vwboop Samba Member
Joined: April 04, 2004 Posts: 716 Location: Langley, BC
Posted: Sat Jun 17, 2006 10:28 am Post subject: Can anyone tell if this is a real Manx? |
Just picked this buggy up for $300 from a guy who'd had it for 25 years. He originally got it from an estate sale, and didn't know much about it's history. There's no id tag on it or isn't anymore if there ever was. Thanks for any help.
_________________ "Love and good roads" |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5066 Location: Madisonville, La
Posted: Sat Jun 17, 2006 12:45 pm Post subject: |
Looks definitely like a Manx to me!!! _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
dirtydeedss Samba Member
Joined: November 19, 2005 Posts: 613 Location: Aldergrove BC Canada
Posted: Sat Jun 17, 2006 1:01 pm Post subject: |
| hey boop did that guy have anymore in his yard? |
Yellermanx Samba Member
Joined: November 04, 2004 Posts: 1242 Location: Florida
Posted: Sat Jun 17, 2006 1:03 pm Post subject: |
Possible. Is the dash plastic or is it fiberglass? Although the tube under the side looks correct it looks as if it doesn't go far enough or part of it is missing. How thick is it? Is there a steel bracket under the dashboard as in the left side of the picture below? (the rusty piece just below the dash) Is that the original gelcoat or has it been painted? If it's the gelcoat where the key is pictured it does not look correct. However the buggy sure looks like one.
Jimmler Samba Member
Posted: Sat Jun 17, 2006 2:06 pm Post subject: |
Regardless if it's a real one or not: you got a heck of a deal for $300! Enjoy it and don't worry about authenticity. Mine was made by one of the companies that Bruce Meyers sued! That should make it worth even more, right? _________________ -Jim
Nipomo, CA |
vwboop Samba Member
Posted: Sat Jun 17, 2006 2:22 pm Post subject: |
The dash is black plastic.
When you say how thick is it, do you mean the reinforcing tube or the body itself. The body doesn't seem to be all that thick on the edges.
There is a steel bracket under the dash and a steel tube that seems to run the width just behind the bottom of the dash.
It was painted a blue metalflake and has a few coats of clear that have been discolored/oxidized. Appears to be red underneath
| Yellermanx wrote: |
Posted: Sat Jun 17, 2006 2:28 pm Post subject: |
| The thickness part I was referring to the body itself. The Manx is one of the thicker bodies out there. However I have noticed that some of them are much thicker than others. If it has the plastic dash and the brace that hooks to the side like the one in the picture and has the tube go all the way across as you say I would say you got a good deal on a Manx. Congrats!! |
vwboop Samba Member
Posted: Sat Jun 17, 2006 2:46 pm Post subject: |
Here's a pic of the bar and bracket. I know it was a great deal regardless. Just if it's a real manx we're going to proceed differently than if it's a manx "style" buggy
Thanks again guys.
lostinbaja Samba Member
Joined: December 19, 2004 Posts: 4036 Location: Frankfort, Illinois
Posted: Sat Jun 17, 2006 2:56 pm Post subject: |
Nope...it's not a Manx. I have never seen a authenticated Manx with a string holding the windshield frame up.
It does look awful close to a Manx...with the exception of the string.
Jerry... |
Balboaislandbob Samba Member
Posted: Sat Jun 17, 2006 3:08 pm Post subject: |
and isn't it true that all manx's., except for very few early ones, are clearly marked under the dash?
Still a great find for $300. |
vwboop Samba Member
Posted: Sat Jun 17, 2006 3:51 pm Post subject: |
| lostinbaja wrote: |
Jerry... |
Ya, I guess he got a replacement windshield but never got around to installing it String is definately not OE.
Think I read somewhere the later Manx's (Manx 2's had an ID under the dash) could be wrong though. _________________ "Love and good roads" |
Posted: Sat Jun 17, 2006 4:32 pm Post subject: |
Never heard of any ID under the dash. Just ID tag in rear. There is one more thing you can check that is a Manx trait that not everyone is aware of. However it is not on all of them. On the front of the firewall there is a piece of wood glassed in that was used to lift them out of the mold, it is in the red circle. There is also one in the rear. It is located on the opposite side of the other red circle that is below the ID tag. They look to be about a 3/4" slices of 2x4 glassed in. Bet yours has them.
Posted: Sat Jun 17, 2006 5:51 pm Post subject: |
ok, so in the rear, I understood that the number tags were impressed in the glass, not glued on? Thus if it was a Manx, it would likely have one? and only the very early manx's did not have this impressed number?
I just read in the MAnx forums that the serial # above the access plate |
vwboop Samba Member
Posted: Sat Jun 17, 2006 6:31 pm Post subject: |
| Yellermanx wrote: |
| There is one more thing you can check that is a Manx trait that not everyone is aware of. However it is not on all of them. On the front of the firewall there is a piece of wood glassed in that was used to lift them out of the mold |
I would say this buggy doesn't have either of those. Pretty hard to access those spots.
Does anyone have one handy enough to measure their ID plate. I have an access hole cut right around where I figure there could've been the plate. The ones I've seen were pop-rivited on, and this access hole was cut using drilled(?) starter holes (wondering if some of those holes could've been from the plate pop-rivets). Anyhow, here's a pic. There are two holes on the left roughly 3 cm apart???
Here's a pic of a number plate I found online that was pop-riveted
Posted: Sat Jun 17, 2006 7:26 pm Post subject: |
What's with the big crack down the rear of the tunnel? Looks like it goes right thru the VIN number. That could be a problem if welding is necessary. It would obliterate the VIN. _________________ -Jim
Nipomo, CA |
vwboop Samba Member
Posted: Sat Jun 17, 2006 7:34 pm Post subject: |
He said he had some problems with the shifter (made a real mess of the tunnel). If it turns out to be a real Manx I would like to build up a later beetle pan (IRS and ball joint), and give it a proper resto. _________________ "Love and good roads" |
Posted: Sat Jun 17, 2006 8:27 pm Post subject: |
Balboaislandbob, The ID tags are all pop riveted on as far as I know. You can see it just above the red outlined area in the picture I posted above.
| vwboop wrote: |
| He said he had some problems with the shifter (made a real mess of the tunnel). If it turns out to be a real Manx I would like to build up a later beetle pan (IRS and ball joint), and give it a proper resto. |
In order to use an IRS chassis you have to also use a body lift. In this picture you can see how close the IRS is to the battery box. It is just as close to the spare tire well. You can also see how it put holes in the battery box.
Somehow 2" body lift made about 3" of clearance and now I have no problems. It hits the bump stops first and does not hit the body. This is on a Berrien chassis and I think the other chassis may have had the rear kicked up a bit.
Posted: Sun Jun 18, 2006 4:24 am Post subject: |
Take a closer look at the dash/windshield support. It should look like this one. If it looks like the OE Manx support it is probably a Manx because I haven't seen any other buggys that actually reproduced the support.
vwboop Samba Member
Posted: Sun Jun 18, 2006 7:24 am Post subject: |
That's exactly the support I have. I think I'm convinced, as I don't think anyone would go to the trouble of reproducing everything the same if they were just copying a buggy, and now that I look at it the hole someone cut behind the front seats easily could have housed the ID plate. Shame someone might of hacked it out. It also has the rear supports that come down from either side of the notch at the back (where the liscence plate goes?), and I've noticed some real manxes have the two same little bolts on either side of it.
I'm totally new to buggy's (split bus guy more or less). Just had to stop to check it out, and couldn't pass up a $300 buggy. I'm going to send pics off to see if they'll issue me emblems for it based on what I have.
Thanks again all
That paint should buff out. I will need to exfoliate some of the old clear. I think we will build up a new pan for it (mechanical resto) but leave it old school looking. We may stick to swing axle/king link.
One more thing. It has this little handle inside the front. I thought maybe that could've been used to pull it out of the mold. It is roughly opposite where the glassed in wood would be.
vwboop Samba Member
Posted: Mon Jun 19, 2006 8:54 pm Post subject: |
| Balboaislandbob wrote: |
| and isn't it true that all manx's., except for very few early ones, are clearly marked under the dash? |
Found where I was reading. It was off the Manx club site. Looks like the SR's and Tow'ds have a serial number under the dash:
"2. The serial no. - if it has one
a. Meyers Manx - found on the vertical surface of the fiberglass just above the inspection plate behind the front seats.
b. Tow'd or SR - above the pedals under the dash." _________________ "Love and good roads" |
