Can the genny handle this?
chadwick
chadwick is offline
PostPosted: Sat Mar 25, 2006 12:04 am    Post subject: Can the genny handle this? Reply with quote
Hey guys if im running 2 6x9s in the back a 4x6 in the dash spot and a 12 inch sub powered by a 260 watt amp am i risking any electrical problems. I did a search and some said that just a speaker and a tape deck is risky others said they were running 6 speaker system with beastly amps. Whats the true answer.
vdubman27
vdubman27 is offline
PostPosted: Sat Mar 25, 2006 12:38 am    Post subject: Reply with quote
what is the amp draw on you 230 watt amp? your gen is rated at 30 amps
rloaircool
rloaircool is offline
PostPosted: Sat Mar 25, 2006 8:53 am    Post subject: Re: Can the genny handle this? Reply with quote
Depending on how much power the amp is drawing, your headlights might dim. You might want to add a capacitor.
chadwick
chadwick is offline
PostPosted: Sat Mar 25, 2006 6:18 pm    Post subject: Reply with quote
on the amp it just has a big wide red X it doesnt say anything else imma go on the website and see. what does it have to be below. can it be up to 30 amps or should it be like 25 or 20?
Russ Wolfe
Russ Wolfe is offline
PostPosted: Sat Mar 25, 2006 8:36 pm    Post subject: Reply with quote
If you pull 30 amps off the system, you will eventually drain the battery. 30 amps is the max the generator can do, not the average.
You would not be able to use the head lights, wipers, t/s, ETC.
Gary: OK. Ima poop.
Air_Cooled_Nut
Air_Cooled_Nut is offline
PostPosted: Sat Mar 25, 2006 11:19 pm    Post subject: Reply with quote
230watts for a 12v system is 19.17amps. That means at full peak your amp would be drawing almost 2/3 of the total amperage from your generator. Not sure how the meager charging system would like that abuse. Question
Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Penthouse Sundowner 2.0L; 2015 Audi S5 Cabby w/Stage II APR; '06 Ducati Sport Classic 1000; '14 Ducati Diavel Strada
The First Invasion
Russ Wolfe
PostPosted: Sun Mar 26, 2006 10:44 am    Post subject: Reply with quote
Ohms law: Volt x amp = watt
So, 230watts divided by 12Volt = 19.166666amps
The number that air cooled nut came up with.
Just to show how it is figured.
Gary: OK. Ima poop.
Air_Cooled_Nut
PostPosted: Sun Mar 26, 2006 2:37 pm    Post subject: Reply with quote
Thanks Russ Smile I have the formulas in my PDA. I enter in any two of the values, tap the SOLVE button, and it gives me the third value.
The First Invasion
Russ Wolfe
PostPosted: Sun Mar 26, 2006 3:39 pm    Post subject: Reply with quote
If this was the rants, I would say "f__k PDA's". Too many people depend on them and calculators. Learn to do it in your head. That "calculator" usually doesn't fail until we die.
Just ranting a little.
One of my grandkids can't tell time on a clock hands on it. He's gotta have digital. Schools don't even teach them how to tell time anymore. OR the parents. I ranted on my daughter when I found that out.
Gary: OK. Ima poop.
