Jake, did you test this OEM shroud?
Page: 1, 2, 3  Next
RIS
RIS is offline
PostPosted: Sat Feb 04, 2006 9:51 am    Post subject: Jake, did you test this OEM shroud? Reply with quote
Just wondering how it stacked up against the others...
http://www.cbperformance.com/catalog.asp?ProductID=1523
Richard Sedoris - VW Performance & Machine - Youngstown, OH
http://rismachine.tumblr.com/
YouTube: https://m.youtube.com/channel/UCfTBCG4I61iVm_ROc8OAuOQ
Instagram: @rismachine
Air Sucker
Air Sucker is offline
PostPosted: Sat Feb 04, 2006 10:51 am    Post subject: Reply with quote
Is that a hose attachment point on the back of the shroud where the oil cooler sits behind?
1971 Super Beetle
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat Feb 04, 2006 10:53 am    Post subject: Reply with quote
Not speaking for Jake, but I don't think that was included in his tests.
And that is a round hose fitting for the outlet of the oil cooler air. It's perfect for a kit car.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Air Sucker
PostPosted: Sat Feb 04, 2006 11:03 am    Post subject: Reply with quote
Can you use OEM cooling flaps with this?
1971 Super Beetle
Mr. 010
Glenn is offline
PostPosted: Sat Feb 04, 2006 11:05 am    Post subject: Reply with quote
I don't see any holes for mounting the flaps, but that can be solved. The rear dog house looks deeper than stock, so the linkage might need to be tweaked.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Air Sucker
PostPosted: Sat Feb 04, 2006 11:15 am    Post subject: Reply with quote
So you just need to drill a few holes then? This seems like an interesting option to the 181 shroud.
1971 Super Beetle
Mr. 010
Glenn is offline
PostPosted: Sat Feb 04, 2006 12:21 pm    Post subject: Reply with quote
Probibly... like I said... you should be able to get some flaps in there.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Banzai KG
Banzai KG is offline
PostPosted: Sat Feb 04, 2006 1:19 pm    Post subject: Reply with quote
The one pictured above from CB doesn't look like it has the holes for the screws to the flaps.
The "Low-Profile" (Puma) Doghouse Fanshroud w/ fresh air outlets that I have on my Ghia has provisions for the OEMs as well as the two other Puma shrouds I have up in the rafters. I am running thermostat and flaps on my engine.
I bought mine as a kit from SCS (Small Car Specialties - Anaheim, CA) back in 1985 and at that time CB Performance (Claude Buggies back then) too also sold them.
You can see on left of the fresh air hose is the screw for the flaps as well as under you can see a partial cutout of the cylinder tin where the flaps swivel.
Jim Kikuchi
Sunnyvale (near San Jose), CA
1964 Karmann Ghia coupe
V.V.W.C.A. - Golden Gate Chapter: http://www.ggcvvwca.org/
B.L.T.N. (Better Late Than Never) late model VW Club (San Jose/Santa Clara, CA): https://www.facebook.com/groups/bltnvw/
NorCal Aircooled Group (NAG) Facebook Goup: https://www.facebook.com/groups/NAGVW/
Mr. 010
Glenn is offline
PostPosted: Sat Feb 04, 2006 1:22 pm    Post subject: Reply with quote
Jim... what took you so long? Wink
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Banzai KG
Yes, that is an hose attachment. I used one of those paper cardboard type fresh air hose connect to that oil cooler outlet and route mine to exit under the engine.
Jim Kikuchi
Jake Raby
Jake Raby is offline
PostPosted: Sat Feb 04, 2006 2:24 pm    Post subject: Reply with quote
I did not test the shroud in question... At that time I could not find one.
Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell"
steel buggin
steel buggin is offline
PostPosted: Sat Feb 04, 2006 8:14 pm    Post subject: Reply with quote
I have tested it and it is the best factory fan shroud you can get other then the DTM I had one on my buddy street car which made 185HP and 173TQ at the real wheel's never had a over heating issue. The best part about the shroud is the 2" exhaust tube for the oil cooler plus the unit is one piece not two like the other oem shround's.
https://www.thesamba.com/vw/classifieds/pix/medium/546322.jpg
Steve Arndt
Steve Arndt is offline
PostPosted: Sun Feb 05, 2006 10:33 am    Post subject: Reply with quote
How did you fix the front tin where the hose from the cooler exits? Did you wels or pop rivit a piece of metal to seal around the hose? (stock rectangle exit, Puma round..)
Steve
Banzai KG
PostPosted: Sun Feb 05, 2006 11:30 am    Post subject: Reply with quote
Steve
Steve, the front tin where the oil cooler exits also has the round hole in which as rubber hose is in conjunction between the two.
I can take a picture of one of the other Puma shroud and front tin that I have and post it here.
Jim Kikuchi
Steve Arndt
PostPosted: Sun Feb 05, 2006 5:47 pm    Post subject: Reply with quote
Routing the oil cooler outlet hose into the heater channel would be slick for easy winter heat.
Banzai KG
PostPosted: Sun Feb 05, 2006 7:23 pm    Post subject: Reply with quote
Here are the pics of the Puma "Low-Profile" doghouse fanshrouds I retrieved from the rafters...
My set of Puma doghouse fanshrouds with the front tin
Bottom and rear view of the Puma shrouds
Bottom view with flaps and Brazilian oil cooler mount
Brazilian doghouse oil cooler mount
Internal directional airflow vanes
Front tin with round oil cooler outlet
Jim Kikuchi
Mr. 010
Glenn is offline
PostPosted: Sun Feb 05, 2006 7:25 pm    Post subject: Reply with quote
Nice Jim... that's a sweet setup.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
67jason
67jason is offline
PostPosted: Sun Feb 05, 2006 7:47 pm    Post subject: Reply with quote
very nice jimmy...when are you going to sell me one of them things?! Very Happy
Mr. 010
Glenn is offline
PostPosted: Sun Feb 05, 2006 7:53 pm    Post subject: Reply with quote
Jason,
CB has brand new ones without fresh air outlets.
http://cbperformance.com/catalog.asp?ProductID=1523
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
67jason
67jason is offline
PostPosted: Sun Feb 05, 2006 8:00 pm    Post subject: Reply with quote
Glenn wrote:
Jason,
thanks glenn, i know and im tempted, but i want heat when the 2110 is done. afterall it is my daily.
This topic is locked: you cannot edit posts or make replies.    Forum Index -> Performance/Engines/Transmissions All times are Mountain Standard Time/Pacific Daylight Savings Time
Page: 1, 2, 3  Next
