tenpin Samba Member
Posted: Mon Aug 21, 2006 9:09 am Post subject: positive ground? |
Is the electrical on a 69 beetle a positive or a negative grounded system? Thanks. |
David58bug Samba Member
Posted: Mon Aug 21, 2006 9:21 am Post subject: |
It is a negitive grounded system. |
tenpin Samba Member
Posted: Mon Aug 21, 2006 12:20 pm Post subject: |
Thanks, did some years have + ground? |
OldsCool Samba Member
Joined: May 12, 2005 Posts: 222 Location: Flowery Branch, GA
Posted: Mon Aug 21, 2006 12:30 pm Post subject: |
I don't think any Beetles were ever positive ground. If I remember correctly, the only cars that were ever positive ground were either early Triumph or Austin Healey. I'm sure someone will correct me if I'm wrong, though  |
Randy in Maine Samba Member
Posted: Mon Aug 21, 2006 1:15 pm Post subject: |
OldsCool wrote: |
Also many American cars were positive ground until the mid to late 50's.
I am dinking with a 50 Desoto "Travel All" right now that was a positive ground 6 volt. Boy is that thing a toad! |
tenpin Samba Member
Posted: Mon Aug 21, 2006 2:24 pm Post subject: |
Well that explanes a few things. The ground cable to the battery is red and the first time I hooked the battery up I didn't pay atenttion to where the wire was going, just the red and hooked the battery up backwards. Then I started it up, it did start? But I think that might have fried the volt reg. Thanks for the input I will start over checking things out. |
julrich366 Samba Member
Joined: June 05, 2006 Posts: 1305 Location: N.E. Ohio - aka "The Rustbelt"
Posted: Tue Aug 22, 2006 3:25 pm Post subject: |
Quite a few older British cars are positive ground. I used to have a '65 MGB in the early 70's and it was (+) ground... a real BITCH at the time to find an 8-track player that worked on (+) ground... oh, those were the days!
Think the Triumphs and Austin's were as well. _________________ - John
'74 Vert ..lot's to still do. |
spotco2 Samba Member
Posted: Tue Aug 22, 2006 8:24 pm Post subject: |
My Ford 8N tractor is poss ground  _________________ 69 Beetle
VW's are not just a car, they're an adventure! |
WolvenGoth Samba Member
Joined: July 12, 2006 Posts: 403 Location: Memphis, TN
Posted: Tue Aug 22, 2006 8:48 pm Post subject: |
Randy in Maine wrote: |
Also many American cars were positive ground until the mid to late 50's. |
i was considering buying a plymouth cranbrook at one time, think it was a 51, and it had a positive ground on it, the guy said in part to ford and gm owning various patents there were differences with the plymouths, dunno if that's true or not, but the one other interesting part about it was, it was a 3 on the tree, but it was different. reverse was towards you and down, then you shifted up to first, down and forward to 2nd, and up to 3rd. while this is totally different than any 3speed i've ever owned, and i'm certain would get confusing since i'm so used to the other setup, it seems like it would be better cause top gear would keep the stick out of the way of the knees of whoever's riding bitch. i have no clue what relevance any of this has, probably none. _________________ --WolvenGoth
1972 Beetle Automatic Stickshift (LuLuBell)
1976 Beetle (Herman) New Daily Driver
VW's. Betcha can't own just one! |
The Pirate Samba Member
Joined: August 09, 2006 Posts: 310 Location: Austin Tx.
Posted: Wed Aug 23, 2006 8:35 pm Post subject: |
Keep in mind that some Beetles have the Speedo on a positive ground while the rest is negative ground. _________________ 74 super beetle AKA The Pirate.
We are currently offering a rebuild service for Beetle rack and pinion steering units. PM for details.
Service with a Yahhrrr. |
DrDarby Samba Member
Joined: May 12, 2004 Posts: 6543 Location: Northern Illinois
Posted: Thu Aug 24, 2006 5:58 am Post subject: |
This is not entirely true. All Beetles speedo is grounded like everything else. The Gen, Oil & T/Sig lights though are in an insulated housing and + is applied to the bulb bases and (-) is applied to the spade terminal on the bulb holder. This is still a negative ground system. _________________ Midwest Autosavers, Inc. Crystal Lake, IL |
67jason Samba Member
Joined: August 28, 2005 Posts: 4741 Location: behind my back feet - Pittsburg CA
Posted: Thu Aug 24, 2006 6:11 am Post subject: |
tenpin wrote: |
just remember on VWs, black is the hot wire...black battery cable, black positive coil wire etc. _________________ 67 bug x3
67 ghia
64 bug |
