Skim Rants Master
Joined: April 15, 2001 Posts: 17095 Location: GFK 31 Year Vet
Posted: Fri Jan 19, 2007 8:25 pm Post subject: Mirror / Hing Pin Removal - ok I did a search |
My 60 SC came with no outside mirrors, I have the arms but whats the best way to knock out the door hing pins to put the mirror arms in. I know this has probably been asked a million times already. Thanks in advance. _________________ GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
1963 Deluxe Turkis Walk Thru 15 Window OG Paint |
campingbox  Samba Member
Joined: November 14, 2000 Posts: 10249 Location: Petaluma, CA
Posted: Fri Jan 19, 2007 8:31 pm Post subject: |
I use an air chisel. Be sure to have an anchor on top to keep from tweaking the door hinges (I'm sure you have access to a railroad tie). |
Skim Rants Master
Posted: Fri Jan 19, 2007 8:34 pm Post subject: |
should I marinate them in some PB blaster for a few days prior? _________________ GFK
1953 Kabriolet
1954 Sunroof
Posted: Fri Jan 19, 2007 8:38 pm Post subject: |
Skim wrote: |
should I marinate them in some PB blaster for a few days prior? |
It won't hurt.....I've never had one that an air chisel wouldn't move. |
Lind Samba Member
Joined: November 06, 2000 Posts: 10208 Location: idaho
Posted: Fri Jan 19, 2007 8:43 pm Post subject: |
Skim wrote: |
my experience is that the PB blaster won't really penetrate into it. it is too tight of a fit. _________________ .
Wanted:
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9830 Location: Exit 7, New Jersey
Posted: Fri Jan 19, 2007 9:05 pm Post subject: |
campingbox wrote: |
Please elaborate on the technique.
Thanks,
J. _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all!  |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10797 Location: iT StiNgeD iTseLf tO dEAd
Skim Rants Master
Posted: Fri Jan 19, 2007 9:26 pm Post subject: |
thanks Hazet  _________________ GFK
1953 Kabriolet
1954 Sunroof
Posted: Fri Jan 19, 2007 9:28 pm Post subject: |
Here's a photo of the piece of railroad track I used last time. This keeps you from damaging the hinge itself and still allows enough clearance to move the hinge pin. |
Skim Rants Master
Posted: Fri Jan 19, 2007 9:31 pm Post subject: |
campingbox wrote: |
haha now I get it, you said Railroad 'Tie', I was like hmmm?  _________________ GFK
1953 Kabriolet
1954 Sunroof
Posted: Fri Jan 19, 2007 9:33 pm Post subject: |
Skim wrote: |
haha now I get it, you said Railroad 'Tie', I was like hmmm? :?: :D |
My bad......what I meant was track. This specific "all-purpose tool" was found while travelling on the Shasta Snow Trip. |
Posted: Fri Jan 19, 2007 9:37 pm Post subject: |
Skim wrote: |
thanks Hazet  |
just saying, there might be some info in there that may help, and may not be said in here. please don't kill me. |
Skim Rants Master
Posted: Fri Jan 19, 2007 9:42 pm Post subject: |
hazetguy wrote: |
Skim wrote: |
thanks Hazet  |
1953 Kabriolet
1954 Sunroof
Posted: Fri Jan 19, 2007 9:52 pm Post subject: |
scruzdelux Samba Member
Joined: February 10, 2004 Posts: 44 Location: Santa Cruz, CA
Posted: Fri Jan 19, 2007 10:15 pm Post subject: |
This thread from Hazetguy looks the best. I removed mine by soaking with PB for several hours, heating to help the penetration, and knocking it out from below with a punch and small sledge. Air hammer sounds like a good way too. Once you get movement soak and heat some more. A good soaking, for as long as you can, is important.
-Jeff |
Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9016 Location: Portland, OR
Posted: Fri Jan 19, 2007 11:21 pm Post subject: |
One of mine was stuck to the point where I had to take the door off and invert it on an anvil and drive the pin out with a long drift and a BFH. It did finally come out though. |
Posted: Fri Jan 19, 2007 11:56 pm Post subject: |
Campingbox, do you have an air chisel insert small enough to punch out the pin? Or have you made up some sort of adaptor, or what? _________________ Founder and Chairman Emeritus, ECMSAS
Aaron Samba Luddite
Posted: Sat Jan 20, 2007 12:24 am Post subject: |
I couldn't find a correct size attachment when I had a stuck pin so I ground down a tapered attachment. Once I got the pin started I used the stem of an old valve and a mini sledge. |
Mr. Loaf Samba Member
Joined: March 30, 2005 Posts: 2098 Location: Okra, Oklahoma
Posted: Sat Jan 20, 2007 4:01 am Post subject: Pin |
If you get the old pins out don't forget to ream the hinges for the new pins. _________________ Never drive faster than your Angel can fly
$24,100 was too hard to resist................. |
Metalwizard Samba Member
Joined: October 21, 2003 Posts: 696 Location: Archdale, NC
Posted: Sat Jan 20, 2007 6:48 am Post subject: |
I soak with pb and for about 30 mins then i heat with the henrob torch. Spray it again, then use the air hammer while its still a bit warm. I have a tapered punch that came with my last new air hammer and it works great, its not tapered enuff to go all the way through but after it once moves 1/2 inch or so you can use a normal drift punch. Same deal works on cargo door hinges as well. I have just changed about 5 in the last month on this damn 56 Sunroof getting it ready to ship home later this week. If it don't kill me first that is. Oh also on the hinges do as Greg says about backing it up with something with some ass. And back the air down on the hammer, you shouldn't need full force, it might get away from you and fuck up something you don't want it to. Don't ask how i know that please.  _________________ http://s461.photobucket.com/albums/qq335/Metalwizard/
Kelly aka
"Bubble & Nut Buster for wannabe BadBoy's of Restoration"
"There is no cure for Stupid"
ITMC "Drill SGT" |
