Ignition switch repair?
Page: 1, 2, 3  Next
incynr8
incynr8 is offline
PostPosted: Mon Oct 23, 2006 3:42 pm    Post subject: Ignition switch repair? Reply with quote
Ok, I have
A good battery
good starter
good soleniod
clean connections at start switch
6.3 V on the guage
turn starter switch get 3-4V at soleniod
Is that enough to run the relay kit or is the starter switch suspect, I SOMETIMES get starts.
If the switch is suspect, it is a 1959 screw term and riveted to the body, any internal repair attemtp I can make?
My wires are very clean.
AL
Do it right, or don't bother.
Eric&Barb
Eric&Barb is offline
PostPosted: Mon Oct 23, 2006 8:01 pm    Post subject: Reply with quote
Hi Al,
Check voltage at the battery posts and then use that amount for referance as you check for what voltage at EACH connection going from battery to ignition switch and back to the starter solinoid.
Good idea to replace each battery cable and the tranny to body grounding cable to see if that will do the trick.
Have you checked out the headlight rebuild article we helped to write up in the type2.com archives? Also solder the clips in each slot of the post-1960 fuse box together, and soldering the pre-1961 fuse box riveted connections helps a lot!
In Stereo, Where Available!
npelton
npelton is offline
PostPosted: Mon Oct 23, 2006 9:26 pm    Post subject: Reply with quote
nice
incynr8
incynr8 is offline
PostPosted: Tue Oct 24, 2006 3:24 am    Post subject: Reply with quote
Hmm it might be the tranny grounding cable, but the others look nicer than my subaru outside. It's just odd I sometimes get starts and sometimes do not. I am trying a 6v ford relay once I find one around town today.
Thanks for the fuse box tips, I had read those in the archives and will look to tighten them up as well.
Al
spiderjames
spiderjames is offline
PostPosted: Tue Oct 24, 2006 4:24 am    Post subject: Reply with quote
The connection may be clean but the wire itself tends to increase in resistance as it ages. I would clean all the connections first, the switch and the selenoid and then try a relay. In my experience a horn relay works better than the bypass selenoid. If that doesn't fix it try replacing the starter selenoid.
If you bypass the switch entirely does it start consistantly?
incynr8
incynr8 is offline
PostPosted: Tue Oct 24, 2006 4:46 am    Post subject: Reply with quote
that's tonights testing, the wire to starter motor and then soleniod from the battery feed cable(which is new) for reliabilty testing.
The unit is a new Bosch starter with new soleniod. I do believe the condition is the overal total resistance of the wiring, but the ignition switch is suspect internally as well. Since it is a brass rivet, I was particualrly asking if there is a way to open them up and clean them or tighten the interal connections.
So far I get 5.8-6.3 volts at the soleniod at terminal 30. At the ignition wire trigger point, I get about 3.8 when the key is turned. I hope that would be enough to fire a 6v relay of some point. I am doing this relay regardless as it makes sense, just trying to keep my OG ignition if I can.
Seems like I have alot of little improvements to do..
Thanks for the help!
AL
Big Bill
Big Bill is offline
PostPosted: Tue Oct 24, 2006 6:24 am    Post subject: Reply with quote
incynr8, I too had the problems you are talking about. I did all the repairs you tried plus the starter bushing and a WW hard start reley and still would get a no start sometimes. I bought a good used ignition switch in the samba classifieds, and had Gaberial(sp?) rekey it to my OG key code, has been flawless since then. I belive he said he cleaned up the contacts, but I wouldnt know how to open up the switch myself hope this helps. Bill
Mr. Loaf
Mr. Loaf is offline
PostPosted: Tue Oct 24, 2006 6:27 am    Post subject: Switch Reply with quote
Your problem is your ignition switch. Maybe you could send it off to Gabriel if you can not figure out how to open it up. Otherwise, find one here on the SAMBA!
Never drive faster than your Angel can fly
$24,100 was too hard to resist.................
incynr8
incynr8 is offline
PostPosted: Tue Oct 24, 2006 6:28 am    Post subject: Reply with quote
they have to come apart then by drilling that center brass rivet and popping the 'tabs' Only way I can see getting to the cyl as well. He had to get into there to retumble it somehow. I see no way from the 'front' or key side.
Has anyone opened one of these up?
I ordered the ww relay, it makes sense to use one, but I really want to keep my original ignition switch.
Thanks,
AL
ToolBox
ToolBox is offline
PostPosted: Tue Oct 24, 2006 9:48 am    Post subject: Reply with quote
Thanks,
AL
You can if you are careful remove the electrical portion from the switch assembly. Look for 3 stake marks around the backside of the assembly, unstake them and the switch will come apart. I had a new switch and used the electrical portion in the original housing.
splitpile
Samba's Worst Speller
splitpile is offline
PostPosted: Tue Oct 24, 2006 10:06 am    Post subject: Reply with quote
Thanks,
AL
A hard start relay is a bandaid to a problem, find the problem and fix it.
I have run a temp wire from the starter solinoid to the ignition switch before to test that area, but as you discribe the voltage drop is at the ignition switch, is that with or without the starter wire connected at the switch?
Does Jon Furst (aka Hazetguy) also rebuild ignition switchs like he does headlight switchs?
"no more hacking my sig line"
incynr8
incynr8 is offline
PostPosted: Tue Oct 24, 2006 10:23 am    Post subject: Reply with quote
SO dont drill the center rivet out?
Thanks.
I am going to try and run contact cleaner through it first.
incynr8
incynr8 is offline
PostPosted: Tue Oct 24, 2006 10:27 am    Post subject: Reply with quote
Alot of the problem I think is the Bosch starter, I have been reading they often need almost 7 volts to hit the soleniod?
I agree it should WORK without a relay.
Seems to me I have to check the headlight switch and possibly open it and do the internal solder gig, same with fuse box, and then clean/repair my ignition switch.
The relay is not an original implementation, but does reduce alot of wire resistance in the path.
The wiring is so nice it looks new, but beside the battery cable to starter, I do not believe it is.
The voltage drop measured was at the starter soleniod, I had 6 available, and then at the soleniod trigger I had only 3.8 when you would turn the key, so the resistance could be:
At headlight switch
At fuse box
at starter switch
I have alot more to empirically check
The annoying thing is, it SOMETIMES starts!
Al
crofty
Judas of the North
crofty is offline
PostPosted: Tue Oct 24, 2006 10:29 am    Post subject: Reply with quote
Can't you wire the hot lead directly to the ignition switch then to the light switch? I saw a tech article on that years ago...
HamburgerBrad wrote:
incynr8
incynr8 is offline
PostPosted: Tue Oct 24, 2006 10:32 am    Post subject: Reply with quote
Yes you could.
I will chase the resistance dragon and post again. I really think it's the ignition switch internally, as it was fine for a bit ,then got crappy. It still sometimes fires right up, then doesn't then does, then doesn't. Not much is being manipulated in the meantime.
spiderjames
PostPosted: Tue Oct 24, 2006 5:21 pm    Post subject: Reply with quote
True it should work without a relay and did when it was new. If its original wiring its 40+ years old. the wire to the selenoid is too long to begin with. Longer wire = more resistance. Long crusty 40 year old wire = too much resistance. Old ignition switch with dirty contacts = even more resistance. It's a wonder these old busses start at all.
Maybe so. The absolute correct fix would be to run new wiring to the selenoid and replace the igntion switch. That's a lot of work to me. If you clean the switch, all of your wire and battery connections, and plug in a relay, you will have a fairly permanent workable solution.
Considering the total length of wire from the back of the bus to the ignition switch and back again, this is really the way VW should have engineered it to begin with.
The relay in my bug has been running for 6+ years without a hitch. I made it out of $8.00 worth of parts from autozone.
Hella Bro
Hella Bro is offline
PostPosted: Tue Oct 24, 2006 6:54 pm    Post subject: Reply with quote
Have you checked your starter bushing?
Eric&Barb
PostPosted: Tue Oct 24, 2006 7:17 pm    Post subject: Reply with quote
Hi Volks,
While the starter relay will often fix the starting problem. It will not remove resistance in the wiring connections that occurs due to corrosion, loose connections, bad battery cables, etc... This resistance keeps your lights, signals, horn, wipers, etc., dimmer, less loud, slower working, etc....
With the all the 40+ year old wiring systems in all our VWs and many friends we have helped with, been able to get voltage drop down to 1/10 of a volt when checked at the taillights and solinoid.
In the decades we have been working on VWs, have only seen one that needed the relay, and that due to the solinoid wire was partly fried by a DPO.
Unfortunately if there are no other causes of resistance in the wiring and the ignition switch is going. The ignition switch will just keep going bad from wearing out and finally will not get the starter working any more even with the relay.
Stanagon
Stanagon is offline
PostPosted: Tue Oct 24, 2006 7:28 pm    Post subject: Reply with quote
I just had Gabriel replace the electrical part of my ignition switch. $25 and very quick turn around. Mine had gotten fried and was actually smoking.
Gab said he could smell it before he opened the package...
Stan's Classic Service, specializing in air-cooled VWs:
http://www.thesamba.com/vw/classifieds/detail.php?id=614073
www.stanagon.com
My '61 Mango bus thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=110367
My '64 vert thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=386344
My '71 squareback thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=637709
spiderjames
PostPosted: Wed Oct 25, 2006 5:24 am    Post subject: Reply with quote
Eric&Barb wrote:
Hi Volks,
I'm not doubting your experience. It just hasn't been my experience. Every older VW I have owned has had recurring peoblems with the ignition system even with new parts and clean connections. Maybe the resistance isn't the issue but without the starter relay I find myself cleaning connections routinely (every few months) with 6 volt systems being worse. When I use the relay my routine cleaning is limited to my battery connections with the other connection needing attention very seldom. Doesn't mean the connections are staying cleaner. Just means my car will still start.
Back in 1980 when I had my 1970 vw it didn't have this problem. But as I got into older VWs and starter pulling these older derelicts out from behind people sheds and such this problem routinely showed up. Now that all these VW are as old as they are I just use the relay period. I just saves me some hassle when I'm trying to get to work on time.
Clean the switches and connections it will probably start fine. Repeat every few months, ad nauseum.
Page: 1, 2, 3  Next
