VW_MAN_73 Samba Member
Joined: November 18, 2005 Posts: 1003 Location: Sunny Florida
Posted: Tue Jan 09, 2007 10:06 pm Post subject: Front beam leaves and shift rod coupler removal |
Hi. Iam trying to pull the leaves out of my bus beam to put in my narrowed beam and they won't some out. I loosened one of the nuts on the lower beam tube but looks like there is another screw that uses an allen key and I have a 6 and a 8 and they don't work. How do these come out? Thanks. Craig. _________________ ’73 Beetle - My first car, owned 26+ yrs
’71 VW Westfalia - Road-tripping across the US
Rescued & restoring a ’61 Dove Blue SO23 Bus
Follow our journey! |
Posted: Tue Jan 09, 2007 10:54 pm Post subject: |
got the bottom leaves out from the help of hoodride but the shiftrod is in the way on the top one and there is no way in hell that I can get the shiftrod coupler off. Sprayed it in pb blaster for a few days, then torched it and then had to drill out the screws and still won't come off I decided that iam going to cut the shiftrod but cant find anything small enough to get in there. I wish I had a sawzall  _________________ ’73 Beetle - My first car, owned 26+ yrs
Clara  Samba Member
Posted: Tue Jan 09, 2007 11:11 pm Post subject: |
step away from the bus.
put down the tools
do a search about getting the shift rods apart. The topic comes up here from time to time.
use your Bentley manual. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Posted: Wed Jan 10, 2007 12:45 am Post subject: |
| Clara wrote: |
put down the tools
use your Bentley manual. |
Hey Clara. I know everyone says to just cut the coupler in half but I don't have a sawzall to get in there and Iam deffinately not going to buy one. But I don't see how when You cut it in half how you gonna get the coupler pieces off the shiftrod? _________________ ’73 Beetle - My first car, owned 26+ yrs
galexander Samba Member
Joined: April 17, 2003 Posts: 644 Location: Round Rock, TX
Posted: Wed Jan 10, 2007 8:14 am Post subject: |
I had a stuck coupler also, used a Dremel with the small cutoff wheel, sliced right through the old coupler. Then was able to use a hammer and punch to knock the old coupler off the rear shift rod, and after pulling the front shift rod out, was able to do the same on it. Just be careful when slicing through the old coupler not to cut into your shift rod. Took like maybe 4 minutes of cutting. Put a new coupler on, after applying anitseize to the shift rods, inside the new coupler and the set screw. Then safety wired the set screw. WW has the couplers.
Good Luck. _________________ enjoy the journey,
Gary
Watch us on YouTube, VW Life AND
listen in to the VW Life Good Time Hour on VDub Radio, every Tuesday! |
Clara  Samba Member
Posted: Wed Jan 10, 2007 10:55 am Post subject: |
| VW_MAN_73 wrote: |
| Clara wrote: |
put down the tools
Hey Clara. I know everyone says to just cut the coupler in half but I don't have a sawzall to get in there and Iam deffinately not going to buy one. But I don't see how when You cut it in half how you gonna get the coupler pieces off the shiftrod? |
I don't use a sawsall.
i have used an angle grinder (wear good eye and ear potection)
make two cuts the length of the coupler, to effectively make it into two half cylinders. then with a fat screwdriver you can pry them off the rod.
The heat till red hot and douse with water trick usually works for me ... use at LEAST 4 cycles of heat /cold.
but it did stump me on my red 61 and I had to cut the coupler.
be careful not to cut too deep. new couplers are cheaper than shift rods, but they are reproing the front shift rod now, I heard.
A dremel or air cut off wheel is probably easier than my makita angle grinder, but that is the tool I had... a bit tricky to fit up there to get to the coupler. Wiggle the rod around before cutting, to guage the best place to make two cuts. a big screwdriver in the first cut, then twist it, to stretch the C- shaped coupler (was an O until you cut a slot) will generally crack the rust to let the coupler away from the rods.
after the coupler is off, take two pair vise grips to attach to front and rear rods (front rod is hollow, be careful, do not squash), and twist to undo the rods.
I cannot emphasise enough how the heat/cool cycle is very helpful. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
derv Samba Member
Joined: October 12, 2005 Posts: 2601 Location: Oak Park (Chicago), IL
Posted: Wed Jan 10, 2007 11:22 am Post subject: |
I suggest changing the name of this thread to something relating to the stuck shift coupler so Clara's information wont go to waste. _________________ Jack
| Quote: |
| Mr. Hido: To post your bare ass to virtually all hardened bus enthusiasts casts thick, a slag not easily ground smooth. |
Posted: Wed Jan 10, 2007 11:28 am Post subject: |
I think that would be good but I don't know how to change the topic. _________________ ’73 Beetle - My first car, owned 26+ yrs
Stocknazi Samba Member
Posted: Wed Jan 10, 2007 12:42 pm Post subject: |
yeah, do what clara said!! she is right on. the hot/cold technique has to be one of the best tricks i have picked up from the samba, bar-none. it works almost everytime. although the process may have to be repeated several times for the most stubborn fasteners, it works 95% of the time. it is defiently alot less headache than having to look for other parts b/c you fu*cked yours up by getting in a hurry. use bp blaster too. i would suggest keeping your bus stock height with stock componants, but it seems you already have it in your head to lower your bus, that's just my opinion. make sure you keep all your og stuff so your bus can be returned to stock later if needed. good luck and take your time _________________ WANTED:
Thomas Jefferson |
Posted: Wed Jan 10, 2007 12:52 pm Post subject: |
Yeah, I don't really care for the appearance of stock height. I have a 4 inch adjustable beam with drop spindles that iam working on now. I lowered the rear but have an aftermarket exhaust that is about 4 inches from the ground. Once I get a stock exhaust i will drop it another 2-2 1/2 inches. Here is a pic of the rear. I put the can of easy off so you could kinda see.
Posted: Thu Jan 11, 2007 1:05 pm Post subject: |
I can't take this any more! I cut one side with a dremel and cant get to the other because of no room. I don't know how you guys get in there. I broke down as of now. Out comes the air cutter and the shiftrod is going to be cut. It may take a while because that things worthless but I can't let this damn coupler stop me from getting this on the road. I have to get this ready for a show coming up way down in miami. Thanks for all your input everyone and I will let you know what it looks like when its done. _________________ ’73 Beetle - My first car, owned 26+ yrs
my65vert Samba Member
Joined: November 09, 2003 Posts: 6187 Location: Middleburg, Florida
Posted: Thu Jan 11, 2007 1:56 pm Post subject: |
No, you dont have to cut the other side of the coupler. Just one side, then jam a screw driver into the cut slot and pry the coupler open.
Or cut another slot right above or below the other and take that section out. _________________ OGJHC
Kombisutra;
I'm starting to get little wafts of bus stink coming from the north. Something about the unique scent of drivers seat padding when it's glued together with mouse piss and shit that really gets me going... and I'm smelling it! Oh yeah! Time to start loading up the equipment. |
Posted: Thu Jan 11, 2007 2:55 pm Post subject: |
The dirty deed has been done. The rod is cut But the damn beam still won't come out because all the tie rods are frozen. I took out all the nuts on the tie rod ends and they won't pop off. I tried punching them through with a mini sledge and using heat and pb blaster and they still won't come out. Are they any other ways I can free them up? _________________ ’73 Beetle - My first car, owned 26+ yrs
Riff Raff Shivering Sambian
Joined: October 25, 2004 Posts: 3097 Location: Alberta
Posted: Thu Jan 11, 2007 3:07 pm Post subject: |
Even with the shift rod cut, you still need to get that coupler off.
You will never get the tie rod ends off without a pickle fork (Not good) or a proper tie rod removal tool (Much better). It has been awhile since I have been under my bus, but I didn't think the tie rods had to come off to drop the beam?
Regardless, you will need the removal tool for the drag link anyhow.
Did you cut the shift rod at an angle so you can line it back up properly?
On a side note, you will want to replace that louvred deck lid with a stock one before driving any amount. The louvres will allow the exhaust and hot cooling air to recycle into the engine compartment. _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
Posted: Thu Jan 11, 2007 3:23 pm Post subject: |
| Riff Raff wrote: |
You will never get the tie rod ends off without a pickle fork (Not good) or a proper tie rod removal tool (Much better). It has been awhile since I have been under my bus, but I didn't think the tie rods had to ocome off to drop the beam? Regardless, you will need the removal tool for the drag link anyhow.
Did you cut the shift rod at an angle so you can line it back up properly? |
I did cut at an angle The only tierods that need to come off are the ones that are connected to the steering box or the one coming from the center pin. The one on the steering box is in good condition so thought I'd go after that one but it is frozen like the rest of them. The nuts comes off like nothing but those tierod ends are not coming off. I have been using heat then ice then heat then ice pb blaster beat it and nothing. Autozone have this puller? I not trying to pull the ti rod end from the tirod but the tirod from the arm on the steering box or on the center pin. _________________ ’73 Beetle - My first car, owned 26+ yrs
Posted: Thu Jan 11, 2007 3:47 pm Post subject: |
| VW_MAN_73 wrote: |
| Riff Raff wrote: |
I did cut at an angle The only tierods that need to come off are the ones that are connected to the steering box or the one coming from the center pin. The one on the steering box is in good condition so thought I'd go after that one but it is frozen like the rest of them. The nuts comes off like nothing but those tierod ends are not coming off. I have been using heat then ice then heat then ice pb blaster beat it and nothing. Autozone have this puller? I not trying to pull the ti rod end from the tirod but the tirod from the arm on the steering box or on the center pin. |
Good that you cut the rod at an angle.
That is the drag link you are trying to get off. It is tougher to pop that prick off than a tie rod end. It's tough even with a pickle fork and an air chisel. You really want to get a proper tie rod removal tool for that.
I can't comment on whether or not Autozone would have one as we don't have them up here. _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
Posted: Thu Jan 11, 2007 4:45 pm Post subject: |
hey riff raff. I got that drag link off, I guess thats what its called. Now. How do I disconnect the heater cables and clutch cable? Do I have to take it off at the front or rear? I didn't know that the brake line and heater cables and clutch cable were going through it too I guess vw never wanted us to slamm buses  _________________ ’73 Beetle - My first car, owned 26+ yrs
Posted: Thu Jan 11, 2007 6:21 pm Post subject: |
I don't think the heater box cables are threaded through the beam.
The clutch cable undoes at the front, there is a small pin with a cotter pin through it that needs to be removed.
The e-brake cables can be undone at the base of the e-brake lever and pulled down.
Don't forget to unhook the speedo cable from the drum as well. _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
Posted: Thu Jan 11, 2007 6:33 pm Post subject: |
thanks riff. All that is done now. Here is my problem. Iam trying to push the shiftrod thorugh the front and its hitting the e brake thing. What do I do about this? All I have to do is that an iam done  _________________ ’73 Beetle - My first car, owned 26+ yrs
Posted: Thu Jan 11, 2007 6:55 pm Post subject: |
The rear shift rod has to come out through the back.
Now is when you have to get that coupler off. _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
