Andy_A Samba Member
Joined: August 10, 2005 Posts: 14 Location: Hamilton, MT
Posted: Tue Dec 06, 2005 8:39 pm Post subject: Front lower shock mount |
| Ok. I was just replacing all the shocks on my 67 microbus, and I got the rear ones on just fine. In the front, the top mount is a bolt that goes straight through the shock and fits fine also. My question is concerning the lower mount. It appears as if I must take out the inner metal bushing of the shock, because on the old shock this inner metal bushing wasn't there. There is just the rubber bushing which connects to the larger shaft of the stud. So, can I just push this inner metal bushing out of the shock? And, how should I go about doing this? Thanks, Andy |
Bongo Samba Member
Joined: December 03, 2004 Posts: 872 Location: Egå, Denmark
Posted: Wed Dec 07, 2005 3:54 am Post subject: |
My method: Vice, dowel, hammer.
Don't know if it's the right thing to do, but there was no way it was going on there with that metal bush. I assumed that the shocks weren't split -only nad that the bush was there for other vehicle types. _________________ 1964 Standard
1962 Single Cab
2002 Golf St.Car |
Andy_A Samba Member
Posted: Wed Dec 07, 2005 7:38 am Post subject: |
| thanks for the reply, that's just what i wanted to hear. So now I can get back to fixing my bus in -5 temps. |
rizzag Now Wut?
Joined: April 19, 2001 Posts: 3131 Location: Keizer, OR
Posted: Wed Dec 07, 2005 8:05 am Post subject: |
NO!!!!!!!!
the old shock bushings are on the lower mounts. they are just stuck there. to get them off use a combo of a rust penetrant, torch, visegrips to grab and swivel and a hammer with a chisel to hit at an angle to push it off. an air chisel works great for that if you have access to one. _________________ flossin, tossin, dippin, and trippin |
Clara  Samba Member
Posted: Wed Dec 07, 2005 8:12 am Post subject: |
| rizzag wrote: |
NO!!!!!!!!
the old shock bushings are on the lower mounts. they are just stuck there. |
I agree, take the old bushing of the shock mount.
I avoid use of a torch here, but am pretty damn good with a grinder,(careful NOT to go through into the stud) or even a file. Having two flat faces to get a vise grip onto is useful. Soaking overnight with PB blaster is also good. Then get the vise grips on the flat faces you filed, and whack it with a hammer to twist the bushing.
Use grease or never-seize on the mount when installing the new shocks! And on the threads of the bolts. Really!!! If you didn't do that with the rear, maybe you might want to. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/
chrome Samba Member
Joined: March 21, 2003 Posts: 746 Location: back in NorCal
Posted: Wed Dec 07, 2005 8:47 am Post subject: |
my methood is usung a neumatic die grinder and cutting a split in the bushing so it will spread apart, then taking a chisell to help spread it and break it free, only takes about 10-15 minutes per side,a dremill will work for this but finding quality disks for them is another story do not remove the bushings from your new shocks !!!! it doesnt work _________________ 65 21 window
57 T1 ragtop
58 ghia vert
68 fastback
73 Thing
74 Thing
54 chevy 210
63 mercury meteor wagon |
Bongo Samba Member
Posted: Wed Dec 07, 2005 9:27 am Post subject: |
I can't figure that. The lower mount on mine has a collar on it which means that it's impossible to get anything other than a flexible material past it. the inner diameter of the bush in the shock was smaller than the outer diameter of the collar, rendering said bush useless. Be interested to hear if anyone else has a similar experience. I appreciate theat there is some flexion which will wear the rubber over time, but the fit is so tight and well greased that I don't see a problem. _________________ 1964 Standard
1962 Single Cab
2002 Golf St.Car |
VWBobby Samba Member
Joined: April 21, 2004 Posts: 1537 Location: Central Oregon Coast
Posted: Wed Dec 07, 2005 10:43 am Post subject: |
Bongo,
The collar you see is probably an old bushing thats fused itself to the lower shock mounting stud. Do you happen to have any pics of the mount? |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3443 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Wed Dec 07, 2005 12:48 pm Post subject: |
| rizzag wrote: |
NO!!!!!!!!
the old shock bushings are on the lower mounts. they are just stuck there. to get them off use a combo of a rust penetrant, torch, visegrips to grab and swivel and a hammer with a chisel to hit at an angle to push it off. an air chisel works great for that if you have access to one. |
Correct.
Happens all the time. Look at it carefully, you may get lucky and the bushing has a split in it already.
I personally use an air chisel to remove the old bushings. takes about 10 minutes a side. |
Andy_A Samba Member
Posted: Wed Dec 07, 2005 7:07 pm Post subject: |
| Well, after school and work I went out and took a look at the bushing. They are both really stuck on there, and i have neither an air chisel or a torch at the moment, so i was a bit stuck, and, it is at least 5 below 0 outside, my garage has no real heat, besides my little propane heater and a mediocre stove, so I was stopped for the night. Thanks to everyone for helping out. Andy |
Bongo Samba Member
Posted: Thu Dec 08, 2005 2:41 am Post subject: |
Just so happens that the beam is on the bench at the mo' so I'll investigate. To be honest, I'll be chuffed if it is an old bush. The mounts are pretty gnarled I have to say. I was thinking about taking them down and welding a sleeve on them anyway. I guess this thread has pushed me in the right direction. Cheers Andy! I sympathise with your temperatures, same here, bloody annoying when you're trying to study something up close and you can't see through your breath! _________________ 1964 Standard
1962 Single Cab
2002 Golf St.Car |
Andy_A Samba Member
Posted: Thu Dec 08, 2005 6:26 pm Post subject: |
| Borrowed an air chisel from work today and man what a difference! It didn't take very long at all with the chisel. Thanks to everyone for their replies, Andy |
rizzag Now Wut?
Posted: Thu Dec 08, 2005 6:54 pm Post subject: |
| Andy_A wrote: |
now take a little emory cloth to the rust on the mount and coat it with anti-seeze. then she will be good for another 30+ years. _________________ flossin, tossin, dippin, and trippin |
bugboy63 Samba Member
Joined: December 11, 2005 Posts: 523 Location: tennessee
Posted: Mon Feb 20, 2006 8:19 pm Post subject: |
well now i don't feel so dumb....
been trying to put new shocks on my 64 westy...
been havin' the same problem
this web site is great  |
Long-roofs Samba Member
Joined: March 20, 2002 Posts: 2384 Location: Millwood, Wa
Posted: Mon Feb 20, 2006 11:27 pm Post subject: |
| bugboy63 wrote: |
Good job in using the Search Button and finding this thread. Seems like everything is here, just have to search. _________________ ---
Trying to keep poor cool
People are talking, the greatness is coming, going to be greater than great, so great, greater than anything ever.
Posted: Wed Mar 08, 2006 8:47 pm Post subject: |
update:
took some liquid wrench spray, 14" pipe wrench, small hammer & alot of patience
...got the old bushings off with a little werk
...got the new shocks on just fine......put a little grease on the studs too... |
DannoT Samba Member
Joined: September 15, 2007 Posts: 249 Location: Up where the air is thin
Posted: Sat Jan 19, 2008 1:42 pm Post subject: can't get old shocks off! |
| My teenage son is in our freezing garage turning the air blue! He's gotten the bolts off the shocks top & bottom on the front of his stock 67 bus, but the shocks won't slide off the studs. He used Knock R Loose & WD 40 but we don't have an air hammer or a torch- just the usual tools. Any advice? Besides soap in his mouth? Thanks, Mom |
DannoT Samba Member
Posted: Sat Jan 19, 2008 1:53 pm Post subject: OOPS |
| Correction- He's gotten the nuts off. I get nuts & bolts mixed, Sorry, Mom |
campingbox  Samba Member
Joined: November 14, 2000 Posts: 10261 Location: Petaluma, CA
Posted: Sat Jan 19, 2008 2:09 pm Post subject: Re: can't get old shocks off! |
| DannoT wrote: |
Use some sort of a prybar to get the shocks to slide off. Most likely you'll be left with the inner metal sleeve stuck on which you'll need to file/lubricate/remove with vise-grips as the above posts describe. |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20963 Location: Sandpoint, ID
Posted: Sat Jan 19, 2008 11:14 pm Post subject: |
I have had to cut the bottom of the shock apart with a grinder, then cut the rubber bushing with a utilty knife, then remove the inner metal bushing with one of the many methods described previously. _________________ Confusious say it takes it takes two wipes to know you need three, but it takes three wipes to know it only needed two. |
