Front Wheel Bearings by Timken
shouldhave
shouldhave is offline
PostPosted: Sat Jul 29, 2006 3:05 pm    Post subject: Front Wheel Bearings by Timken Reply with quote
Question I was going thru an old box I recieved with my 1974 bus and found a mixture of Type 1 and Type 4 parts. I have a lot of new roller bearings by Timken and was wondering if anyone knows where I can get a cross reference for them?
Or possible someone can ID them for me? The two roller bearings are numbered L45449 and LM11749. The races are L45410 and LM11710 respectively. If anyone knows that they are for the front wheel of a 1974 bus could they let me know? I'm about to set out on a cross continent journey and would like to know if they should come along for the ride....(You never know where and when the law of entropy will grip you...) Many thanks, Chris
ratwell
ratwell is offline
PostPosted: Sat Jul 29, 2006 3:14 pm    Post subject: Reply with quote
None of those part numbers match anything in the Timken online catalog except LM11710 and there's no info on it.
I'd contact them and see if they can cross reference those old numbers. Here are the bus wheel bearing part numbers:
211405625 front
211501283D outer rear
211501287 inner rear
'78 Westfalia CDN
'76 Doublecab Sweden
Read the Baywindow FAQ
dwill49965
dwill49965 is offline
PostPosted: Sat Jul 29, 2006 5:33 pm    Post subject: Reply with quote
Well it just so happens I spent all day yesterday and today redoing the front wheel bearings on my 78 Westy. The inners on both sides were good (Timken). But as for the outer bearings, one was trashed, the other okay, so I replaced them both and kept the good used one as a spare.
My fronts were Timken - the bearing is LM 11949 (Made in France), and the race is Timken LM 11910 and is Made in USA.
I ordered replacements through my local FLAPS (211 405 645D) and the brand I got is KOYO - made in Japan. The cross reference on the box says LM 11949/10. They look and feel identical in every way. The local machine shop guys who pressed out my old races said that KOYO were a good, high quality bearing maker.
As far as I know, 72-79 front bearings are all the same - in fact I think it extends up until 84 Vanagon's as well (but I may be wrong here).
Darryl
'78 Westy, Boston Bob built 2.0 L, FI, MSD 6A
ratwell
ratwell is offline
PostPosted: Sun Jul 30, 2006 8:11 am    Post subject: Reply with quote
Sounds like had a factory bearing:
http://homepage.mac.com/ratwell/.Pictures/MoreParts4/155-WheelBearing.jpg
'78 Westfalia CDN
SlowLane
SlowLane is offline
PostPosted: Sun Jul 30, 2006 6:34 pm    Post subject: Reply with quote
I believe you're right. At least, my '81 VAnagon used the same bearings.
On that note, see this cautionary tale about some industry standard LM11949 bearings that turned out to be not so standard. Mad
Present:
'81 Westfalia: 2L, manual. Originally Canadian, now Californiated
Back in the day:
'72 Super Beetle
'69 Camper Van - Corvair powered
'71 Window Van - Transferred Corvair from '69
"With sufficient thrust, pigs fly just fine." - Internet RFC 1925
"They say a little knowledge is a dangerous thing, but it is not one half so bad as a lot of ignorance." - Sir Terry Pratchett
wagenman
wagenman is offline
PostPosted: Wed Apr 25, 2007 11:39 am    Post subject: Reply with quote
I know that the L45449 cone bearing is used in watercooled 020 5-speed gearboxes as the pinionshaft end bearing and the race for it is pressed in the case half.
wagenman
wagenman is offline
