Bub Samba Member
Joined: June 10, 2004 Posts: 1302 Location: Central Washington
Posted: Wed Oct 05, 2005 7:27 am Post subject: Metal Dashboard - - ? |
I got a question....I did a search but didn't find an exact answer, so pardon if it's a repeat.
Anyone have any luck stripping the plastic off the dashboard? I've seen a few busses where it's been done and I have 2 bay windows- just wondering what sort of mess it leaves behind.
Bob O |
dembus Samba Member
Joined: February 02, 2005 Posts: 1272 Location: Fleming Island, Florida
Posted: Wed Oct 05, 2005 8:25 am Post subject: |
I stripped this one because it was badly cracked but I still wanted to use the original dash from the 69. I saw one in a pic of a European/Comercial model and I think it looks awsome. I saw one painted black with the upper pad and sun deflector and one painted the same color as the interior metal with the black pad and black sun deflector. I will try to find the pic.
_________________ "Want a little peace of mind, grab the lowest branch and start to climb"
JJ Grey
69 Westy (R.I.P.)
68 Kombi
70 Westy
68 Beetle Sedan
69 Beetle Sedan
68 Deluxe
71 Deluxe
71 HT Westy |
dembus Samba Member
Posted: Wed Oct 05, 2005 8:36 am Post subject: |
Here is a good example from the gallery.
JJ Grey
69 Westy (R.I.P.)
68 Kombi
70 Westy
68 Beetle Sedan
69 Beetle Sedan
68 Deluxe
71 Deluxe
71 HT Westy |
Gary Person of Interest
Joined: November 01, 2002 Posts: 17069 Location: 127.0.0.1
Posted: Wed Oct 05, 2005 8:54 am Post subject: |
dembus wrote: |
That looks really nice. Makes me re-think sending my dash off to get restored/recovered. _________________ West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943) |
jolo Samba Member
Joined: June 02, 2004 Posts: 172 Location: Burlington
Posted: Wed Oct 05, 2005 9:48 am Post subject: |
If I remember correctly, the european ones (or some of 'em) came from the factory with the metal dash. |
panasonic90 Samba Member
Joined: April 13, 2004 Posts: 612 Location: Under the Belgian rain
Posted: Wed Oct 05, 2005 10:16 am Post subject: |
What? your dashboards are not metallic?  _________________ "May the fweem be with you"
Obi Volks Kenobi
74 bay ambulance
type 4 2lt carbs engine |
dembus Samba Member
Posted: Wed Oct 05, 2005 11:09 am Post subject: |
Here is another one. There are factory holes in the passenger side for switches for rt hand drive models. They could easily be plugged with something. I think it is a great way to utilize an original dash and not toss it in the trash. It only takes about a half hour to strip the padding, longer to strip adhesive and sand/paint. Fun project!
JJ Grey
69 Westy (R.I.P.)
68 Kombi
70 Westy
68 Beetle Sedan
69 Beetle Sedan
68 Deluxe
71 Deluxe
71 HT Westy |
sxuxrxf Samba Member
Joined: May 18, 2005 Posts: 1338 Location: Oceanside, CA
Posted: Wed Oct 05, 2005 11:17 am Post subject: |
There was a recent thread about this. From what I have seen, European models may have come with the steel dash with no padding. If you look close at the Bentley manual, you'll see the white westy with a steel dash.
Warning: before you decide to strip the vinyl and foam from your dash look at the backside near the corners. There are vertical slotted holes in the american dashes under the air vents. The cut out areas will need to be filled. I converted my first bus by getting a used dash from the junkyard. This allowed me to strip, fill holes and paint while still driving my bus daily. It's an easy swap (couple of hours) if you're ready ahead of time. To fill the slots you'll need to weld in new metal or use a lot of bondo!
(pic above was added while I was writing-good timing!) _________________ (ignore the X's )
zabo Samba Member
Posted: Wed Oct 05, 2005 11:18 am Post subject: |
open glove boxes look like the only downside _________________ 1960 6 volt sedan- 1978 adventurewagen
–wanted bill spreen atlanta dealer tag frame |
Posted: Wed Oct 05, 2005 11:21 am Post subject: |
The glove box bolts right back on, regardless of padding. With the door on it looks just like the gauge panel. _________________ (ignore the X's ) |
stevemariott Samba Member
Joined: November 09, 2003 Posts: 1103 Location: Portland, OR
Posted: Wed Oct 05, 2005 11:25 am Post subject: |
You can still use the glovebox door on a stripped dash, they were not always equipped with them on the euro dashes though. Here's one I shot locally:
The early dashes don't have those vertical slots, but the later ones do. Various other holes still remain however - one in the center under the radio, a few others on the pass. side, etc. _________________ 1963 Manx copy
1968 Bus |
Posted: Wed Oct 05, 2005 11:26 am Post subject: |
Now seriously, all european bays have steel dashboard. I believe that early bays came with the dashboard in the same color as the body, while late bays had a black slightly rough finish. I could be wrong here, these are just my observations. _________________ "May the fweem be with you"
Obi Volks Kenobi
74 bay ambulance
Posted: Wed Oct 05, 2005 11:30 am Post subject: |
Yep, I gather the same thing. For that matter, all the American ones have steel dashes too... underneath the wonderful vinyl and foam padding  _________________ 1963 Manx copy
1968 Bus |
steponmebbbboom Samba Member
Posted: Wed Oct 05, 2005 3:51 pm Post subject: |
The padding was added for North american markets to meet safety standards for lowspeed collision. |
Posted: Wed Oct 05, 2005 8:28 pm Post subject: |
steponmebbbboom wrote: |
Oh, those whacky Americans. 2mph collisions would require padding  _________________ West Virginia State Board of Education v. Barnette, 319 U.S. 624 (1943) |
Posted: Wed Oct 05, 2005 8:30 pm Post subject: |
FMVSS and CMVSS to be precise. Good for 15mph.
Thanks for stopping by.  |
clyde68 Samba Member
Joined: August 09, 2005 Posts: 62 Location: EXETER,DEVON,ENGLAND
Posted: Thu Oct 06, 2005 8:29 am Post subject: |
Ive been told that only 68 buses came with colour coded dash. Ive got a lhd 69 westy and am thinking of looking for a spare dash to strip and paint while still keeping my original for the future, in case i ever need to sell it. Anyone got one in the uk they want to sell? |
