Crank Ques
corey2120
corey2120 is offline
PostPosted: Thu Oct 27, 2005 12:16 pm    Post subject: Crank Ques Reply with quote
ok i got my crank in today and i was putting on my cam gears and other stuff but i ran into a prob. is it suposed to be extremly hard to put on everything?? it seamed like the gear was to small and everything else i put on. i don;t kno if this is normal or not if you could help me out that would be great. the crank is a CB 76mm and CB straight cut gears and CB crank kit with racer spacer
turboblue
turboblue is offline
PostPosted: Thu Oct 27, 2005 12:28 pm    Post subject: Reply with quote
Heat the gear up on a hot plate.
It'll go right on then.
Dots out!
Sometimes the spacer has to be warmed up too.
Gary
Turbo VW Sand Drag Buggy
"If you don't run into the Devil every once in awhile, you must be going in the same direction!"
chazavw
chazavw is offline
PostPosted: Thu Oct 27, 2005 1:22 pm    Post subject: Reply with quote
mine was a bitch to get on too!!!
i bought a brass hammer so i would not screw anything up......
one of my buddies said afterwards maybe i could have the cam gear machined down just a hair to get it to fit better!
corey2120
PostPosted: Thu Oct 27, 2005 6:39 pm    Post subject: Reply with quote
yeah i broke my cam gear and the crank kinda pissed i had to order all new stuff but what ever its only 179 bucks i am goin to try again with this if it doesn't go on easy i'll try to get it machined down
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Oct 27, 2005 6:49 pm    Post subject: Reply with quote
You have to heat the cam gear. I use a torch. It's made to be a press fit.
Don't machine anything.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
martyrg
martyrg is offline
PostPosted: Thu Oct 27, 2005 6:55 pm    Post subject: Reply with quote
This technique comes from the Tom Wilson book "How to Rebuild Your Volkswagen Air-Cooled Engine."
Put the gear and spacer in a small pan filled with some vegatable oil. You only need enough to cover the gear. Now heat the oil until it starts to show wispy smoke coming off the surface. The gear will now be hot enough and expanded enough to slip easily on the crank. You only get one shot at this - you need to work quickly because the gear cools quickly once it comes in contact with the cold crankshaft. Once you extract the gear from the hot oil you can handle it with a thick leather work glove.
I've used this technique several times and the gear will just drop into place if you work quickly. Good Luck!
corey2120
PostPosted: Thu Oct 27, 2005 7:58 pm    Post subject: Reply with quote
if it cools can i just put it back in and heat it up again?
Mr. 010
Glenn is offline
PostPosted: Thu Oct 27, 2005 8:00 pm    Post subject: Reply with quote
sure can.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
corey2120
PostPosted: Thu Oct 27, 2005 8:07 pm    Post subject: Reply with quote
ok sounds good i don't want to break another gear or crank its costing me to much cash oo can i keep the other cam gear on the cam or should i switch that to
mharney
mharney is offline
PostPosted: Thu Oct 27, 2005 8:17 pm    Post subject: Reply with quote
WTF?? How do you BREAK a crank and gear??
Mr. 010
Glenn is offline
PostPosted: Thu Oct 27, 2005 8:18 pm    Post subject: Reply with quote
BFH
Big F'ing Hammer
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
mharney
mharney is offline
PostPosted: Thu Oct 27, 2005 9:26 pm    Post subject: Reply with quote
Indeed.
