Thermostat Bracket Modification To Accept New Style Thermo
Kris Styes
Kris Styes is offline
PostPosted: Fri Aug 25, 2006 8:34 am    Post subject: Thermostat Bracket Modification To Accept New Style Thermo Reply with quote
Thermostat Bracket Modification To Accept New Style Thermostat.
Coiled or bellow style thermostats are getting hard to find and pricy. VW produces a new type / style thermostat at this time. The problem with the new style thermostat is the bracket it requires to mount on the engine block. It is nearly impossible to find! Go figure!
Pictured below is how I modified the old style thermostat bracket to accept the new style thermostat. Tested and works fine.
Tools Needed:
Jigsaw with fine tooth metal cutting blade
Use of grinder
7/64 Metal bit
Total Time = 1 hour, start to painted finish.
T1 Thermostat Bracket
T1 Thermostat Bracket With Termostat Mounted
Bottom, New Style Thermostat - Notice Lock Pin On Bottom
Using 7/64 or 1/8 Bit, Drill Hole Between "Button Weld" And Mounting Hole
Cut Away Existing "Hoop" And Angle Support So New Style Thermostat Fits Flat On Bracket.
Another View Of Cut.
Finished Bracket With New Style Thermostat Mounted. Lock Pin On Thermostat Fits Into 7/64 Hole And Provides For Some Movement For Rod Alignment.
Kris (Kanas)
Nothing to say!
gerg
a.k.a. 6volt65
gerg is offline
PostPosted: Fri Aug 25, 2006 9:39 am    Post subject: Reply with quote
Kris - How has this new thermo worked for you?
I have heard good and bad feedback in the past.
I pressume most of the bad was lack of a way to mount the new style in the old holder. Question
Very nice work! Wink
Gerg
. . . I got 99 problems and my bus ain't one . . .
'65 Sunroof Beetle
'65 Vert
'60 Singlecab
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger Gallery Classifieds Feedback
Kris Styes
PostPosted: Fri Aug 25, 2006 9:45 am    Post subject: Reply with quote
Greg:
Asjusting the new system (on the block) is not much different than the bellow ones. I had to learn the top end of flap opening by trial and error (just like a bellow one)
Functions fine. Two 100 mile runs to test it. One "hot" day, the other, this AM, when it was cooler. After final adjustment on block, I can't really tell any difference between the old and new style (function).
Hope this helps.
K
Nothing to say!
mailman
mailman is offline
PostPosted: Fri Aug 25, 2006 4:29 pm    Post subject: Reply with quote
Kris...
Great info...thanks! Two questions come to mind. What's the approximate cost of the new style thermostat? Does the new unit accept the same rod as the old style? Maybe one more....what's the temperature range on the new one?
'64 Bahama Blue Beetle / steel sunroof
'64 Bahama Blue Beetle Sedan (future ragtop)
Kris Styes
PostPosted: Fri Aug 25, 2006 5:53 pm    Post subject: Reply with quote
Mailman:
Good Questions. Sorry for not posting them with original post!
VW Number on new thermostat is 111 119 159 A, which is the same part number as the original thermostat. With that in mind, the new style thermostati shares the same temperature range as the original bellow type.
I purchsed two of the new style thermostats for $ 15.00 each. I have seen them as low as $ 7.50, but in catalogs, they can go for $ 40-50. There is one on SAMBA now for $ 50.00. People just don't know much about them, and with the mounting bracket issue, people are not purchasing them (I'm only guessing on this)
I used the same rod that attached to my bellow thermostat. Worked fine!
Hope this helps,
Kris (Kansas)
Nothing to say!
johneliot
johneliot is offline
PostPosted: Fri Aug 25, 2006 6:08 pm    Post subject: Reply with quote
I'm going from memory and this comes from other posts here, but what I have heard from others is that when the old style fails, it fails in the open position. I don't think this is true of the new style. Those in the know, chime in.
John
John
There is no distinctly American criminal class - except Congress.
Mark Twain
69 bug - "The Grey Ghost"
Kris Styes
PostPosted: Fri Aug 25, 2006 6:23 pm    Post subject: Reply with quote
I believe the return spring mounted on the rear of the cooler housing (hooked to flap rods) keep the flaps in the open position when and if a thermostat fails.
Anyone want to confirm?
Kris
Nothing to say!
WickedWagens
WickedWagens is offline
PostPosted: Wed Dec 06, 2006 1:00 pm    Post subject: Reply with quote
Kris if you don't mind me asking, where did you get your thermostat?
1968 Ghia Land Speed Car
G/CFALT 106.643 MPH
G/CGALT 113.131 MPH
G/CBGALT 134.606 MPH
G/CBFALT 146.715 MPH
G/CBGC 158.242 MPH
H/CPRO 93.383 MPH
H/CBGC 94.33 MPH
H/CBGALT 101.282 MPH
H/CBFALT 120.591 MPH
Kris Styes
PostPosted: Wed Dec 06, 2006 1:43 pm    Post subject: Reply with quote
I got my from Wooster VW in Salina, Ks.
Kris
Nothing to say!
John M.
John M. is offline
PostPosted: Wed Dec 06, 2006 1:48 pm    Post subject: Reply with quote
Kris
The new thermostats fail in the closed position, so it doesn't matter. Hope you have some way of monitoring the temps in-case it does fail and your driving with the flaps closed. That could be disastrous in just a few miles.
Current: 1972 Beetle - 96V EV
Previous:
1966 Beetle - Sea Blue - 1300SP
1966 Beetle - Sea Blue - 1600SP
1974 Beetle - African Red - 1914CC
Jeff Geisen
Samba Chaplain
Jeff Geisen is offline
PostPosted: Mon Aug 20, 2007 1:03 pm    Post subject: Reply with quote
... agreed, the spring type thermostat fails closed. The return spring on the shutter linkage bar keeps the shutters closed when cold, keeps the fan from blowing them open too soon.
IMHO, the new style thermo gives a false savings over the bellows style, which was designed to make the cooling system fail safe.
I Corinthians 4: 1 thru 5
‘63 ragtop - ‘68 single cab
johnanddes
Satellite Wrangler
johnanddes is offline
PostPosted: Mon Aug 20, 2007 1:58 pm    Post subject: Reply with quote
Dave from vw-resource.com has a mexican style installed and is pleased. Here is the link:
http://www.vw-resource.com/thermostat.html
I tihnk he did the same thing you did as far as the bracket.
John
1969 documented numbers matching bug
1968 F250
Keepin the ISS from colliding with space junk
Jody '71
Jody '71 is offline
PostPosted: Tue Aug 21, 2007 4:45 am    Post subject: Reply with quote
So, as of now, when you go to a VW dealership and get the 111-119-159A and open the box, you get the Mexican new style?? Or can you specify the old original bellows style? The last time I ordered this part from my local dealership it was still active, but not in stock. This was the original bellows style. They had to order it, I got my order in one day. I ordered 2. They were $54.62 a piece. This was April 2006. So is the original bellows style no longer made by VW???
'66 Beetle
2011 Hyundai Elantra Touring
RevKevin
RevKevin is offline
PostPosted: Sun Aug 17, 2008 9:28 pm    Post subject: Reply with quote
Any idea how many mods would be required to fit it onto the type 4 setup?
39coupe
39coupe is offline
PostPosted: Mon Aug 18, 2008 5:55 am    Post subject: Reply with quote
What are the ramification's of removing the flaps and thermo? Can anything be harmed by doing this or is it like removing the thermo from a water cooled vehicle, it just takes longer for the engine to warm up?
I'm rather new to the Air cooled engines, I have 2 1200 engines and rebuilt 1, it had the flaps and the thermo the other has no flaps and no thermo. When I rebuilt I put the flaps in with the thermo which I probably need to replace.
www.aircooledaddicts.org
Aircooled Addicts
'65 Beetle (red)
'65 Beetle (panama beige)
'65 Mustang
'39 Chevy Coupe
Russ Wolfe
Russ Wolfe is offline
PostPosted: Mon Aug 18, 2008 10:17 am    Post subject: Reply with quote
The original style thermostats are available, but at about $80.
The mexican thermostats DO fail in the closed position.
I have a few good used thermostats available.
I even went to an auction a while back and bid on 3 rusted out hulks because the thermostats were still in the cars.
Gary: OK. Ima poop.
capeoddboy
capeoddboy is offline
PostPosted: Wed Sep 10, 2008 2:12 pm    Post subject: no thermostat Reply with quote
If I have no thermostat installed ( I will install it soon ) and the spring on the flaps is installed, am I running with the flaps closed?
Also, if I take the spring off will that cure the cooling problem until I can get the proper rod and thermostat installed?
Thanks,
Tim
KTPhil Premium Member
KTPhil is offline
PostPosted: Wed Sep 10, 2008 2:34 pm    Post subject: Reply with quote
The flap spring works to keep them open. The thermostat works against that spring when it is cold.
capeoddboy
PostPosted: Wed Sep 10, 2008 2:42 pm    Post subject: Reply with quote
Thanks. I thought some previous posts said the spring held the flaps closed.
KTPhil is offline
PostPosted: Wed Sep 10, 2008 4:57 pm    Post subject: Reply with quote
Well, stay tuned, because it's been 20 years since I took my Bug apart. Get a "second opinion."
