kbwakesk8 Samba Member
Joined: December 08, 2005 Posts: 1499 Location: Hacienda Heights CA
Posted: Mon Oct 30, 2006 6:20 pm Post subject: rat rod build |
| im a baja guy but i am planning on building a street bug rat rod style chop the top take of all the fenders. i heard you can put the front beam on backwards so the arms go forward. to give you that longer look. has any one done that. im still shopping for the doner car so i don't know if im going to run linkpin or ball joint. |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80682 Location: Sneaking up behind you
spook Samba Member
Joined: December 30, 2003 Posts: 2038 Location: in the shop 35750
Posted: Mon Oct 30, 2006 6:25 pm Post subject: Re: rat rod build |
| kbwakesk8 wrote: |
| i heard you can put the front beam on backwards so the arms go forward. to give you that longer look. . |
That is one of the most Darwinisk things that I have ever heard _________________ www.airkooledkustoms.com
SBS US #10
feedback on the shop : http://tinyurl.com/yc7jgkl
Welcome to he darkside, its lower here. |
olebeater Samba Member
Joined: August 16, 2006 Posts: 40 Location: Callao,VA
Posted: Mon Oct 30, 2006 8:38 pm Post subject: |
| I've seen it done but it don't look right ! ! ! |
sixfootdan Samba Smartass
Joined: February 13, 2002 Posts: 4852 Location: \Lo*ca"tion\, n. 1. The act or process of locating.
Posted: Tue Oct 31, 2006 12:13 am Post subject: Re: rat rod build |
| kbwakesk8 wrote: |
The Beam stays on the car the same way, It's the control arms that get swapped to the opp. sides. _________________ Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!! |
bugntjw Rants Lurker
Joined: February 11, 2004 Posts: 698 Location: Purgatory
Posted: Tue Oct 31, 2006 7:53 am Post subject: |
IMO it doesn't look right. Buy the kit to put an early Ford Beam on it, thats what looks right. _________________ A good friend will come and bail you out of jail...but, a true friend will be sitting next to you saying, "Wow...that was fun!"
Duct tape is like 'The Force'. It has a light side and a dark side, and it holds the universe together. |
phibertek Samba Member
Joined: February 22, 2005 Posts: 141 Location: Brooklyn Beotch!
Posted: Tue Oct 31, 2006 10:14 am Post subject: Rat Rod / VolksRod |
I feel I must make it clear that Rat Rodding and Volks Rodding are two different things. Rat Rod is when you let your care exists. These are normally and naturally developed. Of course slamming it low also helps. VolksRod stems from Hot Rod in a volkswagen way, is clean cut, but modified heavily.
I just feel I need to clear that up, because people ask about one thing, but they mean the other.
-Phibertek _________________ Lots of Beetle Parts for SALE!
Whatcha Needing?
http://www.volksride.com/marketplace/index/other/seller51.php |
Kubel Nick Samba Member
Joined: August 12, 2003 Posts: 1369 Location: Fort Worth, TX
Posted: Tue Oct 31, 2006 11:06 am Post subject: |
Flipping the trailing arms is very very iffy. The majority of the volksrods guys are against them since they can be potenitally dangerous. There is ALOT of things that you need to figure out to make it safe, etc, not just flip it and be done with it as most people do them.
Other alternatives for the extended axle look:
-frame extension adapter to push forward the beams (cheapest safe route)
-get a dropped axle kit ($$)
-permanently extend your framehead
-relocate your body back (safest route since it's the only route where the suspension is untouched, but hardest since you need to relocate the drvier seats, pedals, shifter, etc). |
Posted: Tue Oct 31, 2006 5:50 pm Post subject: |
im picking the car up friday its a 69 balljoint frontend but they put a swing axil trans in it. im going to start by chaneling 4 inches out of the car and maybe chopping 3 or 4 " off th roof i was also planning on sliding the rear suspention back 3" and lifting it up 3" to slam the car. but i still not shure how i want to handel the front end . my friend was pushing me to put my extra 6" wider beam on there with the beam extention. i also have 3x3 it would give the car one crasy stance.
just thinking out side the box. looking to turn heads |
71_transporter Samba Member
Joined: July 02, 2005 Posts: 823 Location: Southern Illinois
Posted: Tue Oct 31, 2006 6:47 pm Post subject: |
i would just get something like this where someone has done alot of the work for you.
http://www.thesamba.com/vw/classifieds/detail.php?id=379647 _________________ Bryan
Old hippies never Die, They just go up in Smoke!
63 Bug
67 Bug
82 WestfaliaVanagon |
Posted: Tue Oct 31, 2006 8:30 pm Post subject: |
| but that takes all the fun out of it. |
Posted: Wed Nov 01, 2006 6:08 am Post subject: |
check ou my site: www.runtrod.com
I gave some basic info on how to channel a VW, etc. And join volksrods.com forums if you haven't already. |
Posted: Wed Nov 01, 2006 11:56 am Post subject: |
sweet thanks that is a great site i have so many ideas.
i'll post picks when i pick up the car. |
Rome Samba Member
Joined: June 02, 2004 Posts: 10845 Location: Pearl River, NY
Posted: Wed Nov 01, 2006 3:25 pm Post subject: |
| Even with a half-finished rod project linked above, you are still many months ahead compared to doing something similar yourself. Look at that roof chop and the door work- how much time would it take for you to get it RIGHT? You might even throw in the towel if you tried it and it did not come out. With a project like the one listed, you still can do alot to personalize it to your tastes. If you want to chop off the roof on that car if it were yours and just keep the low windshield to make a roadster, well, for the $ you can't go wrong. Nice that that project is on an IRS pan; keeps the rear wheels level compared to a swingaxle project. |
Posted: Mon Nov 06, 2006 2:31 pm Post subject: |
the body is off the pan. im lifting the rear suspention 4 inches. and welding in new floor pieces.
not bad for the first weekend |
ineedabug Samba Member
Joined: July 05, 2004 Posts: 32 Location: Marysville CA
ivsamhell Samba Member
Joined: June 12, 2006 Posts: 858 Location: hesperiaCA
Posted: Sat Nov 11, 2006 5:34 pm Post subject: |
| flippin the control arm is pretty sketchy, braking is going to cause the front end to raise instead of drop. cause some interesting handling issues....... |
rgdedge Samba Member
Joined: October 17, 2006 Posts: 865 Location: Seymour, TN
Posted: Sat Nov 11, 2006 6:55 pm Post subject: |
| There is more to it than (fliping the control arms). I did mine that way and it drives like a stock bug. Doee not rise up when you hit the brakes. Stops normal, rides great, drives great. |
Posted: Mon Nov 13, 2006 10:59 am Post subject: |
can i fix that by changing the caster angle shimming out the top or bottom of the beam.
i just picked up a 2" narrowe balljoint beam with drop spindles and disc brakes.
do i have to go rack and pinion or can i turn the searing arm 180* on the stock stearing box probably have to heat it up a bend it abit. |
