug?! Imo no!.. vw rated type 1 and 2 twin port 1600 engines at the same power level, at the same rpm, with the same compression ratio, etc...
BUT fitted different exhausts, carb jets, distributors, etc to buses to cope with this.. however, the oiling system was the same, the cooler was the same, the internals were the same, it's ability to remove heat, in stock form, was the same.. so they compensated for the buses seeing greater load, with EXTERNAL changes.. the physical specs or constraints of the longblock engine are the same whether it be in a bug, bus, type 3, fridolin, or stationary engine...
Imo. If you built a well thought out motor, and got it to run a constant 90-95 degrees c at your cruising speed, I would suggest you'd be far happier.... for a long time.... easy motoring.
That's easy to say, but not that easy to do...
Yes, of course it'll go higher for short blasts.. but constantly?
This is what "separates the wheat from the chaff" engine builder wise... oil choice, lubrication mods, internal component choice, external coolers, breathing mods, transmission gearing, etc etc.. it all adds up...
I think you're on the right track Gary... good luck with it.
74 Thing
74 Thing is online now
PostPosted: Tue Jan 06, 2026 8:53 pm    Post subject: Re: Flaps & Thermostat… Reply with quote
I had the same problem with where the thermostat rod connects to the flaps that round spring metal was pulled and it would not go back to the original position so I had to purchase a good used flap.
FYI you can use a heat gun or hair dryer to make sure everything moves and fully opens and closes properly before installing the engine into your car.
nogoodwithusernames
nogoodwithusernames is offline
PostPosted: Wed Jan 07, 2026 9:34 am    Post subject: Re: Flaps & Thermostat… Reply with quote
I think I would personally be more concerned with CHT in a bus than oil temp. Oil temps aren't going to drop a seat if they get too hot. Does OP have a thermocouple under the spark plug?
71 Squareback, 1.7l T4 w/ crank trigger fuel and spark
(Conversion thread https://www.thesamba.com/vw/forum/viewtopic.php?t=732508&highlight= or https://shoptalkforums.com/viewtopic.php?f=1&t=151375&sid=f0542d44a322d290c29d6609fac7f215 )
74 914, 2.0L w/ D-Jet
-Derek
runamoc Premium Member
runamoc is offline
PostPosted: Wed Jan 07, 2026 9:42 am    Post subject: Re: Flaps & Thermostat… Reply with quote
So the 'cream' doesn't form on the oil filler cap
Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires
oprn
oprn is offline
PostPosted: Wed Jan 07, 2026 9:43 am    Post subject: Re: Flaps & Thermostat… Reply with quote
Yes but it's a time thing. At 80-90*C it may take several hours to evaporate. How often does anyone do trips of several hours consistently in an old VW today? I can tell you from personal experience that 30 minutes at 110*C in our street Buggy cleared up my foamy oil when 2 hours at 75*C on the previous day did not.
We got 80K miles out of our rebuilt '69 Bay window Bus engine by limiting the oil temperature to no more than 115*C. We just simply drove it by the oil temperature gauge. When it reached 115 we would just back off the throttle so that it didn't go any higher. We normally ran it between 110 and 115 on the highway in the summer. The bottom end of the engine was still in good condition at 80K miles, I stopped driving it because the valves were starting to show wear. The guy I sold it to ran it 2 more years before rebuilding the heads.
garym999
garym999 is offline
PostPosted: Wed Jan 07, 2026 1:50 pm    Post subject: Re: Flaps & Thermostat… Reply with quote
I do regularly drive several hours and have been doing just that,.. backing off until things drop a bit. Would still like to loose 10c if possible.
Flaps look to be in good order but will alter the link bar a bit to stop fouling.
Looked at the heads and they seem to have had a bit of cleaning up from the builder so not much in the way of obstructing casting flashings. Still room for a little more clean up though.
The barrels on the other hand, don't look like they have been touched and there is a vertical rib directly at the point where the air blows down. Effectively the air is directed to between the barrels and not around, so will clean that up. I have been searching pics but don’t see much reference to barrel flashings.
The other option I have with the engine out is to modify the doghouse for a 8 fin cooler instead of the 6 it has now. I have read mixed opinions on this
Murt
Murt is offline
PostPosted: Wed Jan 07, 2026 2:05 pm    Post subject: Re: Flaps & Thermostat… Reply with quote
Not for everyone @garym999
But I am pretty sold on my Andrig set up on my split Bus
Evolution 1 Fan, Velocity Ring, and Fixed Flaps, all OE tins. Admittedly, I do not run the Bus in Winter, and always let it warm up before a drive. I have a remote filter and cooler with a fan, all thermostatically controlled
I have Oil Temp and Pressure gauge, and a Tacho, but not CHT or AFR. It ran cool this summer, not cold Laughing
1966 VW Beetle ‘Jules’
1967 Kombi Splitscreen ‘Barney’
2018 VW Caddy Maxi R Line
2017 Golf GTD saloon
2008 VW EOS 2.0 TFSi
garym999
garym999 is offline
PostPosted: Wed Jan 07, 2026 2:13 pm    Post subject: Re: Flaps & Thermostat… Reply with quote
I do have a APC velocity ring to fit.
Adding an external thermostatically oil cooler would give me the headroom but I don’t really want the added plumbing that goes with it. After all it is a pretty near stock 1600 so shouldn’t need much of an assist
dunk
dunk is offline
PostPosted: Wed Jan 07, 2026 2:48 pm    Post subject: Re: Flaps & Thermostat… Reply with quote
Ok. The condensation on the oil cap imo is irrelevant...
Can anyone find a car manufacturer that tells you "if seen, increase oil temp to at least 100 degrees c to remove condensation from the oil filler cap"?
It doesn't matter how fast it's removed from the crankcase...
Again, is their any official documentation that says it must be removed in a certain time?!
Nobody has ever broken their AIRCOOLED engine, because they saw, or had what they thought was excessive mayo on the filler cap... all engines do it. Its part of the combustion process.. It won't destroy them.
The filler cap is one of the highest points in the breather system.. youre going to see some residue there..
On most aircooled vws, it's on its way through the breather, to the air filter at that point so I'd rather see it there than inside the case!
Anyway..
Gary..
What engine do you have?! What modifications?
You have many options available to try and bring the temp down.. some bolt on, some not..
Thermostat and flaps which you're doing.
Having ALL stock tinware.
Making sure engine bay is sealed as best as possible
Velocity ring.
Industrial tins, if you're not using heat exchangers.
Changing your oil viscosity/type
Changing oil pump if pressure too high, pressure relief springs also can help here...
Deep sump.
External cooler.
Fan belt length.
Pulley size.
Extra cooling ducting/holes in the tinware.
Alternative fanshroud.
Gearbox ratio.
Rear tyres.
Are just a few...
Im sure others may suggest other alternatives also..
And of course checking the engine over for unforseen problems/interesting fixes... as you've been doing!
I'm personally not a fan of the type4 oil cooler mod. Not worth the hassle with so many other better options available. Imo.
Many will recommend that higher overall temps are fine. Thats theyre personal experience.. I'm cool with that.
I'm only recommending whats worked for me. I can't control what engines other people have, what mods they've done, what oil they use, how accurate their temp gauge is!, etc...
Because of this, recommending staying on the safe side of the "range" in which these cool little engines can operate, seems sensible to me.
Again, trying to be specific.. imo 90-95 degrees c... at cruising speed.. which I'm going to say is 3400 to 3900rpm and approx 60-65mph.. should be possible for hours on end without problem. I know this works. Irrespective of engine size, and vehicle.
Other speeds and temps may work! Each to their own:)
Again good luck with it!
dunk
dunk is offline
PostPosted: Wed Jan 07, 2026 2:51 pm    Post subject: Re: Flaps & Thermostat… Reply with quote
Also... add...
Full flow oil filter
New oil cooler
To the above list of possible mods.
garym999
garym999 is offline
PostPosted: Wed Jan 07, 2026 3:45 pm    Post subject: Re: Flaps & Thermostat… Reply with quote
1600 DP
    - All stock tinware with attention to fit. Removing to give a good clean and paint
    - Standard heater boxes
    - VS SS143 exhaust
    - Solex 34 PICT 4 centre mount carb on stock manifold. Heat riser pipe cleaned
    - Flaps and stat (which was working until I dropped it yesterday, Embarassed )
    - New 6 fin cooler supplied with engine
    - CB 26mm Maxi2 26mm pump with spin on filter
    - Both relief valves checked together with spring tension
    - 10W30 oil
    - Stock alternator pulley
    - APC velocity ring to be fitted
    - Plans to fit 4 cyl CHT and flaps position sensor
    - Plan to fit small APC under head centre tins that kept falling out
    - Option to fit 8 fin oil cooler but would need to modify doghouse
    - Deflash heads and barrels
dunk
dunk is offline
PostPosted: Fri Jan 09, 2026 5:38 am    Post subject: Re: Flaps & Thermostat… Reply with quote
garym999 wrote:
1600 DP
    - VS SS143 exhaust
    - 10W30 oil
OK.. I'll offer some suggestions. I'm going for reasonable cost here!
Sounds like you've taken, or are taking, the engine out to sort the flaps and tinware soo..
Once you've sorted your original list..
Look up the "hoover bit" NOT the hoover mod...
from your above pictures it looks like its missing... if your tinware is badly rusted, bent, or you have after market tinware, it may not fit.. But, if you understand what it's trying to do, stop air pissing out BELOW the oil cooler I.e. not passing through it... you can diy something yourself to do the same job!.. a small piece of sheet metal, folded in the right way.. welded, pop riveted, whatever with some foam on it will help greatly.
Whilst youre in that area, re-foam/seal the area around the cooler as best you can, extra foam (generic closed cell foam tape is fine, dont have to use parts from a vw supplier), silver tape... all of it helps. And you don't see it whilst the engine is running. Force the air to pass through the cooler, don't let it get around it. Its seems a small thing, but it will help..
Whilst your working on the tinware, put in a cold air intake, see above. It's just a fanhousing fresh air hose connecting pipe welded into the front tinware on the starter side...this will allow you to connect some fanhousing hose.. I normally tuck/aim it down by the torsion housing.. this will give you extra fresh cool air for the fan to use when at cruising speed. You can adjust how you stick the pipe in the tinware if you cant weld, change the size, cable tie the hose to certain things, direct it a certain way, put wire over the end to stop bits being sucked up, whatever!... but I hope you see what I'm getting at:) the parts needed are cheap, and again it definately helps..
Along with your small cylinder head tins, and the velocity ring... all the above should make a definite difference when you start doing long drives.
For shits n giggles, you could get a shorter fanbelt as well, and have it up your sleeve if you still see problems...
Other things..
I'm not a fan of the maxi 2 pump.. cb stuff is good quality, but holding the filter next to the exhaust is never a good thing imo.. i know they "work", and lots of people use that style, but it is the "cheapest" way of doing it in many ways.. I'd do it the cal-look way, have hoses going through to the inner wing or similar, and get the filter in some air flow. You get a little more oil capacity and a little cooling, and you can protect the oil hoses from the exhaust with heat reflective tubing.. It just works. The plumbing isn't hard. I understand that may be quite an undertaking at this point though.
Why 10w 30 oil?! That's an interesting one to start with on a rebuilt engine...is it synthetic?!
Do you have a stock air filter?
Hope some of that helps!
garym999
garym999 is offline
PostPosted: Fri Jan 09, 2026 1:21 pm    Post subject: Re: Flaps & Thermostat… Reply with quote
Thanks for the pointers Dunk, yes the engine is out.
Stock(ish) oil bath filter. I say “ish” as being a South African bus it came with a high capacity filter but without the preheat and in the UK climate pre heat is definitely needed. It now has a “thing” filter which is the same but with thermostatically controlled preheat.
Since I got the engine (as a long block) I have always used 30W. When I added the spin on filter I switched to 10W30. It’s my understanding that synthetic oils keep the dirt in suspension so the filter can catch it.
I have been thinking of making some sort of heat shield to go over the filter
I don’t think I’m going to change the oil cooler. Whilst I can weld it’s not that neat and I can see that I’d muck up the tinware while trying to extend it.
I do like the idea of the extra hole in the bulkhead tin though and that’s within my capability. It’s easy to play with and block of it’s not needed.
The heads are very clean from flashings which is surprising. The barrels though were not so I have done the tops.
As to the hoover bit, I purchased one a while back but think it’s not needed with my tinware (Mexican I think). But now is the time to check and the new sealing foam has turned up along with a new thermostat after dropping mine during the strip down and bursting it
All the tinware including the fan is dirty with a rough surface mixed in with rust so I plan to clean it all up and paint. I think the fan could do with shimming forwards towards the opening as there as about a 5mm gap
