bucko Samba Member
Joined: December 09, 2004 Posts: 2617 Location: Coppell, Texas
Posted: Tue Dec 12, 2006 12:00 pm Post subject: 4 Speed noise |
In my quest to clean, change, replace, rebuild, and repair any problems on my 84 Westy, I changed the transaxle fluid today. Wow, did that drain plug have some gunk and metal file pieces on it! It reminded me of that board game I had as a kid; you waved a magnetic wand over a face to move metal pieces to make head hair or facial hair!
Anyhow, 1st, 2nd, 3rd, and reverse are all quiet, but I notice that 4th gear has some noise under load. It did this prior to the change of fluids as well. I figured it needed changing, and perhaps the fluid change would quiet it up. None of the other gears make any noise except 4th. It runs great, shifts perfect; it just has some gear noise in 4th gear when applying gas, or under load.
Is this normal for these trannys? |
Tomswesty Samba Member
Joined: July 06, 2005 Posts: 194 Location: Moscow, ID
Posted: Wed Dec 13, 2006 7:33 am Post subject: |
I was told it be the pinion gear (made a high wining sound when in 4th). Mine did that too until I put in a new rebuilt tranny, no more noise. From the sounds of it you might be ready for the sudden death syndrome.
Good luck. |
bucko Samba Member
Posted: Wed Dec 13, 2006 11:49 am Post subject: |
Nope, not a high wine noise. Just a gear noise. Can't describe it, but definitly not high pitched. |
