Sealing case and cylinders?
Page: 1, 2, 3 ... 11, 12, 13  Next
mrmarcdude
mrmarcdude is offline
PostPosted: Sun Jun 25, 2006 7:38 pm    Post subject: Sealing case and cylinders? Reply with quote
Hey i was wondering what you guys reccomend to seal the two case halfs? Any feedback on a specific product? What to stay away from? Thanks a lot guys
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Jun 25, 2006 7:46 pm    Post subject: Reply with quote
Permatex Aviation will work.
Never ever use any silicone form-a-gasket.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
SeVVenth
SeVVenth is offline
PostPosted: Sun Jun 25, 2006 7:48 pm    Post subject: Reply with quote
I use permatex on just about thing that has the possibility of leaking oil. Make sure to get a decent sized tub, it lasts quite a while. I had to tear my motor totally apart after I just got it together and I haven't even gone through a 1/5 of the bottle.
TristanM
TristanM is offline
PostPosted: Sun Jun 25, 2006 7:50 pm    Post subject: Reply with quote
I use to use Permatex Aviation, but on the last few engines went with Curil-T and will be using it from now on.
Don't Believe The Hype.
SeVVenth
SeVVenth is offline
PostPosted: Sun Jun 25, 2006 7:51 pm    Post subject: Reply with quote
^^Any reason why?^^ Less sticky?
John M.
John M. is offline
PostPosted: Sun Jun 25, 2006 7:56 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=177871&highlight=case+sealant
http://www.thesamba.com/vw/forum/viewtopic.php?t=152551&highlight=case+sealant
http://www.thesamba.com/vw/forum/viewtopic.php?t=134808&highlight=case+sealant
http://www.thesamba.com/vw/forum/viewtopic.php?t=119104&highlight=case+sealant
http://www.thesamba.com/vw/forum/viewtopic.php?t=116079&highlight=case+sealant
http://www.thesamba.com/vw/forum/viewtopic.php?t=81825&highlight=case+sealant
http://www.thesamba.com/vw/forum/viewtopic.php?t=58056&highlight=case+sealant
http://www.thesamba.com/vw/forum/viewtopic.php?t=51440&highlight=case+sealant
Rolling Eyes
TristanM
TristanM is offline
PostPosted: Sun Jun 25, 2006 7:58 pm    Post subject: Reply with quote
I just found it easier to work and less messy...but that is just my preference. I also liked the tube over the brush factor.
Mr. 010
Glenn is offline
PostPosted: Sun Jun 25, 2006 7:59 pm    Post subject: Reply with quote
Gaskacinch
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
The Noof
The Noof is offline
PostPosted: Sun Jun 25, 2006 8:09 pm    Post subject: Reply with quote
Specialty sealers such as Dirko and Yamabond are excellent also.Yamabond is made exclusively for applying to gasketless machined aluminum surfaces.Messy and expensive, but very effective.
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Sun Jun 25, 2006 8:41 pm    Post subject: Reply with quote
I smell the need for a "sticky"! Very Happy
Eaallred
Eaallred is offline
PostPosted: Mon Jun 26, 2006 5:34 am    Post subject: Reply with quote
Think of it this way. If you have 8 case sealers that all work at keeping the case halves dry, but one of them can be cleaned off easily with a paper towel the next time you have to get in there fix something, which do you think you should choose?
That's why I use Curil T. Wink
Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn.
millerje78
Samba Amishman
millerje78 is offline
PostPosted: Mon Jun 26, 2006 3:04 pm    Post subject: Reply with quote
Yamabond definitely keep the engine from leaking oil out of the ordinary spots. (oil cooler seals, sump plate, valve covers) it takes a while to run out of the $8 tube. you just need to make sure you form a perfect furface of the goo, free of debris or air bubbles. It is kind of a pain to get off though when doing maintenance.
.02
always seeking a better way
my 73 standard project
do your research, consult with experts, and buy quality parts. you won't be sorry
steel buggin
steel buggin is offline
PostPosted: Mon Jun 26, 2006 5:05 pm    Post subject: Reply with quote
1211 bond from Japan works great.
SeVVenth
SeVVenth is offline
PostPosted: Tue Jun 27, 2006 1:43 pm    Post subject: Reply with quote
Glenn wrote:
Gaskacinch
You know I looked ALL OVER the damn place for that stuff. Couldn't find it anywhere around here.
polkaudio
polkaudio is offline
PostPosted: Fri Jul 21, 2006 3:37 pm    Post subject: Reply with quote
That's why I use Curil T. Wink[/quote]
where is this available? Very Happy
MCT
MCT is offline
PostPosted: Fri Jul 28, 2006 11:12 am    Post subject: Reply with quote
Loctite 515 or 518, Anaerobic Sealer, I use it on everything I do on Airplanes Piston Aircooled engines and used it on my 1600cc and guess what?
Nice and dry, no leaks, its good for almost anything that needs to be sealed.
66 Bug, 1600cc DP Engine, 12 Volt
miniman82
Samba Swamp Donkey
miniman82 is offline
PostPosted: Mon Jul 31, 2006 12:39 pm    Post subject: Reply with quote
One word-Hylomar.
http://www.hylomar-usa.com/
I'm not the spokesperson or anything, but we used this stuff when building jet engines (for the Navy), and I've used it on every engine I build. It's great becuase if you have to tear something back down, it's a snap to wipe off, and it seals very well.
RockNbus
RockNbus is offline
PostPosted: Tue Aug 08, 2006 3:08 pm    Post subject: Reply with quote
I got my Curil-T through the following link. It is great stuff for your 'must seal' areas. It is not cheap so I only use it for the important areas.
http://www.germansupply.com/home/customer/product.php?productid=16441&cat=351&page=1
helowrench
helowrench is offline
PostPosted: Tue Aug 08, 2006 3:12 pm    Post subject: Reply with quote
I use hylomar aero grade for everything. no drips no leaks no runs.
and removal is the easiest with the aerosol remover.
rob
Current VWs:
70 bug vert for wifey
73Thing bucket o rust
73 914 1.7
12 Passat 2.5 Highway cruiser
GeorgeL
GeorgeL is offline
PostPosted: Tue Aug 08, 2006 4:13 pm    Post subject: Reply with quote
miniman82 wrote:
One word-Hylomar.
Both of the Mexican VW engines I've purchased came with a bead of Hylomar squeezed out of the case joint. Neither has leaked in years of use.
Now, if it were just available on the Permatex rack like it used to be...Sad
Do any VW suppliers carry Hylomar?
George
BTW, do not buy this stuff from the Hylomar-USA site listed above. This stuff is expensive, but $28.50+shipping for a 100g tube is way too much!
http://www.cvproducts.com/cv/products/specItem.aspx?prodID=4771&brandID=94
http://www.fast-idleautosupply.com/index_files/Page664.htm
Page 1 of 13
