Official Fuel injection questions thread
Page: Previous  1, 2, 3 ... 57, 58, 59
busdaddy
busdaddy is offline
PostPosted: Sat Oct 11, 2025 6:36 pm    Post subject: Re: Official Fuel injection questions thread Reply with quote
tbenne wrote:
Thanks for the reply. I will check out the bay window forum.
What does "CO" stand for?
Carbon monoxide, it’s the level of gases in the exhaust measured by an exhaust analyzer, the scientific way to set mixture.
Слава Україні!
PostPosted: Sat Oct 11, 2025 9:17 pm    Post subject: Re: Official Fuel injection questions thread Reply with quote
The previous message say PO - Do you mean that?
PO = Previous Owner
tbenne
tbenne is offline
PostPosted: Sun Oct 12, 2025 7:50 am    Post subject: Re: Official Fuel injection questions thread Reply with quote
Thanks for directing me to the bay window forum. The information has provided me with several part numbers for a breather valve which if works on the bay window bus FI engines, should work no problem for my 1975 super beetle. I will likely go with 06A 129 101D.
Here are some links to the threads I reviewed.
https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=20
https://www.thesamba.com/vw/forum/viewtopic.php?t=762858
I was also to find information about adjusting the AFM in addition to using carbon monoxide (CO) for tunning.
https://www.thesamba.com/vw/forum/viewtopic.php?t=687698
https://www.thesamba.com/vw/forum/viewtopic.php?t=397487&highlight=
jwms
jwms is offline
PostPosted: Wed Oct 29, 2025 12:38 pm    Post subject: Re: Official Fuel injection questions thread Reply with quote
EGR Filter or Not?
'79 Beetle Convertible
My EGR lower tubing was removed by a PO and the filter is gone. The top of the lower tube is crushed closed and the muffler flange has been welded closed.
The questions are:
Is it worth buying the filter and going back original, or is the way it is set up now good for performance/economy, etc.?
and,
The filter is available to buy, but I see there is also an "elbow" tube for sale. Do I need to purchase both of these if I go back with the filter or do the tubes on the filter go from the upper mount to the muffler?
A good picture of a complete original lower area would be beneficial...
'72 Westy Camper Tin-Top-Project
'72 Westy Camper Tin-Top-Complete
'79 Tri-Color Black 'Vert'-Fuel Injected-Complete
'29 Ford Tudor Sedan
jwms
jwms is offline
PostPosted: Wed Oct 29, 2025 12:49 pm    Post subject: Re: Official Fuel injection questions thread Reply with quote
EGR Filter or Not?
I just had a thought about this:
The left side of the muffler is lower than the right side. Could it be that the exhaust tubes (heater box) on one side or the other was hit and bent, which caused the lower EGR tube to break and therefore it was taken off and sealed up?
Thoughts on this?
busdaddy
busdaddy is offline
PostPosted: Wed Oct 29, 2025 2:32 pm    Post subject: Re: Official Fuel injection questions thread Reply with quote
The filter likely rotted out, it's not uncommon. The wilting exhaust may be from an offroad excursion, or maybe just wasn't hed up straight when all the nuts were tightened.
The EGR does reduce combustion chamber temps at speed, but a Beetle doesn't work hard enough to damage anything like a bus does, if you don't have to smog leaving it disconnected is likely the better option. It still looks the part from above. If you want it to look 100% correct install the filter but leave the port on the muffler blocked, no worries about it rusting out or leaking like that.
You might want to replace the gasket where the valve meets the plenum with a solid one, that eliminated the chances of vacuum leaks from a faulty valve.
Слава Україні!
jwms
jwms is offline
PostPosted: Wed Oct 29, 2025 2:38 pm    Post subject: Re: Official Fuel injection questions thread Reply with quote
Thanks again, Busdaddy!
It's always run pretty good; I was thinking of replacing it for posterity...
And we don't smog...
jwms
jwms is offline
PostPosted: Wed Oct 29, 2025 2:40 pm    Post subject: Re: Official Fuel injection questions thread Reply with quote
Oh, but if I did replace it, is it just the filter part, or also the other "elbow" too?
jwms
jwms is offline
PostPosted: Wed Oct 29, 2025 2:51 pm    Post subject: Re: Official Fuel injection questions thread Reply with quote
I'm trying to wrap my head around the possible faulty valve. The diaphragm here on this one is still good (hold vacuum and I can hear movement), believe it or not. If the valve faulted open, there's no place for the plenum to get the extra air, as the valve body is sealed to the atmosphere.
The EGR light on the speedo is "on" when starting and immediately goes out. I would say that is normal. I don't know what the light "on" is signifying (what fault), when there is a failure. I'm assuming there's a microswitch in there if it doesn't operate when it is supposed to.
busdaddy
busdaddy is offline
PostPosted: Wed Oct 29, 2025 3:31 pm    Post subject: Re: Official Fuel injection questions thread Reply with quote
The light is controlled by that box mid way in the speedo cable in the trunk, it turns on the light when the service interval is due, 30K miles IIRC. Actual system health has no bearing on what the light does, it's strictly a reminder to have the dealer change the filter.
The diaphragm may be OK now, but some day it could become a vacuum leak, if the system is disabled a solid gasket eliminates all possible points of failure.
From the gallery:
Слава Україні!
Maltboy!
Maltboy! is offline
PostPosted: Wed Oct 29, 2025 4:13 pm    Post subject: Re: Official Fuel injection questions thread Reply with quote
The gasses were corrosive enough to eat completely through the EGR valve pipe on my 76 bug. I got a used one to replace it, but I decided to weld the hole shut at the muffler connection. It looks 100% correct, but no gasses get through. I figure anything that could damage the EGR that badly couldn't be good for the engine. The car runs fine.
76 Super Beetle convertible, Ford Chrome Yellow - body-off restoration, 100% of work done by me
59 Beetle convertible, future project - 25,000 actual miles, original interior
Lost69Convertible
Lost69Convertible is offline
PostPosted: Thu Oct 30, 2025 7:29 am    Post subject: Re: Official Fuel injection questions thread Reply with quote
Hi jwms,
My ‘79 had the EGR disconnected and plugged by the PO in the same manner as yours. My EGR intake tube was crimped closed below the tin. But it wasn’t completely sealed and this caused small backfires when I lifted my foot off the gas pedal quickly. I sealed it completely and the backfires stopped. My engine has been running great for 5 years with the EGR intake sealed.
I bought an EGR filter locally. I plan to clean it up and install it for a stock look underneath. I’ll leave the EGR intake pipe plugged/sealed.
1956 Beetle Ragtop: My Father's car
1969 Beetle Convertible: My first car. I loved it, I lost it, and I never got over it.
1979 Super Beetle Convertible
Maltboy!
Maltboy! is offline
PostPosted: Tue Dec 30, 2025 7:26 pm    Post subject: Re: Official Fuel injection questions thread Reply with quote
Hey busdaddy!
What's the best fix for failed SB PCV diaphragms? Does anyone make an aftermarket replacement?
busdaddy
busdaddy is offline
PostPosted: Tue Dec 30, 2025 9:57 pm    Post subject: Re: Official Fuel injection questions thread Reply with quote
Maltboy! wrote:
Hey busdaddy!
There have been a few who threatened to make some, so far no actual product. Here's the fix if you aren't too concerned with appearance: https://www.thesamba.com/vw/forum/viewtopic.php?t=762858
Or since the Beetle one is part of the air filter this might work: https://www.thesamba.com/vw/forum/viewtopic.php?t=476758&highlight=eec+valve
Слава Україні!
redhot
redhot is offline
PostPosted: Sun Jan 11, 2026 10:01 am    Post subject: Re: Official Fuel injection questions thread Reply with quote
I am considering of converting back my late Super Beetle.
Is there a known list of what is the typical key parts that either is NLA or only used, and releevant items to either service regularly or known to fail "randomly" or frequently - this be extra aware of?
- "Wear" items; e.g. injectors, seals, vacuum and pressure lines etc.?
- "Awareness" items; maybe ECU, Double-relay, S-boot, distributor vaccum pot, maybe some wiring connectors etc.?'
I would not need to care about EGR or VOC (blind of, remove etc.) - but driveability and able to fix without months/years of searching would be good...
busdaddy
busdaddy is offline
PostPosted: Sun Jan 11, 2026 10:56 am    Post subject: Re: Official Fuel injection questions thread Reply with quote
https://ratwell.com/technical/FIAvailability.html
As for failing the only things you really need a spare of are TS2's and double relays.
Слава Україні!
redhot
redhot is offline
PostPosted: Mon Jan 12, 2026 12:53 pm    Post subject: Re: Official Fuel injection questions thread Reply with quote
Thanks!
It seems the page update is some years ago, while gives (along with other pages from same host) a lot of good information!
As I understand it; several items are NLA - with then the Thermo Switch 2 (TS2) and Double Relays being the key ones? Former seems not too bad to source/replicate, latter... a bit worse.
For the first: quick googling: https://germansupply.com/temperature-sensor-bus-75-79-vanagon-80-83-super-beetle-75-79-repro.html
A bit nervous about any rubber/elastomer part, while there are sources of used...
https://www.ratwell.com/technical/TempSensorII.html
https://www.ratwell.com/technical/DoubleRelay.html
busdaddy
busdaddy is offline
PostPosted: Mon Jan 12, 2026 1:23 pm    Post subject: Re: Official Fuel injection questions thread Reply with quote
Nothing has really changed since the last update, used parts are still the best option, much of it is offered in repro but very unreliable, the Samba classifieds are the best option.
The Temp sensor 2 (TS2) is common to most VWFI systems of the 70's, it's not hard to make your own or spoof it too. The relay often burns out a track on the PC board, repairable with solder. Often the cause is a shorted thermo time switch (TTS) or auxiliary air valve (AAV).
Слава Україні!
Page 59 of 59
