Rbake Samba Member
Joined: October 10, 2004 Posts: 112 Location: Central Texas
Posted: Thu Nov 23, 2006 8:14 pm Post subject: Odyssey 680 mounted on inside of passenger firewall? |
anyone done this??
after searching, it apears that the odyssey 680 will crank and run a f/g dune buggy, anybody mounted it up high on the passenger firewall inside?
I'm trying to keep my back seat area clean w/out dropping the battery down over the torsion tube.
http://www.odysseybatteries.com/accessories/pc680hd.htm
the battery is really small in size and still cranks out 680 cca's, I'm pretty sure 350 cca's will start a v dub.
about $100 for the battery and another $60 on box doesn't seem too bad for not having to modify much. |
manxcraig Samba Member
Joined: November 12, 2006 Posts: 617 Location: pendelton (indianapolis) indiana
Posted: Thu Nov 23, 2006 8:54 pm Post subject: |
Someone posted on here about using a 350 cca garden tractor battery and was having no problems so........
Space for a full size battery can be hard to find. _________________ 69 Meyers Manx II on 65 pan, 1 owner !
WANTED, Meyers Manx license plate frames, repo OK, don't like the new smiles per miles ones. |
lostinbaja Samba Member
Joined: December 19, 2004 Posts: 4036 Location: Frankfort, Illinois
Posted: Fri Nov 24, 2006 4:45 am Post subject: |
I have been using lawn tractor batteries for years at $25.. bucks a crack. For $100 bucks I can have enough batterys to last me 16 years. Granted they are not quite as small and light weigh as the Odyssey. The Odyssey would work well mounted under the bottom of the back seat.
Why do you want to mount it so far away from the engine/starter? I think it's better to run 2- 8 gauge wires from the back (battery) to the front of the buggy then it is to run 2 battery cables from the dash (battery) to the engine in the rear of the buggy.
Just a thought,
Jerry... |
MURZI Samba Member
Joined: August 25, 2005 Posts: 5066 Location: Madisonville, La
Posted: Fri Nov 24, 2006 11:22 pm Post subject: |
I just started repping a line of batteries from EAST PENN for CARQUEST. We make a a couple of motorcycle batteries that are AGM or absorbed glass mat in design that would work well for a lot less money. They are completely sealed and can be mounted in any direction. I would use the ETX 18 or ETX 20. I would have used one on my buggy if I would have been repping them then and knew about them. WE are OEM for Harley Davidson. Here is a link to the specs:
http://www.batteryweb.com/motorcycledekaagm.cfm
And by the way using OHMS law, and assuming a 1800 watt starter with a 12.6 volt power source, we need about 140-160 CCA to spin our engines, so 225-275 CCA is more than enough to do the job.
Keep in mind, if you go with the Odyssey, although slick, what happens when that puppy goes out? With this line just pop in any CARQUEST and get a replacement.
AGM batteries are awesome and will go in all my stuff from now on. Do a search on google about them..
PSSSST an Optima battery uses this technology.....
MURZ _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Lo Cash John Samba Member
Joined: February 06, 2004 Posts: 2287 Location: Jacksonville, FL
Posted: Sat Nov 25, 2006 12:35 am Post subject: |
EAST PENN makes some really top of the line stuff for the TeleComm market too. I install TONS (literally!) of their batteries in telephone offices and cell sites for a living. _________________ www.LoCashRacing.org
Lo' Cash Racing Team on Facebook
More brains than bucks...Believe it or not!!
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone. |
Rbake Samba Member
Posted: Sat Nov 25, 2006 5:23 pm Post subject: |
Thanks for the info guys
MURZI do they sell a tight mounting box for that battery?
my rear seat area has no cuttouts or indentions for a battery, so I'm considering just mounting the odyssey under the buggy above the trans. I'd have to remove the rear tire to acess but I think it would look clean and still be close to the starter.
also, the odyssey can be bought on ebay for $93 so only $4 cheaper than the motorcycle battery and has 3 times the cca's. I have a 1915 so it probably takes a little more to spin. |
MURZI Samba Member
Posted: Sat Nov 25, 2006 8:44 pm Post subject: |
This is what I did on my berrien. Five bucks in angle iron, two muffler clamps, four 3/8 bolts, and 15 minutes of labor. I made a box perimeter with the angle iron, welded bolts to the bottom, and then used the "female ends" of the muffler clamps to clamp to the torsion. The UL1 lawnmower battery, 275CCA, cranked my 2276 just fine....even in July heat.
No doubt, the Odyssey will work great. The box will look trick too!! Do it!!
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
Posted: Sat Nov 25, 2006 10:41 pm Post subject: |
| MURZI wrote: |
Exactly what I did, but I switched to IRS. I'll find somwhere new before spring. _________________ 69 Meyers Manx II on 65 pan, 1 owner !
Dunebubby Samba Thread Killer
Joined: October 12, 2006 Posts: 882 Location: In my den,throwing darts at a picture of my ex-boss
Posted: Sat Nov 25, 2006 10:48 pm Post subject: IRS Batteries.... |
| manxcraig wrote: |
| MURZI wrote: |
Exactly what I did, but I switched to IRS. I'll find somwhere new before spring. |
The IRS swing arm and both half shaft boots ARE (barely!) visible in Murzi's picture.Looks like it works with IRS...... |
Posted: Sun Nov 26, 2006 1:48 am Post subject: |
I see said the blind man ! The battery is on top of the torsion, not behind it. I wont know if I have room untill the body is back on. _________________ 69 Meyers Manx II on 65 pan, 1 owner !
MURZI Samba Member
Posted: Sun Nov 26, 2006 3:02 pm Post subject: |
Build this box for one of those ETX 18's or ETX 20's . You would have plenty of room then. Yes, my car was IRS. _________________ 62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
bountyhunterdm Samba Member
Joined: October 29, 2006 Posts: 25 Location: California
Posted: Sun Nov 26, 2006 10:21 pm Post subject: |
Here's what I did. Turns over the buggy no problem. IT's ok if you don't need spare juice to run accesories without the engine running.
Rbake Samba Member
Posted: Mon Nov 27, 2006 10:09 am Post subject: |
Perfect!!
that's why I love this forum!!
Thanks BountyHunter!! That's exactly what I want to do, I'm ordering today. |
EMPIImp69 Samba Member
Joined: April 17, 2006 Posts: 3389 Location: Dirty Jersey
Posted: Fri Feb 16, 2007 1:47 pm Post subject: |
Hey Rbake, how did that 680 fit in your buggy? I am going to get one of these Odyssey batteries. Do you know if the PC925 will fit in an Empi Imp battery box? I need to measure the dimensions of the box once I get home? Which is the best of the 3, the PC925? thx
http://www.odysseybatteries.com/accessories/pc680hd.htm _________________ 1963 Ragtop Bug
1966 Vert Bug
Check out my ads, Thanks! |
kit.car Samba Member
Joined: January 16, 2004 Posts: 136 Location: Sterling , VA
Posted: Fri Feb 16, 2007 11:32 pm Post subject: |
I did the same thing as MURZI but with a Safari body and a IRS rear too. I used some angle iron and a pair of trailer axle U bolts. I think its a standard group 73 battery. $160 for battery and box sounds kind of spendy.
[/img] _________________ Joe |
Rbake Samba Member
Posted: Sat Feb 17, 2007 10:25 pm Post subject: |
| I haven't installed yet, but I plan on doing exactly what bountyhunderdm did. I've been working on my 32 roadster a little more lately. But, the 680 is going to work in it also!! |
MURZI Samba Member
Posted: Wed Feb 21, 2007 12:49 am Post subject: |
That odyssey pc680 is only 220 cca. Really look at the ETX line of batteries at CARQUEST. These batteries are AGM design just like the odyssey and can be deep cycled too. They are OEM on Harleys. Here are the specs. Sealed and can be mounted in any direction.
TECHNICAL SPECIFICATIONS
Model CCA AH L" W" H" LBS
ETX9 120 8 5.88 3.42 4.3 6.3
ETX12 180 10 5.88 3.42 5.13 9.4
ETX14 200 12 5.88 3.42 5.75 12
ETX15 190 14 5.25 3.5 6.55 11
ETX15L 190 14 5.25 3.5 6.55 11
ETX16 275 19 6.88 4 6.13 17
ETX16L 275 19 6.88 4 6.13 17
ETX18L 300 20 8.13 3.55 6.38 18
ETX20L 270 17.5 6.88 3.42 6.13 15.5
ETX30L 365 26 6.6 5.3 6.88 21.7
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam |
joemama Samba Member
Joined: February 09, 2006 Posts: 1666 Location: La Crescenta, California
Posted: Wed Feb 21, 2007 2:20 pm Post subject: odyssey batteries |
| Over the Christmas break, we went to Buttercup ( part of Glamis), with some friends, they had a rail that used 2 Odyssey batteries, one as a back up, neither would take a charge, dont know why, as they were only about a year old, but the real problem was that we could not find a replacement anywhere in the area, including Yuma, Arizona. Ended up strapping a group 24 battery in the rear seat floor pan. |
