My alternator conversion
Daniel Hood
Daniel Hood is offline
PostPosted: Sat Oct 21, 2006 6:33 pm    Post subject: My alternator conversion Reply with quote
Here's some photos of my 2110 with CB fuel injection and Denso alternator conversion that is fully adjustable. Also notice the heater outlets and oil tube are gone. I just got it running yesterday Very Happy
59 vw guy
59 vw guy is offline
PostPosted: Sat Oct 21, 2006 6:36 pm    Post subject: Reply with quote
Freakin sweet whered you get the brackets..
New project 66 bug And 61 bug for parts if you need some 61 parts im me to see if i have it Will trade 61 parts for dual carbs and bumpers for a 66..
Daniel Hood
PostPosted: Sat Oct 21, 2006 9:04 pm    Post subject: Reply with quote
I made the brackets and requires machining of the fan housing. I also used a modified billet aluminum alt pulley that is used on nascar engines.
As I felt the denso pulley was to small.
Bryan67
Bryan67 is offline
PostPosted: Sat Oct 21, 2006 9:24 pm    Post subject: Reply with quote
You need to throw up some more pics of the car Daniel. Inside and out.
If you`re going to do something, do it right.
59 vw guy
PostPosted: Sun Oct 22, 2006 6:47 am    Post subject: Reply with quote
I agree and make more.. Very Happy
JSMskater
Samba Grease Gorilla
JSMskater is offline
PostPosted: Sun Oct 22, 2006 9:26 am    Post subject: Reply with quote
how did you do that with the fan shroud? did you just weld some new metal in orr....
and where do you fill the oil these days, or does it run on MAGIC Wink
71 Squareback-FI -- 73 Bay (subaru powered)
TOOB Member #3
I make D-jet FI connectors
Daniel Hood
PostPosted: Sun Oct 22, 2006 9:46 am    Post subject: Reply with quote
Yes, I welded new pieces of metal in. I add oil in from the breather box.
there is some more photos of the car, Click on my gallery.
squareonair
squareonair is offline
PostPosted: Sun Oct 22, 2006 9:53 am    Post subject: Reply with quote
so each time you add oil ...you have to unscrew the two bolts on top? Think
Bryan67
Bryan67 is offline
PostPosted: Sun Oct 22, 2006 11:13 am    Post subject: Reply with quote
Well its not like its going to burn oil. You`ll only have to do it when you change oil.
blankmange
Type 3 Darksider
blankmange is offline
PostPosted: Sun Oct 22, 2006 12:52 pm    Post subject: Reply with quote
is there a dipstick somewhere or am I just not seeing it?
póg mo thóin
Certified DHS Technician
Samba Member # 24517
squareonair
PostPosted: Sun Oct 22, 2006 12:56 pm    Post subject: Reply with quote
i didnt see one..
Daniel Hood
PostPosted: Sun Oct 22, 2006 2:48 pm    Post subject: Reply with quote
You guys didn't see it.
electricmonk
electricmonk is offline
PostPosted: Sun Oct 22, 2006 4:35 pm    Post subject: Reply with quote
Nice, I would realy like more details an the alternator, How many amps? what exactly did you use and what needed to be fabricated and how? I can get a few things done at work as I just don't have tools anymore like I used to. Any pics of how you did it?
Bryan67
Bryan67 is offline
PostPosted: Sun Oct 22, 2006 8:01 pm    Post subject: Reply with quote
Look in his gallery for more pics.
lonotch
Samba Padrino
lonotch is offline
PostPosted: Sun Oct 22, 2006 8:04 pm    Post subject: Reply with quote
Very clean, looks nice! Cool Wink
It's not about the window, it's about the people.
German Folks
Air_Cooled_Nut
Air_Cooled_Nut is offline
PostPosted: Mon Oct 23, 2006 7:53 pm    Post subject: Reply with quote
The original and more:
http://www.icbm.org/erkson/ttt/engine/generator.html#custom
In kit form:
http://www.theddb.com/
Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Penthouse Sundowner 2.0L; 2015 Audi S5 Cabby w/Stage II APR; '06 Ducati Sport Classic 1000; '14 Ducati Diavel Strada
The First Invasion
Air_Cooled_Nut
PostPosted: Mon Oct 23, 2006 7:54 pm    Post subject: Re: My alternator conversion Reply with quote
Daniel Hood wrote:
Here's some photos of my 2110 with CB fuel injection and Denso alternator conversion that is fully adjustable. Also notice the heater outlets and oil tube are gone...
Nice work! I like the shorty fan housing Cool
Two recommendations:
1. Move the coil to a cooler location. On top of the case isn't a good spot and coils need to keep cool. I'd recommend moving up to an after-market ignition system when you can to get even more power;)
2. Try to get taller air filters if you can. Makes a noticable difference in power output with more air filtration area...BTDT.
The First Invasion
Bryan67
Bryan67 is offline
PostPosted: Mon Oct 23, 2006 8:05 pm    Post subject: Reply with quote
There are no other air cleaners that will fit under the lid. I don`t think it makes much difference as I have ran my car without filters for tuning and it feels the same with then on or off.
Air_Cooled_Nut
PostPosted: Tue Oct 24, 2006 11:02 am    Post subject: Reply with quote
I dropped 1/4 inch on my air filter height and felt the power loss. See if you can find a slightly taller air filter; it just will make taking the air filter tops off a little more challenging. Mine are VERY close to touching (but aren't) the engine lid surround. I understand engine dynamics/physics as well and know from that perspective that the lower surface area creates a restriction, too. I bet if you put it on a dyno you'd see the difference as you're engine is only 103cc bigger than mine Wink
The First Invasion
trylordurben
trylordurben is offline
PostPosted: Tue Oct 24, 2006 11:25 am    Post subject: Reply with quote
very nice!
where do you get those dizzy wires that are bent 90 degrees?
im curious as to how your fan shroud mods affect the airflow? i know there was a thread on how beetle motors work better with the original heater ducts as opposed to the removed ones, just wondering if you looked into that? My shroud has the ends plugged.
how do you like the fuel injection kit? my friend is putting the same kit in his beetle.
again, your motor looks very nice!
