p4ch00 Samba Member
Joined: July 29, 2004 Posts: 53 Location: r00t c3l4r, ch41n3d t0 b01l3r
Posted: Sun Apr 30, 2006 1:03 pm Post subject: Dec. Zwitter floor pan / front seat question... |
I own a Dec. (1952) Zwitter. This is what my floors look like. There are 4 studs through the floor and no seat tracks. Is this correct?
Close-up on the studs on the driver side...
I don't have any seats and am wondering what seats I need to be looking for to match up with what looks to be the original floor pans? If this is not an original floor pan / seat set-up I am going to replace the pan halves...any recommendations? _________________ I do evil things to expensive carz:
www.carolinarodshop.com |
sconord Samba Member
Joined: February 22, 2005 Posts: 704 Location: Dallas Texas
Posted: Sun Apr 30, 2006 6:11 pm Post subject: |
Yes, kind of. They are ment for a wing nut style seat mount.
There is a wing nut which screws into it holding down the mount.
It is an early type seat mount BEFORE the tracks were invented
http://www.thesamba.com/vw/classifieds/detail.php?id=223094 _________________
beatleeater wrote: |
you're a freaking genius |
coolairX2 Samba Member
Posted: Sun Apr 30, 2006 7:26 pm Post subject: Pan, Pan |
That's not totally correct, while its true standard cars pre-date Deluxes 49+ the studs & wing nuts where for standard cars and were produced in parallel for many years. Deluxes had seat tracks if not from the beginning then very early on.
If your car is a standard then its correct. if somehow the standard pans where put in a your Deluxe then obviously it's not right.
I certainly wouldn't take out German standard pans and replace them repro, just weld some tracks in. I suspect your car is a standard and has the correct pans.
-Craig |
vw insanity Samba Member
Posted: Sun Apr 30, 2006 10:47 pm Post subject: seat |
I will take some pics and show you what they look like./ I purchased some standard seats and needed deluxe seats instead. |
Posted: Mon May 01, 2006 7:27 am Post subject: |
I have a 51 standard, so I thought that they were all like that. _________________
p4ch00 Samba Member
Posted: Mon May 01, 2006 7:54 am Post subject: |
Thanx for all the help so far...
Are the standard seats adjustable at all?
Once you wing nut them to the floor is that it?
One position?
What keeps the seat from tilting forward durring a hard brake?
From every indication my car looks to be a deluxe car...
What signs am I looking for to tell me standard vs. deluxe when this is pretty much all I have? _________________ I do evil things to expensive carz:
Wiggy Samba Member
Joined: April 17, 2003 Posts: 6606 Location: Downingtown, PA
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9407 Location: Northwood, NH USA
Posted: Mon May 01, 2006 10:11 am Post subject: |
A std sunroof? Be interested to know.
Also, those studs look like they may have been welded in after the fact. Can you get a pic from underneath??? _________________ John Henry
'57 Deluxe
'56 Single Cab |
banana split Samba Member
Joined: January 22, 2002 Posts: 1126 Location: Beautiful British Columbia Canada
Posted: Mon May 01, 2006 12:09 pm Post subject: |
The easiest way to determine if your car is a standard or a deluxe is to see what kind of headliner it takes. If the body has the little crimping "teeth" for holding the headliner material in place going down the door pillar area, around the rear window etc, then you know it's a deluxe. Standards had a very small headliner that covered the roof area only. All the surounding areas were painted the body color of the car.
Cable brakes would also be a dead giveaway that it's a standard. Here in Canada, all of our standards still came with the exterior chrome body moldings unlike the European standards. |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
KantDriveFast Samba Member
Joined: January 08, 2005 Posts: 4293 Location: Caldwell, Id.
Posted: Tue May 02, 2006 7:17 pm Post subject: |
Also verify that pan and body VINs match, could be a standard pan/deluxe body? |
p4ch00 Samba Member
Posted: Wed May 03, 2006 5:23 am Post subject: |
One position?
What keeps the seat from tilting forward durring a hard brake? _________________ I do evil things to expensive carz:
Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9016 Location: Portland, OR
Posted: Wed May 03, 2006 9:02 am Post subject: |
They can be slid back and forth, you just have to loosen the wingnut clamps in order to do it. More work, vs a single lever as in the deluxes. |
Hebster52 Samba Member
Joined: March 14, 2003 Posts: 1903 Location: Finland, Jakobstad
