New Member Here!!!! My Motor!
Kurleedaddeewrx
Kurleedaddeewrx is offline
PostPosted: Fri Nov 28, 2003 4:25 pm    Post subject: New Member Here!!!! My Motor! Reply with quote
Just wanted to introduce myself. I was heavily into VW's in the late 80's to early 90s. I had a 1776cc motor built by Small Car Specialties to the following specs:
Type 1 1776cc Balanced and Blueprinted
69mm Counterweighted Crank
90.5mm pistons and cylinders
Engle 110 cam
17lb Fly Wheel
1700lb Kennedy Pressure Plate and 2 plate racing disk
041 heads ported and polished
Dual 40mm Dellorto carbs with K&N air cleaners and ported intake runners
1 5/8 in. header to stinger or dual muffs
I still have the motor and am looking for a Porsche Speedster Kit Car or a Manx style dune buggy to put the motor in. I also had it mated to a IRS(69' BUG) tranny that had updated gears that I still have. I have to backtrack and call the place I got it from to confirm what gears are in it.
I also own a '02 Subaru Impreza WRX which runs a Stage 4 kit (upgraded turbo, injectors, fuel pump and intercooler). I am going to the dyno this week(Wednesday) and will hopefully put near 300whp down to the ground.
Just thought I would share with you all what I have sititng on my bench in the garage.
Kurlee Daddee
(THE ORIGINAL)
STG4 WRX W/ VF22
my65vert
my65vert is offline
PostPosted: Fri Nov 28, 2003 4:58 pm    Post subject: Reply with quote
Good that your back to vw's, more the merrier. Burn the suburu b4 its too late.
OGJHC
Kombisutra;
I'm starting to get little wafts of bus stink coming from the north. Something about the unique scent of drivers seat padding when it's glued together with mouse piss and shit that really gets me going... and I'm smelling it! Oh yeah! Time to start loading up the equipment.
Kurleedaddeewrx
PostPosted: Fri Nov 28, 2003 11:06 pm    Post subject: Reply with quote
Oh no. You definately have me wrong. This Subaru is the baddest most reliable and best handling car I have ever owned. And it sure does take well to mods as well. I went from 188whp to 250whp for only $2000. I should be near 300whp next week. That may be good for mid 12 second 1/4 mile runs.
The VW will just be a toying around type car. I just have a motor and trans combo to play with. I just need the body and pan to make it work.
Kurlee Daddee
(THE ORIGINAL)
STG4 WRX W/ VF22
Erik G
Erik G is offline
PostPosted: Tue Dec 02, 2003 9:40 pm    Post subject: Reply with quote
hmmm, really? I always thought of suburu's as throw away POS cars
dual44DCNFs
dual44DCNFs is offline
PostPosted: Fri Feb 13, 2004 9:43 pm    Post subject: COOL Reply with quote
Cool to see you back in the scene. It's too bad everyone is giving you a hard time about yourSuburu because it uses a flat 4 like a VW.
sixfootdan
Samba Smartass
Location: \Lo*ca"tion\, n. 1. The act or process of locating.
sixfootdan is offline
PostPosted: Sat Feb 14, 2004 12:20 pm    Post subject: Reply with quote
I like Subaru's, I think that will be our next car for my Wife. Welcome back to VW's Wink
Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!!
