Dec. Zwitter floor pan / front seat question...
p4ch00
p4ch00 is offline
PostPosted: Sun Apr 30, 2006 1:03 pm    Post subject: Dec. Zwitter floor pan / front seat question... Reply with quote
I own a Dec. (1952) Zwitter. This is what my floors look like. There are 4 studs through the floor and no seat tracks. Is this correct?
Close-up on the studs on the driver side...
I don't have any seats and am wondering what seats I need to be looking for to match up with what looks to be the original floor pans? If this is not an original floor pan / seat set-up I am going to replace the pan halves...any recommendations?
I do evil things to expensive carz:
www.carolinarodshop.com
sconord
sconord is offline
PostPosted: Sun Apr 30, 2006 6:11 pm    Post subject: Reply with quote
Yes, kind of. They are ment for a wing nut style seat mount.
There is a wing nut which screws into it holding down the mount.
It is an early type seat mount BEFORE the tracks were invented
http://www.thesamba.com/vw/classifieds/detail.php?id=223094
beatleeater wrote:
you're a freaking genius
coolairX2
coolairX2 is offline
PostPosted: Sun Apr 30, 2006 7:26 pm    Post subject: Pan, Pan Reply with quote
That's not totally correct, while its true standard cars pre-date Deluxes 49+ the studs & wing nuts where for standard cars and were produced in parallel for many years. Deluxes had seat tracks if not from the beginning then very early on.
If your car is a standard then its correct. if somehow the standard pans where put in a your Deluxe then obviously it's not right.
I certainly wouldn't take out German standard pans and replace them repro, just weld some tracks in. I suspect your car is a standard and has the correct pans.
-Craig
vw insanity
vw insanity is offline
PostPosted: Sun Apr 30, 2006 10:47 pm    Post subject: seat Reply with quote
I will take some pics and show you what they look like./ I purchased some standard seats and needed deluxe seats instead.
sconord
sconord is offline
PostPosted: Mon May 01, 2006 7:27 am    Post subject: Reply with quote
I have a 51 standard, so I thought that they were all like that.
p4ch00
p4ch00 is offline
PostPosted: Mon May 01, 2006 7:54 am    Post subject: Reply with quote
Thanx for all the help so far...
Are the standard seats adjustable at all?
Once you wing nut them to the floor is that it?
One position?
What keeps the seat from tilting forward durring a hard brake?
From every indication my car looks to be a deluxe car...
What signs am I looking for to tell me standard vs. deluxe when this is pretty much all I have?
Wiggy
Wiggy is offline
PostPosted: Mon May 01, 2006 8:13 am    Post subject: Reply with quote
Does the car have cable brakes? Are there holes in the side of the car where the trim would have gone?
Kevin "Wiggy"
My 58 Ghia Vert
My 51 Split 11G
My 57 Deluxe
My 56 Oval
johnshenry
johnshenry is offline
PostPosted: Mon May 01, 2006 10:11 am    Post subject: Reply with quote
A std sunroof? Be interested to know.
Also, those studs look like they may have been welded in after the fact. Can you get a pic from underneath???
John Henry
'57 Deluxe
'56 Single Cab
banana split
banana split is offline
PostPosted: Mon May 01, 2006 12:09 pm    Post subject: Reply with quote
The easiest way to determine if your car is a standard or a deluxe is to see what kind of headliner it takes. If the body has the little crimping "teeth" for holding the headliner material in place going down the door pillar area, around the rear window etc, then you know it's a deluxe. Standards had a very small headliner that covered the roof area only. All the surounding areas were painted the body color of the car.
Cable brakes would also be a dead giveaway that it's a standard. Here in Canada, all of our standards still came with the exterior chrome body moldings unlike the European standards.
bill may
bill may is offline
PostPosted: Tue May 02, 2006 9:31 am    Post subject: Reply with quote
standard ragtop beetles were produced thru the 1967 model year.
Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617
KantDriveFast
KantDriveFast is offline
PostPosted: Tue May 02, 2006 7:17 pm    Post subject: Reply with quote
Also verify that pan and body VINs match, could be a standard pan/deluxe body?
p4ch00
p4ch00 is offline
PostPosted: Wed May 03, 2006 5:23 am    Post subject: Reply with quote
One position?
Major Woody
Samba Enigma
Major Woody is offline
PostPosted: Wed May 03, 2006 9:02 am    Post subject: Reply with quote
They can be slid back and forth, you just have to loosen the wingnut clamps in order to do it. More work, vs a single lever as in the deluxes.
Hebster52
Hebster52 is offline
PostPosted: Thu Aug 24, 2006 10:57 am    Post subject: Reply with quote
I know this is a bit of an old thread but the standards did only have one wingnut on each side of the seat...
A standard -49:
~Kris~
"The Hebster52" my Hebmuller replica build
The 912ST
The KidVRod project
The 356 Pre-A replica,SOLD
The 1966 Kommanderwagen, SOLD
