3 point rear seatbelts for convertible
69911e
69911e is offline
PostPosted: Fri Jan 19, 2007 9:24 am    Post subject: 3 point rear seatbelts for convertible Reply with quote
I have read a few post looking for information about 3 point rear seat belts in a convertible, but not anyone posting they have actually done this. Does anyone have pics or a description of a completed install?
Thanks
Ed
'78 super conv. - project with my kids (3&6)
'69 911E daily driver + AutoX car
'71 1800E wife's weekend car
mnussbau
mnussbau is offline
PostPosted: Fri Jan 19, 2007 7:24 pm    Post subject: Reply with quote
Good luck finding info on this, I've been unsuccessful as well. I think the upper mount or belt travel would be blocked by the top mechanism.
Mike
‘74 bug vert
Parts...
ach60 Premium Member
ach60 is offline
PostPosted: Fri Jan 19, 2007 7:31 pm    Post subject: Reply with quote
Are we talking front or rear?
Good Luck
Al
View user's profile Send private message Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
WolvenGoth
WolvenGoth is offline
PostPosted: Fri Jan 19, 2007 10:44 pm    Post subject: Re: 3 point rear seatbelts for convertible Reply with quote
--WolvenGoth
1972 Beetle Automatic Stickshift (LuLuBell)
1976 Beetle (Herman) New Daily Driver
VW's. Betcha can't own just one!
View user's profile Send private message AIM Address Yahoo Messenger Classifieds Feedback
VW Vet
VW Vet is offline
PostPosted: Fri Jan 19, 2007 11:18 pm    Post subject: Reply with quote
Is this part of what you need to know?:
As the shoulder harness leaves the shoulder and goes aft, it should be no more than 5 degrees below or 30 degrees above the shoulder. Not exceeding 5 degrees below is the most important one to observe.
69911e
69911e is offline
PostPosted: Sat Jan 20, 2007 12:38 pm    Post subject: Reply with quote
I was looking at using the threaded holes which exist holding up the rear panel carpet. These threads look to have the same reinforcement the seat belts have (I need to double check this), so they should be strong enough.
The top I have is trashed so I can't check clearence with the top mechanism down accurately. I plan on using the plastic window top without the headliner or padding so I may have a little more room than a conventional top.
Has any one try ever tried this approach?
Ed
Bugs'n'Pugs
Bugs'n'Pugs is offline
PostPosted: Sat Mar 03, 2007 8:05 am    Post subject: Reply with quote
Question Did you have any luck with that? I would like to install 3-point seat belts in the rear of my convertible, too.
1978 Super Beetle Convertible (Project)
Post a Photo in the Forums
Rescue Man's Best Friend
69911e
69911e is offline
PostPosted: Fri May 04, 2007 11:29 am    Post subject: Reply with quote
Yes, it works fine. I needed belts for my kids (3&6), so the desired angle is different than an adult. The angle would not be suitable for a tall person whose shoulders were significantly above the seat back. I did it using the attachments on the firewall with non-retractable belts from BugCity ($60 for the pair). It required bending the rear attactment assembly of the belts to a right angle. Let me know if you would like pics.
Ed
MIKE+4
MIKE+4 is offline
PostPosted: Mon May 07, 2007 12:53 pm    Post subject: vert seat belts Reply with quote
Ed would you please send the pictures? Im wanting to put 3 points in the rear of my 73 vert. Thanks Mike.
69911e
69911e is offline
PostPosted: Mon May 07, 2007 5:03 pm    Post subject: Reply with quote
Here are the pics.
The belts should be placed on the side of the seat for small children just above the seat back latch mechanism. This places the belts in the correct position.
The bracket went right into the existing threads which were covered by a plastic plug. The bracket needed to be bent at a right angle.
This pic is to demo how I will modify this when the kids are bigger. I plan on adding a headrest when needed with a padded spaced (shown here by the 2 x4 ). the spacer will position the belt to avoid a downward angle which could cause shoulder compression. The headrest supports will have a secondary function of postioning the seatbelt strap near the edge of the seatback.
mnussbau
mnussbau is offline
PostPosted: Mon May 07, 2007 6:05 pm    Post subject: Reply with quote
I'd be a little concerned that bending the bracket would weaken it.
Mike
‘74 bug vert
Parts...
69911e
69911e is offline
PostPosted: Tue May 08, 2007 2:31 pm    Post subject: Reply with quote
The bracket is thick, mild steel so it is fine to bend without weakening it. The weakest point is the entire firewall which is just as weak as the original center mount for the lap belt. So, at the very least it should be as strong or stonger than original because the load is now distributed over 3 point instead of 2.
Than being said, I am in no legally binding way stating this is a safe modification, only that I have done it. As with all things you find on the internet use your own judgement.
